    [Plugin] Universal Importer - v1.2.7 - 14 Nov. 2026
    459 Posts 112 Posters 647.3k Views 113 Watching
    • kenK
      ken
      I have not had this program to import any files, STL or OBJ or STP. Below is the following error message I get trying to import an STP file of a nut that is 24k large.
      I did notice in the program, it lists the file as obj file when the file name is, CROSBY 2160 300T NUT.STP.
      Thanks for your help.
      Ken
      • samuel_tS
        samuel_t
        @paladinjnr said:
        I have installed the plugin in my SketchUp 2018 , absolutely brilliant
        how ever I am having a problem with textures , models import fine but no textures, which format should the textures be , I have tried dds and png
        Could you please upload whole folder (model and textures) to a file hoster? This way I could debug it.
        • samuel_tS
          samuel_t
          @oxer said:
          Fantastic plugin but I work on mac, is there plan for macos support?
          Good news: I'm working on a macOS version of plugin. 😛 Stay tuned!
            Run SketchUp as Administrator then re-import OBJ model. Let me know if problem persists.
            If this step fixes the issue then it's almost certain that SketchUp was not installed correctly !
            To fix it...
            Whilst logged into Windows as your normal Windows user-name, ensure that SketchUp is closed.
            Find the SketchUp installer's exe file - probably in your Downloads folder ?
            Select the exe file's icon and right-click > context-menu > "Run as administrator"
            When prompted choose "Repair".
            Restart SketchUp and retry...
            Installing any complex app in any other way can cause weird and unpredictable problems, often around permissions...
            So never double-click an installer's exe file to 'Run' it - even if you have admin-powers, it is not the same thing.
            • Didier BurD
              Didier Bur
              French translation file 😄
              fr.zip
              DB
              • samuel_tS
                samuel_t
                @paladinjnr said:
                Hi Here is a link to the model as requested.
                Filehorst wurde abgeschaltet! Filehorst has been shut down!
                (filehorst.de)
                Your model had absolute paths to textures. That's not supported by plugin.
                I converted absolute paths to relative paths with a text editor. It's OK now:
                Fixed DirectX Model
                Fixed model is attached below:
                Fixed DirectX Model
                • samuel_tS
                  samuel_t
                  Thank you! 😄
                    Danish9762
                    Hi sir im using sketchup 2017 when i install this plugins by extension manager so im getting unsigned plugin please contact plugins developer. Not working please gix it or tell me how to fix it
                    • jujuJ
                      juju
                      @Danish9762: You need to relax the extension loading policy you have set withing SketchUp.
                      • samuel_tS
                        samuel_t
                        @Danish9762 "Unsigned" problem isn't a bug, it just means plugin doesn't come from SketchUp Extension Warehouse.
                        As suggested by @juju, relax SketchUp extension loading policy settings. To access these settings, select Window > Preferences > Extensions Policy (Microsoft Windows) or SketchUp > Preferences > Extensions > Policy tab (OS X). SketchUp has three available extension policy modes: “Identified Extensions Only”, “Approve Unidentified Extensions”, and “Unrestricted”. Select “Unrestricted” then restart SketchUp.
                        1 Reply Last reply 👍
                        • sketch3d.deS
                          sketch3d.de
                          based on the MeshLab engine should maybe be mentioned.
                          • P
                            paladinjnr
                            Will do
                            (filehorst.de)
                            Many Thanks Rae
                            Thank You for your help, I have spent most of today importing different models , some worked some didn't , so I am gong to give it a break for a couple of weeks then pick it up again .
                            Once again many thanks for your help
                            Keep up the good work
                            Rae
                            • samuel_tS
                              samuel_t
                              It was already mentioned on GitHub page. And now, it's also mentioned on SketchUcation page.
