    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    715 Posts 166 Posters 843.6k Views 165 Watching
      Anton_S
      @marvsweden said:
      Hey, I'm trying to understand all the settings. I can't see anything about it in the manual. I'm talking about thickness, bend, damper, shear and all that. Am I missing something?
      If you assume that each edge is a linear spring and each two linked edges are an angular spring, then the shearcontrols the linear spring stiffness and bend controls the angular spring stiffness. As for the damping, it controls the drag factor for both type of springs.
      @marvsweden said:
      What are the numbers really, are they linked to the used unit or are they percentage?
      Cloth/collider thickness denotes an offset in mm. Other parameters are more associated to cloth mass ratio.
      @marvsweden said:
      I'm trying to drape an object with a silk cloth and either it falls through the colliders or the thickness makes it sit up above the colliders too much.
      Increase simulation viscosity, before draping, to allow the cloth settle in a less impactive way. That way you can avoid most overlaps.
      @marvsweden said:
      Also from what I understand there is an interplay between the grid size and some of the settings for cloth/collider. Is that right?
      Yes. The smaller the grid spacing, the better is the result, but the less stiffer the cloth becomes. This is something that I have to consider improving in next version.
      To sum it up, the object is to release new version with improved physics and then make tutorials about other ClothWorks options.
        sofie9536
        Hello Anton, maybe I missed something, why does ClothWorks ask for the license number every time? (Windows 10)
        Thank you for your help
          kugelfisch
          Hallo Anton!
          I bought you plugin "Clothworks" today (2 hours ago). How long does it usually take for the license to arrive?
            Anton_S
            @kugelfisch said:
            Hallo Anton!
            It should arrive right away unless you entered a wrong email. I will send you a private message regarding this.
              Anton_S
              Hi, Sofie,
              If you're referring to your licence constantly deactivating, there is an issue with the current version of SketchUcationTools, which I presume would be fixed upon next release cumming soon. We'll see if the issue is fixed then. Other than that, in the meantime, if your licensing seats fill up, let me know via a private message and I will reset them.
              Anton
              • V Offline
                valerostudio
                This is a fun one! Having a great time playing with it and V-Ray Fur. TAKE MY MONEY!!!
                • BoxB Offline
                  A little inspiration for all the scifi modelers out there.
                  A flexible hatch.
                  https://i.imgur.com/YIYGvX9.gif
                    rv1974
                    IS animated calculation a mandatoty thing?.
                    May we get a simple 'show end (balanced) result' button?
                    It will also help to understand the influence of the settings. Currently it's close to impossible. Apropo it'd be fantastic to have an auto update mode (on end result) while tweaking those parameters
                    • BoxB Offline
                      I know I'm doing things it's not really designed for but I like the simplicity of clothworks.
                      • majidM Offline
                        majid
                        Seems stunning and I have an eye on it, does it also have "preventing self collision" option?
                        • FrederikF Offline
                          Frederik
                          @majid said:
                          ...does it also have "preventing self collision" option?
                          Of course... πŸ˜„
                          Cheers
                          Kim Frederik
                          • HornOxxH Offline
                            HornOxx
                            @valerostudio said:
                            ...Having a great time playing with it and V-Ray Fur...
                            πŸ‘ πŸ‘ looks really fantastic - is this fur here is a V-Ray internal feature?
                            @box said:
                            A little inspiration for all the scifi modelers out there...
                            πŸ‘ πŸ‘ not only for the scifis out there πŸ˜„ again magic - a great elastic simulation πŸ‘
                            never trust a skinny cook
                            • V Offline
                              valerostudio
                              Yes, what you are seeing is V-Ray Fur.
                              • V Offline
                                valerostudio
                                Is there a way to have pressure (or have a future feature) where you can have a pillow and drop it on to a sofa or bed? I have played with this in Max a little bit.
                                  smashor
                                  How can I make this kind of curtain?
                                  https://www.ikea.com/gb/en/images/rooms/ikea-clean-green-and-clutter-free-__1364315962817-s4.jpg
                                    Anton_S
                                    Flat curtains are usually really damp and neglect changing their form.
                                    You can control the shape by creating pins and moving some forward and some backward.
                                    The properties should be:
                                    • Shear Stiffness: 1.0
                                    • Bend Stifnness: 0.01
                                    • Damping: 1.0
                                    • Self-collision: ON
                                    When you finish simulating, you can set bending to 0.00, so the cloth rests completely.
                                    After simulation, you can apply loop subdivision and Laplacian smootheninth to better the result, as shown on the green curtain in the image below.
                                    Curtains5.skp
                                      Anton_S
                                      Nice video! Soft bodies are planned for V2.
                                      • HieruH Offline
                                        Hieru
                                        Although we'll have to wait for future releases to do this properly, it's still possible with the current version.
                                        I just need to pull out my finger and find a screen capture method for recording my workflow.
                                        www.davidhier.co.uk
                                        • OxerO Offline
                                          Oxer
                                          My first test with the plugin, it has a lot of possibilities.
                                          • HornOxxH Offline
                                            HornOxx
                                            Hieru and Oxer - your examples just above are so great !! πŸ‘ πŸ‘
                                            how do you manage to generate these voluminous cloth shapes - whether as a pillow or a sack full of potatoes? what I mean is, which kind of cloth surface collides here onto or around which collider to get such a complex kind of result?
                                            • 11
                                            • 12
                                            • 13
                                            • 35
                                            • 36
                                            • 11 / 36
