⚠️ Libfredo 15.4b | Minor release with bugfixes and improvements Update
[Plugin] Universal Importer - v1.2.6 - 30 July 2024
441 Posts 106 Posters 432.2k Views 106 Watching
    samuel_t
    Hi! πŸ˜„ Here's a free new SketchUp plugin: Universal Importer. It imports more than 50 3D file formats*. Bonus: You can reduce polygon count of imported model or existing model.
    => You can download it from SketchUcation PluginStore .
    (*) Supported formats:
    • 3D
    • 3DS
    • 3MF
    • AC
    • AC3D
    • ACC
    • AMJ
    • ASE
    • ASK
    • B3D
    • BLEND
    • BREP
    • BVH
    • CSM
    • COB
    • DAE / Collada
    • DXF
    • ENFF
    • FBX
    • glTF 1.0 + GLB
    • glTF 2.0 + GLB
    • HMB
    • IFC-STEP
    • IGES 5.3
    • IQM
    • IRR / IRRMESH
    • LWO
    • LWS
    • LXO
    • M3D
    • MD2
    • MD3
    • MD5
    • MDC
    • MDL
    • MESH / MESH.XML
    • MOT
    • MS3D
    • NDO
    • NFF
    • OBJ
    • OFF
    • OGEX
    • PLY
    • PMX
    • PRJ
    • Q3O
    • Q3S
    • RAW
    • SCN
    • SIB
    • SMD
    • STEP AP203, 214, 242
    • STL
    • TER
    • UC
    • VTA
    • X
    • X3D
    • XGL
    • ZGL
      Pixero
      Wow. Thanks. Does it import textured objects?
        samuel_t
        @pixero said:
        [...] Does it import textured objects?
        Yes. If input model has only one material: select material texture at second step. If input model has more materials: you can ignore second step because materials should be automatically loaded:
          Khai
          thank you thank you thank you!!!
          started to move my old trueSpace models from the archives to Sketchup...
          just gotta work out a method tho... some of my models (well all of them) are multipart models that are to big to bring in as one mesh. problem is, splitting them down means having to line it all up again, unless I'm missing a key modifier for "paste in place"....
            samuel_t
            1.0.1 version adds:
            • Polygon reduction,
            • French translation.
            UIR Plugin Polygon Reduction Demo
            Download latest Universal Importer plugin from SketchUcation PluginStore .
            • F Offline
              Impressive...!
                Glenn at home
                Impressive, imported a Quake 2 (game) md3 file.
                Thank you
                SketchUp Pro 2024/2025 Dell XPS 8950 i9-12900K 64GB Ram RTX 3080
                  glro
                  dxf fileHi, i tried your plugin
                  It worked for a OBJ file
                  but not for this DXF file (joined)
                  do you know why?
                  • O Offline
                    Oxer
                    Fantastic plugin but I work on mac, is there plan for macos support?
                    Spanish Language File
                    es.zip
                      Khai
                      ok. Cob (caligari trueSpace) is a little shakey, but don't worry, I'm likely to be the only person to be using that....
                      OBJ so far is nice and solid, other than some scaling issues.. everythings coming in tiny πŸ˜‰ but thats not a real issue...
                      thanks again!
                        samuel_t
                        do you know why?
                        Import fails because filename contains a '#' character.
                        Substitute '#' with '_' and import will be succesful. πŸ˜‰
                        plateforme_202001051957_ca.dxf
                          samuel_t
                          @khai said:
                          thanks again!
                          You're welcome! πŸ‘
                            paladinjnr
                            I have installed the plugin in my SketchUp 2018 , absolutely brilliant
                            how ever I am having a problem with textures , models import fine but no textures, which format should the textures be , I have tried dds and png
                              ken
                              I have not had this program to import any files, STL or OBJ or STP. Below is the following error message I get trying to import an STP file of a nut that is 24k large.
                              I did notice in the program, it lists the file as obj file when the file name is, CROSBY 2160 300T NUT.STP.
                              Thanks for your help.
                              Ken
                                samuel_t
                                @paladinjnr said:
                                Could you please upload whole folder (model and textures) to a file hoster? This way I could debug it.
                                  samuel_t
                                  Good news: I'm working on a macOS version of plugin. πŸ˜› Stay tuned!
                                    Run SketchUp as Administrator then re-import OBJ model. Let me know if problem persists.
                                    If this step fixes the issue then it's almost certain that SketchUp was not installed correctly !
                                    To fix it...
                                    Whilst logged into Windows as your normal Windows user-name, ensure that SketchUp is closed.
                                    Find the SketchUp installer's exe file - probably in your Downloads folder ?
                                    Select the exe file's icon and right-click > context-menu > "Run as administrator"
                                    When prompted choose "Repair".
                                    Restart SketchUp and retry...
                                    Installing any complex app in any other way can cause weird and unpredictable problems, often around permissions...
                                    So never double-click an installer's exe file to 'Run' it - even if you have admin-powers, it is not the same thing.
                                    • Didier BurD Offline
                                      Didier Bur
                                      French translation file πŸ˜„
                                      fr.zip
                                      DB
                                        samuel_t
                                        @paladinjnr said:
                                        Hi Here is a link to the model as requested.
                                        Filehorst wurde abgeschaltet! Filehorst has been shut down!
                                        (filehorst.de)
                                        Your model had absolute paths to textures. That's not supported by plugin.
                                        I converted absolute paths to relative paths with a text editor. It's OK now:
                                        Fixed DirectX Model
                                        Fixed model is attached below:
                                        Fixed DirectX Model
                                          samuel_t
                                          Thank you! πŸ˜„
                                          • 22
                                          • 23
                                          • 1 / 23
                                          1 / 23
