    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.1m Views 79 Watching
    • utilerU Offline
      utiler
      Beautiful work as always, Cotty! Do you mind me asking what render program you're using? Very crisp.
      Just Curious...
      • cottyC Offline
        cotty
        Thank you, those are rendered with Indigo Renderer.
        my SketchUp gallery
        • tuna1957T Offline
          tuna1957
          A little late night messing about..... Made the little curved piece down front, follow me then Vertex tools to get the twist... Now what ???? Copy around and you get a kind of crazy flower shaped fruit bowl !
          • HornOxxH Offline
            HornOxx
            πŸ˜„ love this "messing" πŸ‘
            (btw "Messing" in German is the metal alloy brass πŸ˜„ πŸ˜„)
            never trust a skinny cook
            • tuna1957T Offline
              tuna1957
              @hornoxx said:
              πŸ™‚ love this "messing" πŸ‘
              Thanks HornOxx. Curious would "fooling about" translate better πŸ˜‰
              • O Offline
                optimaforever
                @thomthom said:
                Btw, do you have some quad that are not fully QuadFace quads? I see some unexpected uneven edges in the back there:
                [attachment=0:1mfg7n1x]<!-- ia0 -->2019-01-19_13h26_35.png<!-- ia0 -->[/attachment:1mfg7n1x]
                This is the same strange behaviour I got last year with some meshes. Dunno why, but it seems that some vertices react as a 1.0 crease when subdivided although they are 0 when checked with the crease tool.
                I usually delete the problematic edges and redraw the geometry from scratch when that happens.
                • tuna1957T Offline
                  tuna1957
                  More late night fooling about / practice. Seem obsessed with what I can make out of copies of one piece. Made the piece on the left, copy _ array twelve times. Exploded and regrouped. Cleaned up the internal bits with Solid Inspector. Decided to flare the top a little more, as always Vertex tools makes it easy. There you have another crazy vase.
                  • HornOxxH Offline
                    HornOxx
                    @tuna1957 said:
                    ...Seem obsessed with what I can make out of copies of one piece...
                    πŸ˜† πŸ˜† be careful - there is such a high addiction factor πŸ˜† again a so nice (not fooling!) practice πŸ‘ !
                    (in the throat(?) above you end up with a triangle - I still do not really understand correctly whether triangles are no longer an obstacle in this kind of workflow, which they were at the beginning of SubD)
                    • BoxB Offline
                      Next you'll start twisting them, then all is lost.
                      You'll have to start on the twelve steps and put your faith in a higher power...
                      • HornOxxH Offline
                        HornOxx
                        @box said:
                        Next you'll start twisting them...and put your faith in a higher power...
                        πŸ˜† πŸ˜† wunderbar !!
                        • tuna1957T Offline
                          tuna1957
                          Thanks Box , HornOxx.
                          HornOxx, you asked about triangles..... After I exploded the twelve pieces I erased and redrew the flat bottom inside and out so they were all quads. The pairs of triangles at the top just bellow the rim I could eliminate by " soft, smooth, no cast shadows" but I lost to much definition of the crease that way. Leaving them as triangles kept a better look to the vertical grooves. It seems you can cheat on the quads a little sometimes and still get a nice result.
                          • HornOxxH Offline
                            HornOxx
                            thanks for these Infos - yes, you are geting a better shape so πŸ‘
                            This Green-Blue look is this quadface tools live mesh analysis feature - I always forget about this good feature πŸ˜‰
                            • tuna1957T Offline
                              tuna1957
                              HornOxx, your correct the green, purple colors are from Quadface tools analyze function. I forget about it myself sometimes πŸ˜† .
                                @optimaforever said:
                                [attachment=0:gkjocs9z]<!-- ia0 -->2019-01-19_13h26_35.png<!-- ia0 -->[/attachment:gkjocs9z]
                                If you send me one of these models I can have a look into what is going on.
                                • tuna1957T Offline
                                  tuna1957
                                  Some more of my weird Vertex tools and SubD stuff. Twisted up the piece on the left, did some copy - array business. Add a few more bits and pieces and I ended up with a hanging lamp. SubD on the twisty bits and bottom trim ring the rest native SU.....
                                    Not by me! πŸ˜‰
                                    • BoxB Offline
                                      A couple of sinks I knocked up as an example.
                                      Simple
                                      https://i.imgur.com/cVYgeHu.gif
                                      Somewhat more complex
                                      https://i.imgur.com/vgEyLkv.gif
                                        No thickness ? πŸ˜‰
                                        • HornOxxH Offline
                                          HornOxx
                                          @pilou said:
                                          No thickness ? πŸ˜‰
                                          πŸ˜„ πŸ˜„ I think thickness doesn't make sense where it's not to be seen. but did you notice that Box even models the water overflow correctly? 😲 πŸ˜„ πŸ‘
                                            Yes of course, it was for find a little default on these voluptuous design beauties! πŸ˜‰
                                            The cool thing about Subdivision modeling it's that is always a surprise before the final object! β˜€
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 77
                                            • 82
                                            • 83
                                            • 75 / 83
