    SketchUp 2018 Video Card
    24 Posts 8 Posters 8.0k Views 8 Watching
    • P
      Philw
      oh, yea
      Im at work and doing 2 things at once and didn't catch that..
      • P
        Philw
        I ran the uninstall/install and so far things are fine in the short time I had to play with my files.
        FYI and for what its worth I ran the SKU check up before and after and i get the same message.
        Thanks Paul Russam and everyone for your help. 'lll let you know if there are still problems later.
        • Paul RussamP
          Paul Russam
          GTX1070’s all come with 8Gb of memory so that’s an obvious bug in CheckUp.
          Paul Russam
          English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
          • Paul RussamP
            Paul Russam
            IF you want to test your system then I suggest you try Passmark's performance test: https://www.passmark.com/products/pt.htm
            You can then compare your scores (cpu, video card etc) against other cards here:
            Video cards: https://www.videocardbenchmark.net
            CPU's: https://www.cpubenchmark.net/
            Paul Russam
            • P
              Philw
              I'll give it a try.
              • C
                CJRyan
                Philw,
                I got the same report when I started having problems with my ASUS GTX Titan X. And it has 12GB of GDDR5.
                It started running sluggishly after I updated my drivers. I've still not gotten it running correctly, but by turning off "profiles" in my styles tab, it's speed is acceptable again.
                And while I know SU is CPU driven, IMHO without a decent graphics card, zooming and orbiting becomes rather tedious.
                • P
                  Philw
                  "GPUs won't improve SketchUp performance"
                  I have found out that it does make a difference and the changes help to improve my computers performance;
                  Sketchup computer problem
                  I am having issues with SketchUp that I hope someone can help answer. When a file gets to a certain size on my home computer it become sluggish, slow and long save time or crashing the computer become necessary because i…
                  SketchUp Community (forums.sketchup.com)
                  • P
                    Philw
                    Here is a new issue,
                    I am just doing a File>save and I getting the attached. the program is creating a new file with"-0"
                    What is this about?
                      What is this about?
                      It's not a new thing. It's been happening for the last couple of versions or so. I get it periodically when I try to save after exporting to KT. I just save before sending. Currently no fix that I've heard about. When it occurs the file does get saved with the 0 appended. Annoying but at least no work is lost.
                      • sketch3d.deS
                        sketch3d.de
                        @philw said:
                        Here is a new issue,...
                        ... which should be posted in a new thread.
                        • sketch3d.deS
                          sketch3d.de
                          @philw said:
                          NVIDIA GeForce GTX 1070 vs. Nvidia Quadro M2000
                          additionally, a Quadro M2000 is much slower than a GTX 1070... don't buy.
                          If you need more performance invest in a high-clocked CPU and don't use high-poly components during modeling, i.e. move to a dedicated layer and switch off or do use proxy components during modeling which can be swapped to the full-blown components when modeling is finished:
                          https://s3-us-west-2.amazonaws.com/assets.sketchup.com/web/ewh/s3fs-public/s3fs-public/Chairs.gif
                          • P
                            Philw
                            Dave R,
                            Thank you for the clarification of the “-0” file. This has been a new issues for me since moving to 2018 version. I hope they fix it soon its annoying, so I need to now throw out the original file and remove the “-0” file to get back the original name?
                            Its like the message “Not responding” instead of something like “this program is work on it’” and seeing a little hour glass spin around and round on my screen…that way I know it’s doing something other than crashing.
                            sketch3d.de,
                            You are right, this should have been a new thread.
                            I’m just frustrated that I can’t install what I have purchased and have it work,( like it use to be) without having to figure out that things have changed and I should just know about them, like picking running as an administrator (when did that happen?). But that another topic too.
                            sorry just venting...
                            • 2 / 2
