    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    447 Posts 110 Posters 472.8k Views 110 Watching
    • samuel_tS Offline
      samuel_t
      1.0.1 version adds:
      • Polygon reduction,
      • French translation.
      UIR Plugin Polygon Reduction Demo
      Download latest Universal Importer plugin from SketchUcation PluginStore.
      • fredo6F Offline
        Impressive...!
          Glenn at home
          Impressive, imported a Quake 2 (game) md3 file.
          Thank you
            glro
            dxf fileHi, i tried your plugin
            It worked for a OBJ file
            but not for this DXF file (joined)
            do you know why?
            • OxerO Offline
              Oxer
              Fantastic plugin but I work on mac, is there plan for macos support?
              Spanish Language File
              es.zip
                Khai
                ok. Cob (caligari trueSpace) is a little shakey, but don't worry, I'm likely to be the only person to be using that....
                OBJ so far is nice and solid, other than some scaling issues.. everythings coming in tiny 😉 but thats not a real issue...
                thanks again!
                • samuel_tS Offline
                  samuel_t
                  do you know why?
                  Import fails because filename contains a '#' character.
                  Substitute '#' with '_' and import will be succesful. 😉
                  plateforme_202001051957_ca.dxf
                  • samuel_tS Offline
                    samuel_t
                    @khai said:
                    thanks again!
                    You're welcome! 👍
                      paladinjnr
                      I have installed the plugin in my SketchUp 2018 , absolutely brilliant
                      how ever I am having a problem with textures , models import fine but no textures, which format should the textures be , I have tried dds and png
                      • kenK Offline
                        ken
                        I have not had this program to import any files, STL or OBJ or STP. Below is the following error message I get trying to import an STP file of a nut that is 24k large.
                        I did notice in the program, it lists the file as obj file when the file name is, CROSBY 2160 300T NUT.STP.
                        Thanks for your help.
                        Ken
                        • samuel_tS Offline
                          samuel_t
                          @paladinjnr said:
                          Could you please upload whole folder (model and textures) to a file hoster? This way I could debug it.
                          • samuel_tS Offline
                            samuel_t
                            Good news: I'm working on a macOS version of plugin. 😛 Stay tuned!
                              Run SketchUp as Administrator then re-import OBJ model. Let me know if problem persists.
                              If this step fixes the issue then it's almost certain that SketchUp was not installed correctly !
                              To fix it...
                              Whilst logged into Windows as your normal Windows user-name, ensure that SketchUp is closed.
                              Find the SketchUp installer's exe file - probably in your Downloads folder ?
                              Select the exe file's icon and right-click > context-menu > "Run as administrator"
                              When prompted choose "Repair".
                              Restart SketchUp and retry...
                              Installing any complex app in any other way can cause weird and unpredictable problems, often around permissions...
                              So never double-click an installer's exe file to 'Run' it - even if you have admin-powers, it is not the same thing.
                              • Didier BurD Offline
                                Didier Bur
                                French translation file 😄
                                fr.zip
                                DB
                                • samuel_tS Offline
                                  samuel_t
                                  @paladinjnr said:
                                  Hi Here is a link to the model as requested.
                                  Filehorst wurde abgeschaltet! Filehorst has been shut down!
                                  (filehorst.de)
                                  Your model had absolute paths to textures. That's not supported by plugin.
                                  I converted absolute paths to relative paths with a text editor. It's OK now:
                                  Fixed DirectX Model
                                  Fixed model is attached below:
                                  Fixed DirectX Model
                                  • samuel_tS Offline
                                    samuel_t
                                    Thank you! 😄
                                      Danish9762
                                      Hi sir im using sketchup 2017 when i install this plugins by extension manager so im getting unsigned plugin please contact plugins developer. Not working please gix it or tell me how to fix it
                                      • jujuJ Offline
                                        juju
                                        @Danish9762: You need to relax the extension loading policy you have set withing SketchUp.
                                        • samuel_tS Offline
                                          samuel_t
                                          @Danish9762 "Unsigned" problem isn't a bug, it just means plugin doesn't come from SketchUp Extension Warehouse.
                                          As suggested by @juju, relax SketchUp extension loading policy settings. To access these settings, select Window > Preferences > Extensions Policy (Microsoft Windows) or SketchUp > Preferences > Extensions > Policy tab (OS X). SketchUp has three available extension policy modes: “Identified Extensions Only”, “Approve Unidentified Extensions”, and “Unrestricted”. Select “Unrestricted” then restart SketchUp.
                                          • sketch3d.deS Offline
                                            sketch3d.de
                                            based on the MeshLab engine should maybe be mentioned.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 19 / 23
