    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    456 Posts 144 Posters 857.0k Views 143 Watching
      akaraphon
      hi fredo ,i got some problem . i want to create terrain in full area but this is what i got . how can i do for expand the extent of terrain
      thank you
      • fredo6F Offline
        If you include a face (or several) in the group where you have the Guide points, TopoShaper will use them for the contour of the terrain.
        Anyway, the best is that you post your model so that I can have a look.
          alpro
          Fredo, first off let me thank you for all of your amazing plugins. I have a request for toposhaper. I don't know anything about coding and/or how difficult this would be. But in surface modeling programs you have the ability to add breaklines which make a more accurate surface. Do you think this can be added?
          A Breakline is a line used to connect data representing a distinct surface feature, like a ridge line, edge of pavement, toe of a slope, centreline of a road, or flowline of a ditch or stream. When a breakline is defined, the surface triangulation must first follow the breakline, by placing triangle edges coincident with the breakline segments. This ensures the feature in the model is accurately depicted. Then, the rest of the interpolation is performed based on proximity. Breaklines are typically critical to creating an accurate surface model. It is the interpolation of the data, not just the data itself that determines the shape of the model.
            alpro
            That's great Fredo, look forward to it.
            • fredo6F Offline
              It is complex (it involves constrained Delaunay triangulation), but I finally built an algorithm (I use it already in FredoCorner). I will integrate it in TopoShaper when I can, along with a GUI refresh. This would look like a "from Contour", where you can also influence the terrain with additional guide points.
              • pbacotP Offline
                What I wonder how this could be input to the plugin. I'd like to see an example and how it might be implemented on UI level. I suppose edges that are horizontal can be introduced which are defined as firm intersections with the surface and not interpolated with the rest of the terrain. Working-in grades along retaining walls or building walls (rarely level) might be done be definition of point elevations.
                My approach is usually working with existing terrain so after TopoShaper I massage it to new work as needed, sometimes cutting the surface where needed, sometimes moving points of the cut portions to fit to new walls or edges of pavement (e.g.). I see that where a vertical face is actually included in the original contours, weird results happen, but I generally rebuild that part or cover it in other geometry (like a model of the retaining wall it represents).
                • fredo6F Offline
                  In general, it is better to conceive the terrain before adding decoration, houses, fences, etc...
                  But I'll think about what can be done, especially for roads.
                    KrisM
                    This would be GREAT addition to this plugin. I do this work manually at present and it is tedious to say the least. This would be a great time saver.
                    KrisM
                    • PixeroP Offline
                      Pixero
                      Something interactive like this for roads would be superb.
                      https://www.youtube.com/embed/APuVx7Wdvk4?ecver=1
                      And here is a open source road editor solution: https://gupea.ub.gu.se/bitstream/2077/23047/1/gupea_2077_23047_1.pdf
                      • fredo6F Offline
                        I think there is already a Plugin, InstantRoad by ValiArchitect.
                        Anyway, building such a plugin is independent from TopoShaper, as it should apply to any terrain, whatever method has been used to generate it.
                        • PixeroP Offline
                          Pixero
                          But Instant road isn't interactive like in the link.
                            alpro
                            So what I'm doing is recreating our existing conditions surveys so that design can be brought in in 3D for some presentations and renders. When creating surfaces in Civil 3D our spot shots are used for the surface but so is our line work as breaklines for things such as roads, sidewalks, retaining walls. When I bring the contours into SU and create a surface using topo shaper sometimes the differences are pretty significant and just like KrisM I have to manually make adjustments to the surface which is tedious. Toposhaper already is a great plugin but I think having this feature will make it even better.
                            • fredo6F Offline
                              NEW RELEASE: TopoShaper v2.4a - 19 Dec 18
                              Requirement: LibFredo6 8.7a
                              TopoShaper 2.4a is a maintenance release with small adjustments.
                              Home Page of TopoShaper for information and Download.
                              Main post of this TopoShaper thread.
                                MelResDes
                                Hello,
                                I have never used Toposhaper before. I am trying to create a surface from the contour lines and I keep getting an error and the script aborts the operation. Attached is the Error:
                                Date: 16-Feb-19 12:25:07
                                An error occurred in CLEANSING
                                The operation is fully aborted
                                undefined local variable or method `colors_init' for #<F6_TopoShaper::TopoShaperCleanser:0x0000017fe1ef9f68>
                                toposhapercleanser.rbe: 84 -- initialize
                                toposhapertool.rbe: 541 -- new
                                toposhapertool.rbe: 541 -- cleansing_processing
                                toposhapertool.rbe: 523 -- after_selection
                                toposhapertool.rbe: 493 -- notify_edge_picked
                                body_lib6edgepicker.rbe: 445 -- call
                                body_lib6edgepicker.rbe: 445 -- notify_action
                                body_lib6edgepicker.rbe: 496 -- terminate_current_selection
                                toposhapertool.rbe: 658 -- execute_validate
                                toposhapertool.rbe: 387 -- handle_initial_selection
                                toposhapertool.rbe: 319 -- activate
                                toposhapertool.rbe: 133 -- select_tool
                                toposhapertool.rbe: 133 -- action__mapping
                                lib6plugin.rbe: 126 -- call
                                lib6plugin.rbe: 126 -- launch_action
                                lib6plugin.rbe: 224 -- launch_action
                                bootstrap_toposhaper.rbe: 83 -- launch_action
                                bootstrap_toposhaper.rbe: 136 -- block in startup
                                lib6plugin.rbe: 1271 -- command_invoke
                                lib6plugin.rbe: 1253 -- block (2 levels) in build_config_commands
                                lib6traductor.rbe: 1361 -- block in add_command
                                Please let me know if you need more info from me or if you need the file I am working on.
                                • fredo6F Offline
                                  Can you advise if you use Linux under the cover?
                                    MelResDes
                                    I am not really familiar with Linux other than it is an OS that I don't think I use. I'm using a standard Windows 10 OS and Sketchup Pro 2019.
                                    • fredo6F Offline
                                      I found the problem, which seems specific to SU2019.
                                      I will publish a fix.
                                      • fredo6F Offline
                                        NEW RELEASE: TopoShaper v2.5a - 16 Feb 19
                                        TopoShaper 2.5a includes a major fix for SU2019, preventing it to launch correctly .
                                          MelResDes
                                          The update worked! Thank you so much!
                                          • fredo6F Offline
                                            Thanks for signaling the problem.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 22
                                            • 23
                                            • 15 / 23
