    SketchUp 2018 Video Card
    24 Posts 8 Posters 7.6k Views 8 Watching
    • P
      Philw
      Thanks Paul,
      I'll try it and let you know what happens.I will also look at the 1070 as a possibility for my next move. I use Podium and lately V Ray 3.6 to render.
      • Paul RussamP
        Paul Russam
        You said you currently have a GTX1070 in your original post.
        Paul Russam
        English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
        • P
          Philw
          oh, yea
          Im at work and doing 2 things at once and didn't catch that..
          • P
            Philw
            I ran the uninstall/install and so far things are fine in the short time I had to play with my files.
            FYI and for what its worth I ran the SKU check up before and after and i get the same message.
            Thanks Paul Russam and everyone for your help. 'lll let you know if there are still problems later.
            • Paul RussamP
              Paul Russam
              GTX1070’s all come with 8Gb of memory so that’s an obvious bug in CheckUp.
              Paul Russam
              • Paul RussamP
                Paul Russam
                IF you want to test your system then I suggest you try Passmark's performance test: https://www.passmark.com/products/pt.htm
                You can then compare your scores (cpu, video card etc) against other cards here:
                Video cards: https://www.videocardbenchmark.net
                CPU's: https://www.cpubenchmark.net/
                Paul Russam
                • P
                  Philw
                  I'll give it a try.
                  • C
                    CJRyan
                    Philw,
                    I got the same report when I started having problems with my ASUS GTX Titan X. And it has 12GB of GDDR5.
                    It started running sluggishly after I updated my drivers. I've still not gotten it running correctly, but by turning off "profiles" in my styles tab, it's speed is acceptable again.
                    And while I know SU is CPU driven, IMHO without a decent graphics card, zooming and orbiting becomes rather tedious.
                    • P
                      Philw
                      "GPUs won't improve SketchUp performance"
                      I have found out that it does make a difference and the changes help to improve my computers performance;
                      Sketchup computer problem
                      I am having issues with SketchUp that I hope someone can help answer. When a file gets to a certain size on my home computer it become sluggish, slow and long save time or crashing the computer become necessary because i…
                      SketchUp Community (forums.sketchup.com)
                      • P
                        Philw
                        Here is a new issue,
                        I am just doing a File>save and I getting the attached. the program is creating a new file with"-0"
                        What is this about?
                          What is this about?
                          It's not a new thing. It's been happening for the last couple of versions or so. I get it periodically when I try to save after exporting to KT. I just save before sending. Currently no fix that I've heard about. When it occurs the file does get saved with the 0 appended. Annoying but at least no work is lost.
                          • sketch3d.deS
                            sketch3d.de
                            @philw said:
                            Here is a new issue,...
                            ... which should be posted in a new thread.
                            • sketch3d.deS
                              sketch3d.de
                              @philw said:
                              NVIDIA GeForce GTX 1070 vs. Nvidia Quadro M2000
                              additionally, a Quadro M2000 is much slower than a GTX 1070... don't buy.
                              If you need more performance invest in a high-clocked CPU and don't use high-poly components during modeling, i.e. move to a dedicated layer and switch off or do use proxy components during modeling which can be swapped to the full-blown components when modeling is finished:
                              https://s3-us-west-2.amazonaws.com/assets.sketchup.com/web/ewh/s3fs-public/s3fs-public/Chairs.gif
                              • P
                                Philw
                                Dave R,
                                Thank you for the clarification of the “-0” file. This has been a new issues for me since moving to 2018 version. I hope they fix it soon its annoying, so I need to now throw out the original file and remove the “-0” file to get back the original name?
                                Its like the message “Not responding” instead of something like “this program is work on it’” and seeing a little hour glass spin around and round on my screen…that way I know it’s doing something other than crashing.
                                sketch3d.de,
                                You are right, this should have been a new thread.
                                I’m just frustrated that I can’t install what I have purchased and have it work,( like it use to be) without having to figure out that things have changed and I should just know about them, like picking running as an administrator (when did that happen?). But that another topic too.
                                sorry just venting...
