    Wrap-R for SketchUp
    extensions
    191 Posts 43 Posters 180.0k Views 43 Watching
    • O Offline
      Oxer
      Some new about Mac version?
        Gábor
        Still among the plans. No set relase date yet.
        Sent from my SM-G965F using Tapatalk
        • O Offline
          Oxer
          Thanks for the info!
            tengel07
            Payed nd got nothing! Cheater!
              juju
              This won't help resolve any problems you may be experiencing.
              More details would help though, like when the transaction happened, etc.
              Be sure to check you spam filters / folders as well, sometimes there are false positives.
                tengel07
                i did check my spam folder and my folder with mails from unkown too.
                Its now 24h after i did the payment and i got nothing - only the payment response mail.
                They do not respond on mails to support too.
                CHEATER!
                  Gábor
                  Hi tengel07,
                  Thank you for your interest in Wrap-R.
                  I'm now investigating what happened. Will answer your support ticket soon.
                  Gábor
                    Gábor
                    Hi tengel07,
                    I checked and our system sent out the licence by email at the time of the purchase. Sometimes it happens that some over sensitive spam filter puts it into the spam folder or erases it.
                    Anyhow now I've re-sent the licence both from the system and from my gmail mailbox. Hope you've received it this time.
                    Best regards,
                    Gábor
                      • QFT + SubD
                      What is QFT ? 😳
                        juju
                        @pilou said:
                        • QFT + SubD
                        What is QFT ? 😳
                        Quad Face Tools 👍
                          Aaaah! Thx! ☀
                          I believe that Optimaforever is an old famous member of PPB*! 😉
                          And Master of Su of course! 😎
                          • PushPullBar
                            A very cool SketchUp forum who has alas hacked! 😞
                            suSteve
                            Could you please confirm that it is compatible with make 2017 and pro 2019?
                            thank you (the wrap-r website says pro 2018).
                            Also the website has a cyber monday 2018 code is that still valid?
                            thank you
                              Get the latest version to ensure v2019 compatibility...
                              You can but try the code 😉
                                Gábor
                                Yes, it is compatible with these versions. But to be sure it fits your needs I suggest to obtain and try the 7 days free trial at https://wrap-r.com/trial-access.html .
                                If you already have purchased a license you can download the latest version of the program from here: https://s3.amazonaws.com/wrapr-download/WrapR-installer_2018_4.exe
                                • O Offline
                                  optimaforever
                                  @pilou said:
                                  Aaaah! Thx! ☀
                                  • PushPullBar
                                  Ah! salut Pilou! yes, I'm ryo from PPB 😉
                                    suSteve
                                    Thanks for the replies - just purchased. No need to do the free trial as the reviews are good enough for me.
                                      Gábor
                                      Thank you for purchasing Wrap-R. I wish you loads of happy unwrapping! 😄
                                        suSteve
                                        One of the bug bears and hopefully I have this wrong is:
                                        I choose ctrl to create the start of my cut and I can't see the end of my cut so I hold down the middle mouse and shift key to pan and by doing that I switch over to loop mode and lose my start cut.
                                        Is there a way around this?
                                        thank you
                                        Also, is there a way to pan the 3D object in wrap-r. I tried right click (which I think I saw somewhere) but that just gives me a context menu. Hand tool, middle mouse + shift does not work
                                        thanks again
                                          Gábor
                                          Do I understand well that you are trying to select an edge loop in the 2D window? In edge select mode pressing holding down T and left clicking an edge should mark the beginning of the edge loop. Then you can release T and pan with middle mouse button (Shift is not necessary) and then by again holding T and left clicking the end of the loop should create the loop. Is it not working so for you? Would it help if in loop select mode the middle mouse button would still do the panning?
                                          Panning in the 3D window should work with Shift + Right mouse button
                                            suSteve
                                            Thanks for the reply
                                            I am in edge select mode in Su. So I ctrl-click to start the loop and then have to pan so use shift-middle mouse and that changes the edge select mode to loop and I lose my start point
                                            thanks
                                            • 7 / 10
