    SketchUp 2018 Video Card
    24 Posts 8 Posters 6.6k Views 8 Watching
      Unfortunately there is a known bug in the CheckUp app that misreports
      Actually it's a Windows bug that the CheckUp app exposes.
        Philw
        Thanks for the replies,
        Interesting notes on the glitch in the checkup app that changes my thinking on getting a new card.
        The problem that I have with 3D vegetation is it takes a long time to import and to save the files. It can take 3 to 5 minutes to save a file, as far as moving the geometry it really slow as well. I am not talking about a huge scene with lots of geometry a bush or a tree or two cause problems. These are the same items I have used in the past in other project with no problems.
        This just started a little while ago, I’d say a little over a month or so ago so it’s not just SKU 2018. The computer is a little over a year old and is a desk top unit. It supposes to be a high end gaming machine which in the past has worked well for me. Could it be something in the updates for windows 10?
        • jujuJ Offline
          juju
          It might be since historically there has been problems with and Windows 10, but I've mainly seen (online, on this forum and on SketchUp official forum) problems with selecting, etc.
          • pmolsonP Offline
            pmolson
            If the problem started all of the sudden and you had not had that issue previously I would check the driver for your graphics card. You may need to roll it back if windows updated it and your performance dropped.
            Another thing that can happen with 3d vegetation is you can run across a component that is poorly designed and bogs everything down. Even if it just that one tree or whatever. I had a 3d birch tree just this morning that was so heavy it caused sluggishness all by its lonesome. I run a gtx 1080 and do not have issues unless there is a bad driver update or bad 3d component.
            p
            • Paul RussamP Offline
              Paul Russam
              The nature of your vegetation can have a massive impact on a model, I have a 2m hedge (can't remember where I got it) that will cripple any model as soon as I place it yet the premium trees from here will have little (ok maybe not little but the model is still workable) impact when used.
              Here's a Twilight rendered image of a heavily planted model, it takes longer to open than normal but it's not excessive and once open I can move around quickly enough.
              I'm using a MacBookPro i7/16Gb with a Radion R9 M370x, I'm using Windows 10 via a bootcamp partition as I can't stand SU on MacOS
              Paul Russam
              English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                Philw
                I typically look at the files sizes before I add them to one of my files and I try and keep them around a mg as much as I can. I typically do interiors and close up of exteriors at home, so I typically don’t need a forest of items. As I said before it’s not been a problem in the past. I’ll have to look at the drivers tonight when I get back home, I don’t remember if I have updated them recently or not.
                Would the video card cause SketchUp to perform poorly or as stated earlier the CPU of the computer could be a problem?
                  Paul Russam
                  I planning a new pc now for SU and Lumion and a 1070 is my intended card, I’d be very very surprised if it was a bottleneck. Drivers could be (and frequently are) an issue, it wouldn’t do any harm to install the latest set from Nvidia. I’d also go through the process of removing all existing drivers 1st as they have been know to not properly update leaving you with a mix of old and new files littered throughout your system.
                  It seems from this post (https://www.evga.com/support/faq/afmviewfaq.aspx?faqid=59195) that the nvidia drivers can do a complete uninstall during the install process.
                  Paul Russam
                    Philw
                    Thanks Paul,
                    I'll try it and let you know what happens.I will also look at the 1070 as a possibility for my next move. I use Podium and lately V Ray 3.6 to render.
                      Paul Russam
                      You said you currently have a GTX1070 in your original post.
                      Paul Russam
                        Philw
                        oh, yea
                        Im at work and doing 2 things at once and didn't catch that..
                          Philw
                          I ran the uninstall/install and so far things are fine in the short time I had to play with my files.
                          FYI and for what its worth I ran the SKU check up before and after and i get the same message.
                          Thanks Paul Russam and everyone for your help. 'lll let you know if there are still problems later.
                            Paul Russam
                            GTX1070’s all come with 8Gb of memory so that’s an obvious bug in CheckUp.
                            Paul Russam
                              Paul Russam
                              IF you want to test your system then I suggest you try Passmark's performance test: https://www.passmark.com/products/pt.htm
                              You can then compare your scores (cpu, video card etc) against other cards here:
                              Video cards: https://www.videocardbenchmark.net
                              CPU's: https://www.cpubenchmark.net/
                              Paul Russam
                                Philw
                                I'll give it a try.
                                  CJRyan
                                  Philw,
                                  I got the same report when I started having problems with my ASUS GTX Titan X. And it has 12GB of GDDR5.
                                  It started running sluggishly after I updated my drivers. I've still not gotten it running correctly, but by turning off "profiles" in my styles tab, it's speed is acceptable again.
                                  And while I know SU is CPU driven, IMHO without a decent graphics card, zooming and orbiting becomes rather tedious.
                                    Philw
                                    "GPUs won't improve SketchUp performance"
                                    I have found out that it does make a difference and the changes help to improve my computers performance;
                                    Sketchup computer problem
                                    I am having issues with SketchUp that I hope someone can help answer. When a file gets to a certain size on my home computer it become sluggish, slow and long save time or crashing the computer become necessary because i…
                                    SketchUp Community (forums.sketchup.com)
                                      Philw
                                      Here is a new issue,
                                      I am just doing a File>save and I getting the attached. the program is creating a new file with"-0"
                                      What is this about?
                                        What is this about?
                                        It's not a new thing. It's been happening for the last couple of versions or so. I get it periodically when I try to save after exporting to KT. I just save before sending. Currently no fix that I've heard about. When it occurs the file does get saved with the 0 appended. Annoying but at least no work is lost.
                                        • sketch3d.deS Offline
                                          sketch3d.de
                                          @philw said:
                                          Here is a new issue,...
                                          ... which should be posted in a new thread.
                                            sketch3d.de
                                            @philw said:
                                            NVIDIA GeForce GTX 1070 vs. Nvidia Quadro M2000
                                            additionally, a Quadro M2000 is much slower than a GTX 1070... don't buy.
                                            If you need more performance invest in a high-clocked CPU and don't use high-poly components during modeling, i.e. move to a dedicated layer and switch off or do use proxy components during modeling which can be swapped to the full-blown components when modeling is finished:
                                            https://s3-us-west-2.amazonaws.com/assets.sketchup.com/web/ewh/s3fs-public/s3fs-public/Chairs.gif
