    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 587 Posters 11.0m Views 589 Watching
    • fredo6F
      @pibuz said:
      is there any chance your tool "area report by material" could take into account ALSO the faces which are painted from the outside of a group/component?
      This is now available in FredoTools::ReportLabelArea v3.2a, with
      • FredoTools v3.8b
      • LibFredo6 v9.5e
        rv1974
        For some reason I can't install libfredo 9.5.e on SU2020 (win10 64 bit)
          The Lib installs fine for me [same OS etc] and it is fully signed etc...
            rv1974
            Manual extract to plugins folder solved the issue.
            • fredo6F
              NEW RELEASE: LibFredo6 v9.5g - 09 Feb 20
              LibFredo6 9.5g is a minor release necessary for Animator and FredoTools::MoveAlong. It corrects a problem when moving objects.
              • fredo6F
                NEW RELEASE: LibFredo6 v9.5f - 08 Feb 20
                LibFredo6 9.5f is a minor release necessary for VisuHole to capture stencil from container where axes are not oriented with Z being the normal to the thin plate.
                • B
                  Beaver99
                  Thank you so much for creating these tools, extremely valuable to my work flow.
                  You are
                  Awesome & Amazing !
                    Jeff Mack Designs
                    can you use this plug in with sketch up for web? like the free version?
                    when I go to Window the options outlined are not there.
                    ty.
                      ty.
                      No. As I told you elsewhere yesterday, the web versions of SketchUp have no implementation for using extensions.
                      • fredo6F
                        NEW RELEASE: LibFredo6 v9.5j - 25 Feb 20
                        LibFredo6 9.5j is a minor release for fixing a bug in some rare situations where the model has no attribute at all.
                        • fredo6F
                          NEW RELEASE: LibFredo6 v9.5h - 13 Feb 20
                          LibFredo6 9.5h is a minor release necessary for Animator. It corrects a problem when Easing functions.
                            Sunxl
                            Hi Fredo,
                            Do you know how to fix the problem shown as below,
                            [img]file:///C:/Users/SUN/Desktop/%E9%98%BF%E9%87%8C%E6%97%BA%E6%97%BA%E5%9B%BE%E7%89%8720200303012702.jpg[/img]
                            I tried the su2019 and 2020, But the SU still failed to load the Fredo6
                            Please help
                            Thank you
                              The image is missing you cannot link to a file that is on your own PC !
                              Try copy/paste ?
                                Sunxl
                                Try copy/paste ?
                                Sorry,this is my first time to use this.
                                载入文件 C:/Users/SUN/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rbe 时出错
                                Failed to read RBE/RBS file.
                                载入文件 Fredo6_!LibFredo6.rb 时出错
                                Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
                                C:/Users/SUN/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/SUN/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                                C:/Users/SUN/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'
                                thank you
                                • fredo6F
                                  This 'failed to load RBS/RBE' seems to be a problem related to the installation of Sketchup.
                                  Could you reinstall it, with 'run as administrator'.
                                    Sunxl
                                    Yes, I did. But the error still exist.
                                    I didn’t find any available solutions to deal with it.
                                      JDW Interiors
                                      Hi all,
                                      I've downloaded Fredoscale for my MacBook Pro 2018 but I can't seem to open it. I am running sketchup 2020.
                                      I firstly downloaded it from sketchUcation and then I went to 'Window>Extension manager>Install extension'
                                      In the extension manager it says the app is signed but I can't see how I can open the window and use the fredoscale tools.
                                      Can anyone help?
                                      Thanks in advance!
                                      Jack
                                        Have you quit out of SketchUp and reopened it to make sure both extensions load completely? After you do that you should be able to see the FredoScale tool palette in View>Tool palettes.
                                        • fredo6F
                                          NEW RELEASE: LibFredo6 v9.5k - 14 Mar 20
                                          LibFredo6 9.5k is a major release
                                          1. Fixes a bug preventing all my plugins to work with some configurations of MacOS Catalina
                                          2. Introduces a 'toolbar visibility' button in all the QuickLauncher dialogs of my plugins. This makes it easier to manage the visibility of icons in the toolbar, which was already available in the Default Parameters. You need to restart Sketchup for the changes to be effective.
                                          As an example, here is the new layout of the FredoScale QuickLauncher, with the visibility toggle buttons on the right (small eye).
                                          • E
                                            Elrodrules
                                            Hi -
                                            I had installed LibFredo6 9.5j and that was working fine. Today I tried to update to LibFredo6 9.5k and now I'm getting the following error(s). I'm using SketchUp Make 17.3.116 on a MacBook Air running macOS Catalina. I have quit and reopened SketchUp several times and the result is the same. Any suggestions?
                                            The first error window says:
                                            Curviloft 1.8a: Error starting up plugin (creating menus and icons)
                                            undefined method declare_topmenu' for #<Traductor::Plugin:0x007faf20183c70> [in bootstrap_curviloft.rbe: - #startup(): line 87]
                                            /users/ll/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1058:in `rescue in block in effective_load_part2'
                                            I click 'OK' and a second error window opens with these strings:
                                            Error: #<NameError: uninitialized constant Traductor::Plugin::T6>
                                            /users/ll/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1072:in effective_load_part2' /users/ll/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1003:in effective_load'
                                            /users/ll/library/application support/sketchup 2017/sketchup/plugins/fredo6_curviloft/__loader__curviloft.rbe:1:in <main>' /Applications/SketchUp 2017/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in eval'
                                            /Applications/SketchUp 2017/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in require' /Applications/SketchUp 2017/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in load'
                                            /Users/ll/Library/Application Support/SketchUp 2017/SketchUp/Plugins/Fredo6_Curviloft.rb:57:in register_extension' /Users/ll/Library/Application Support/SketchUp 2017/SketchUp/Plugins/Fredo6_Curviloft.rb:57:in module:Fredo6'
                                            /Users/ll/Library/Application Support/SketchUp 2017/SketchUp/Plugins/Fredo6_Curviloft.rb:26:in `<top (required)>'
                                            • 74
                                            • 75
                                            • 76
                                            • 77
                                            • 78
                                            • 113
                                            • 114
                                            • 76 / 114
