    [Plugin][$] TopoShaper - v2.7a - 01 Apr 24
    455 Posts 144 Posters 694.9k Views 143 Watching
    • fredo6F Offline
      @Anastasia_0111
      Could you indicate the text of the error (just just give the files and line numbers), as well as post one of this simple model with free-hand drawn curve.
      Many thanks
        peggy1124
        Thank you Fredo
        amazing plugin
          Keniff
          Hi, Can't get this to work on my Mac. Using the supplied 'test' SKP file I either get a full on program bug splat! a non contoured output, just the shape of the face or the attached useless error message:
          Any help appreciated
            Keniff
            Hi, Finally got this working on my mac after I realised that it worked on a group rather than selecting points (contrary to some vids I've watched) However, now I've got it working the results I've got are not using all the cloud points in the group. Therefore the result is very "pointy" Any help appreciated
            • fredo6F Offline
              Very difficult to help if you do not post the model
                akaraphon
                hi fredo btw this plugin is very useful but i have some question . i want to create full area terrain but this is what i got . could you help me what i have to do
                ps. thank you
                  akaraphon
                  hi fredo ,i got some problem . i want to create terrain in full area but this is what i got . how can i do for expand the extent of terrain
                  thank you
                  • fredo6F Offline
                    If you include a face (or several) in the group where you have the Guide points, TopoShaper will use them for the contour of the terrain.
                    Anyway, the best is that you post your model so that I can have a look.
                      alpro
                      Fredo, first off let me thank you for all of your amazing plugins. I have a request for toposhaper. I don't know anything about coding and/or how difficult this would be. But in surface modeling programs you have the ability to add breaklines which make a more accurate surface. Do you think this can be added?
                      A Breakline is a line used to connect data representing a distinct surface feature, like a ridge line, edge of pavement, toe of a slope, centreline of a road, or flowline of a ditch or stream. When a breakline is defined, the surface triangulation must first follow the breakline, by placing triangle edges coincident with the breakline segments. This ensures the feature in the model is accurately depicted. Then, the rest of the interpolation is performed based on proximity. Breaklines are typically critical to creating an accurate surface model. It is the interpolation of the data, not just the data itself that determines the shape of the model.
                        alpro
                        That's great Fredo, look forward to it.
                        • fredo6F Offline
                          It is complex (it involves constrained Delaunay triangulation), but I finally built an algorithm (I use it already in FredoCorner). I will integrate it in TopoShaper when I can, along with a GUI refresh. This would look like a "from Contour", where you can also influence the terrain with additional guide points.
                          • pbacotP Offline
                            What I wonder how this could be input to the plugin. I'd like to see an example and how it might be implemented on UI level. I suppose edges that are horizontal can be introduced which are defined as firm intersections with the surface and not interpolated with the rest of the terrain. Working-in grades along retaining walls or building walls (rarely level) might be done be definition of point elevations.
                            My approach is usually working with existing terrain so after TopoShaper I massage it to new work as needed, sometimes cutting the surface where needed, sometimes moving points of the cut portions to fit to new walls or edges of pavement (e.g.). I see that where a vertical face is actually included in the original contours, weird results happen, but I generally rebuild that part or cover it in other geometry (like a model of the retaining wall it represents).
                            • fredo6F Offline
                              In general, it is better to conceive the terrain before adding decoration, houses, fences, etc...
                              But I'll think about what can be done, especially for roads.
                                KrisM
                                This would be GREAT addition to this plugin. I do this work manually at present and it is tedious to say the least. This would be a great time saver.
                                KrisM
                                • PixeroP Offline
                                  Pixero
                                  Something interactive like this for roads would be superb.
                                  https://www.youtube.com/embed/APuVx7Wdvk4?ecver=1
                                  And here is a open source road editor solution: https://gupea.ub.gu.se/bitstream/2077/23047/1/gupea_2077_23047_1.pdf
                                  • fredo6F Offline
                                    I think there is already a Plugin, InstantRoad by ValiArchitect.
                                    Anyway, building such a plugin is independent from TopoShaper, as it should apply to any terrain, whatever method has been used to generate it.
                                    • PixeroP Offline
                                      Pixero
                                      But Instant road isn't interactive like in the link.
                                        alpro
                                        So what I'm doing is recreating our existing conditions surveys so that design can be brought in in 3D for some presentations and renders. When creating surfaces in Civil 3D our spot shots are used for the surface but so is our line work as breaklines for things such as roads, sidewalks, retaining walls. When I bring the contours into SU and create a surface using topo shaper sometimes the differences are pretty significant and just like KrisM I have to manually make adjustments to the surface which is tedious. Toposhaper already is a great plugin but I think having this feature will make it even better.
                                        • fredo6F Offline
                                          NEW RELEASE: TopoShaper v2.4a - 19 Dec 18
                                          Requirement: LibFredo6 8.7a
                                          TopoShaper 2.4a is a maintenance release with small adjustments.
                                          Home Page of TopoShaper for information and Download.
                                          Main post of this TopoShaper thread.
                                            MelResDes
                                            Hello,
                                            I have never used Toposhaper before. I am trying to create a surface from the contour lines and I keep getting an error and the script aborts the operation. Attached is the Error:
                                            Date: 16-Feb-19 12:25:07
                                            An error occurred in CLEANSING
                                            The operation is fully aborted
                                            undefined local variable or method `colors_init' for #<F6_TopoShaper::TopoShaperCleanser:0x0000017fe1ef9f68>
                                            toposhapercleanser.rbe: 84 -- initialize
                                            toposhapertool.rbe: 541 -- new
                                            toposhapertool.rbe: 541 -- cleansing_processing
                                            toposhapertool.rbe: 523 -- after_selection
                                            toposhapertool.rbe: 493 -- notify_edge_picked
                                            body_lib6edgepicker.rbe: 445 -- call
                                            body_lib6edgepicker.rbe: 445 -- notify_action
                                            body_lib6edgepicker.rbe: 496 -- terminate_current_selection
                                            toposhapertool.rbe: 658 -- execute_validate
                                            toposhapertool.rbe: 387 -- handle_initial_selection
                                            toposhapertool.rbe: 319 -- activate
                                            toposhapertool.rbe: 133 -- select_tool
                                            toposhapertool.rbe: 133 -- action__mapping
                                            lib6plugin.rbe: 126 -- call
                                            lib6plugin.rbe: 126 -- launch_action
                                            lib6plugin.rbe: 224 -- launch_action
                                            bootstrap_toposhaper.rbe: 83 -- launch_action
                                            bootstrap_toposhaper.rbe: 136 -- block in startup
                                            lib6plugin.rbe: 1271 -- command_invoke
                                            lib6plugin.rbe: 1253 -- block (2 levels) in build_config_commands
                                            lib6traductor.rbe: 1361 -- block in add_command
                                            Please let me know if you need more info from me or if you need the file I am working on.
                                            • 22
                                            • 23
                                            • 6 / 23
