    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    716 Posts 167 Posters 911.4k Views 166 Watching
      Anton_S
      @marvsweden said:
      I don't think converging pins works on MacOS. The handles change while holding the control-key but I can't actually converge them. Anton can you check?
      This has been fixed. Update to version 1.1.1, and use the SHIFT key for converging/diverging.
        Anton_S
        @jorgensen said:
        how do we use the material editor?
        i'm trying to create a curtain that stays almost strait - like a textile with almost no elasticity.
        but it seems that the cloth keeps behaving like it's silk - the curtain extends very much, and 'feels' very light when i push it.
        i have messed around with the material editor, but it does not seem to have any influence on the behavior of the cloth.
        jorgensen
        The material manager is just another way to adjust cloth properties and doesn't have any special things to it other than it can be saved and then used as a preset.
        Does increasing shear stiffness not help? If so, try reducing update timestep, to like 1/520. Reducing update timestep makes cloth stiffer.
          marvsweden
          Hey, I'm trying to understand all the settings. I can't see anything about it in the manual. I'm talking about thickness, bend, damper, shear and all that. Am I missing something?
          I'm trying to drape an object with a silk cloth and either it falls through the colliders or the thickness makes it sit up above the colliders too much. Also from what I understand there is an interplay between the grid size and some of the settings for cloth/collider. Is that right? It would be great if that could be covered in some way. Also, tooltips would be welcome for the settings. What are the numbers really, are they linked to the used unit or are they percentage? It's a little unclear. Don't get me wrong, I love it. I just don't understand it. I wanna learn more. πŸ˜„
            Anton_S
            If you assume that each edge is a linear spring and each two linked edges are an angular spring, then the shearcontrols the linear spring stiffness and bend controls the angular spring stiffness. As for the damping, it controls the drag factor for both type of springs.
            Cloth/collider thickness denotes an offset in mm. Other parameters are more associated to cloth mass ratio.
            Increase simulation viscosity, before draping, to allow the cloth settle in a less impactive way. That way you can avoid most overlaps.
            Yes. The smaller the grid spacing, the better is the result, but the less stiffer the cloth becomes. This is something that I have to consider improving in next version.
            To sum it up, the object is to release new version with improved physics and then make tutorials about other ClothWorks options.
              sofie9536
              Hello Anton, maybe I missed something, why does ClothWorks ask for the license number every time? (Windows 10)
              Thank you for your help
              • K
                kugelfisch
                Hallo Anton!
                I bought you plugin "Clothworks" today (2 hours ago). How long does it usually take for the license to arrive?
                  Anton_S
                  @kugelfisch said:
                  Hallo Anton!
                  It should arrive right away unless you entered a wrong email. I will send you a private message regarding this.
                    Anton_S
                    Hi, Sofie,
                    If you're referring to your licence constantly deactivating, there is an issue with the current version of SketchUcationTools, which I presume would be fixed upon next release cumming soon. We'll see if the issue is fixed then. Other than that, in the meantime, if your licensing seats fill up, let me know via a private message and I will reset them.
                    Anton
                    • V
                      valerostudio
                      This is a fun one! Having a great time playing with it and V-Ray Fur. TAKE MY MONEY!!!
                      • BoxB
                        A little inspiration for all the scifi modelers out there.
                        A flexible hatch.
                        https://i.imgur.com/YIYGvX9.gif
                          rv1974
                          IS animated calculation a mandatoty thing?.
                          May we get a simple 'show end (balanced) result' button?
                          It will also help to understand the influence of the settings. Currently it's close to impossible. Apropo it'd be fantastic to have an auto update mode (on end result) while tweaking those parameters
                          • BoxB
                            I know I'm doing things it's not really designed for but I like the simplicity of clothworks.
                            • majidM
                              majid
                              Seems stunning and I have an eye on it, does it also have "preventing self collision" option?
                              • FrederikF
                                Frederik
                                @majid said:
                                ...does it also have "preventing self collision" option?
                                Of course... πŸ˜„
                                Cheers
                                Kim Frederik
                                • HornOxxH
                                  HornOxx
                                  @valerostudio said:
                                  ...Having a great time playing with it and V-Ray Fur...
                                  πŸ‘ πŸ‘ looks really fantastic - is this fur here is a V-Ray internal feature?
                                  @box said:
                                  A little inspiration for all the scifi modelers out there...
                                  πŸ‘ πŸ‘ not only for the scifis out there πŸ˜„ again magic - a great elastic simulation πŸ‘
                                  never trust a skinny cook
                                  • V
                                    valerostudio
                                    Yes, what you are seeing is V-Ray Fur.
                                    • V
                                      valerostudio
                                      Is there a way to have pressure (or have a future feature) where you can have a pillow and drop it on to a sofa or bed? I have played with this in Max a little bit.
                                        smashor
                                        How can I make this kind of curtain?
                                        https://www.ikea.com/gb/en/images/rooms/ikea-clean-green-and-clutter-free-__1364315962817-s4.jpg
                                          Anton_S
                                          Flat curtains are usually really damp and neglect changing their form.
                                          You can control the shape by creating pins and moving some forward and some backward.
                                          The properties should be:
                                          • Shear Stiffness: 1.0
                                          • Bend Stifnness: 0.01
                                          • Damping: 1.0
                                          • Self-collision: ON
                                          When you finish simulating, you can set bending to 0.00, so the cloth rests completely.
                                          After simulation, you can apply loop subdivision and Laplacian smootheninth to better the result, as shown on the green curtain in the image below.
                                          Curtains5.skp
                                            Anton_S
                                            Nice video! Soft bodies are planned for V2.
                                            • 11
                                            • 12
                                            • 13
                                            • 35
                                            • 36
                                            • 11 / 36