                                • OxerO
                                  Oxer
                                  Thanks for the macos version!! 👍
                                  SU2017 & macOS 10.13.6
                                  I found some problems with the importing:
                                  1. If you import a file that contains a space in filename (e.g. Pinas Prueba.obj), it appears a popup message window in Sketchup: "Import Error". I looked in the Console (I opened SketchUp via Terminal) and this is the error message:
                                  assimp export; wrote output file; /Users/Oxer/.UniversalImporter/tmp/Pinas Prueba.obj.dae
                                  Warning; uri contains white space, dom will convert them to %20 in output files!
                                    uri=#Pinas Prueba.obj.obj
                                  Error; daeStandardURIResolver;;resolveElement() - failed to resolve file;//localhost/Users/Oxer/.UniversalImporter/tmp/Pinas Prueba.obj.dae#Pinas Prueba.obj.obj
                                  2. With a file without spaces in filename Universal Importer work fine but nothing is imported, it appears a popup window in Sketchup with this text --> 'An empty component cannot be inserted'
                                  I probed with different file format: obj, dae, fbx, blend and the same in all.
                                  Perhaps it is a SketchUp error or perhaps is a problem with the scale, I don't know it, but I tried changing the 405 line in converter.rb:
                                  dae_export.sub!('meter="1"', 'meter="0.01"')
                                   to
                                   dae_export.sub!('meter="1"', 'meter="1"')
                                  And the Universal Importer inserted a flat component with two lines, see the image:
                                  3. When you select a file (e.g. in the Finder) to import, the plugin copy all Finder files to the temp folder, why? and are this files delete automatically or is it necessary delete manually?
                                  4. A minor detail, the texts 'Select a 3D Model' '3D Models |.3d;.3ds;.3mf;.ac;.ac3d;.acc;...' 'Select a Texture Atlas (Optional)' 'Images |.jpg;.png;*.bmp;||' do not appear in the importing windows.
                                  Again, thanks for your efforts !!
                                  • samuel_tS
                                    samuel_t
                                    Thanks for detailed report! 😉
                                    OK. I'm gonna fix that.
                                    @oxer said:
                                    2. With a file without spaces in filename Universal Importer work fine but nothing is imported, it appears a popup window in Sketchup with this text --> 'An empty component cannot be inserted' [...]
                                    Did you tried to import a completely different model? Could you please upload original "Pinas Prueba.obj + mtl + jpg" to a file hoster or here. This way I could debug it.
                                    Model and associated files are copied to a temp folder to avoid invalid characters in path.
                                    These temp files are automatically deleted at each import.
                                    Strange. Maybe it's a SketchUp API bug on MacOS... 😕
                                    • OxerO
                                      Oxer
                                      Hi, I tried to import the same Pinas.obj file with QuadTools plugin and the importing works fine.
                                      Here the files:
                                      Pinas.obj, Pinas.mtl and texture
                                      • OxerO
                                        Oxer
                                        It would be interest if other mac users test the file with other macos & SketchUp versions.
                                        • samuel_tS
                                          samuel_t
                                          @oxer said:
                                          EDIT: I see that you have change the converter.rb to V2, I'll test this new version of the file.
                                          Super. Thanks for your help.
                                          • OxerO
                                            Oxer
                                            I overwrited the converter.rb file and this is the result importing Pines.obj file:
                                            Two lines crossed in a vertical plane
                                            I made some testing with another models and formats, I used Blender to export the models to different formats.
                                            Original models created with Blender 2.82.
                                            THE RESULTS
                                            1. FBX format
                                            The importer works but there are some issues:
                                            A) The scale is multiplied by 100.
                                            B) It doesn't import the UVMap.
                                            C) With complex models the edges are displaced a little (see the image).
                                            2. OTHER FORMATS
                                            A) Cube 1 x 1 m, OBJ, PLY and DXF formats.
                                            B) Sphere 1 x 1 m, OBJ, PLY and DXF formats.
                                            EDIT: I see that you have changed the converter.rb to V2, I'll test this new version of the file.
                                            • 22
                                            • 23
                                            • 2 / 23
