    [Plugin] Universal Importer - v1.2.7 - 14 Nov. 2026
    459 Posts 112 Posters 647.3k Views 113 Watching
    • K
      Khai
      thank you thank you thank you!!!
      started to move my old trueSpace models from the archives to Sketchup...
      just gotta work out a method tho... some of my models (well all of them) are multipart models that are to big to bring in as one mesh. problem is, splitting them down means having to line it all up again, unless I'm missing a key modifier for "paste in place"....
      • samuel_tS
        samuel_t
        1.0.1 version adds:
        • Polygon reduction,
        • French translation.
        UIR Plugin Polygon Reduction Demo
        Download latest Universal Importer plugin from SketchUcation PluginStore.
        • fredo6F
          Impressive...!
          • G
            Glenn at home
            Impressive, imported a Quake 2 (game) md3 file.
            Thank you
            • G
              glro
              dxf fileHi, i tried your plugin
              It worked for a OBJ file
              but not for this DXF file (joined)
              do you know why?
              • OxerO
                Oxer
                Fantastic plugin but I work on mac, is there plan for macos support?
                Spanish Language File
                es.zip
                • K
                  Khai
                  ok. Cob (caligari trueSpace) is a little shakey, but don't worry, I'm likely to be the only person to be using that....
                  OBJ so far is nice and solid, other than some scaling issues.. everythings coming in tiny 😉 but thats not a real issue...
                  thanks again!
                  • samuel_tS
                    samuel_t
                    do you know why?
                    Import fails because filename contains a '#' character.
                    Substitute '#' with '_' and import will be succesful. 😉
                    plateforme_202001051957_ca.dxf
                    • samuel_tS
                      samuel_t
                      @khai said:
                      thanks again!
                      You're welcome! 👍
                      • P
                        paladinjnr
                        I have installed the plugin in my SketchUp 2018 , absolutely brilliant
                        how ever I am having a problem with textures , models import fine but no textures, which format should the textures be , I have tried dds and png
                        • kenK
                          ken
                          I have not had this program to import any files, STL or OBJ or STP. Below is the following error message I get trying to import an STP file of a nut that is 24k large.
                          I did notice in the program, it lists the file as obj file when the file name is, CROSBY 2160 300T NUT.STP.
                          Thanks for your help.
                          Ken
                          • samuel_tS
                            samuel_t
                            @paladinjnr said:
                            Could you please upload whole folder (model and textures) to a file hoster? This way I could debug it.
                            • samuel_tS
                              samuel_t
                              Good news: I'm working on a macOS version of plugin. 😛 Stay tuned!
                                Run SketchUp as Administrator then re-import OBJ model. Let me know if problem persists.
                                If this step fixes the issue then it's almost certain that SketchUp was not installed correctly !
                                To fix it...
                                Whilst logged into Windows as your normal Windows user-name, ensure that SketchUp is closed.
                                Find the SketchUp installer's exe file - probably in your Downloads folder ?
                                Select the exe file's icon and right-click > context-menu > "Run as administrator"
                                When prompted choose "Repair".
                                Restart SketchUp and retry...
                                Installing any complex app in any other way can cause weird and unpredictable problems, often around permissions...
                                So never double-click an installer's exe file to 'Run' it - even if you have admin-powers, it is not the same thing.
                                • Didier BurD
                                  Didier Bur
                                  French translation file 😄
                                  fr.zip
                                  DB
                                  • samuel_tS
                                    samuel_t
                                    @paladinjnr said:
                                    Hi Here is a link to the model as requested.
                                    Filehorst wurde abgeschaltet! Filehorst has been shut down!
                                    (filehorst.de)
                                    Your model had absolute paths to textures. That's not supported by plugin.
                                    I converted absolute paths to relative paths with a text editor. It's OK now:
                                    Fixed DirectX Model
                                    Fixed model is attached below:
                                    Fixed DirectX Model
                                    • samuel_tS
                                      samuel_t
                                      Thank you! 😄
                                        Danish9762
                                        Hi sir im using sketchup 2017 when i install this plugins by extension manager so im getting unsigned plugin please contact plugins developer. Not working please gix it or tell me how to fix it
                                        • jujuJ
                                          juju
                                          @Danish9762: You need to relax the extension loading policy you have set withing SketchUp.
                                          • samuel_tS
                                            samuel_t
                                            @Danish9762 "Unsigned" problem isn't a bug, it just means plugin doesn't come from SketchUp Extension Warehouse.
                                            As suggested by @juju, relax SketchUp extension loading policy settings. To access these settings, select Window > Preferences > Extensions Policy (Microsoft Windows) or SketchUp > Preferences > Extensions > Policy tab (OS X). SketchUp has three available extension policy modes: “Identified Extensions Only”, “Approve Unidentified Extensions”, and “Unrestricted”. Select “Unrestricted” then restart SketchUp.
                                            1 Reply Last reply 👍
                                            • 22
                                            • 23
                                            • 1 / 23
