    [Plugin] Lines to tubes
    131 Posts 61 Posters 312.2k Views 61 Watching
    • josephkim626J
      josephkim626
      @pilou said:
      Seems bugged! πŸ˜‰
      Or works only for curves ?
      Seems working only from polys of 5 segments! πŸ˜‰
      [attachment=1:17is50ip]<!-- ia1 -->GIF_bugged.gif<!-- ia1 -->[/attachment:17is50ip]
      Indeed it behaves funny when it is run on rectangles.
      But it seems fine for some others.
      [attachment=0:17is50ip]<!-- ia0 -->tube.gif<!-- ia0 -->[/attachment:17is50ip]
        Seems bugged! πŸ˜‰
          The "Do curve" is somptuous! πŸ‘
          (not my video πŸ’š
          (currioussly don't works for the rectangles! 😲
          Bravo to Sdmitch! 😎
          Ps Will be very fine for any "section" πŸ˜‰
          • ntxdaveN
            ntxdave
            One thing that does not work correctly for me is the Materials parameter. It will only allow me to select a material that has already been used in the model.
            Maybe I am doing something wrong................
            Press F1...thank me later
              To give you access to the potentially thousands of material SKM files that are not currently used in the model could be unbelievably complex, even it it were easy to do in the API - which unfortunately it is not...
              To be frank having any material choice seems overkill, as it is really a a geometry creator ?
              • sdmitchS
                sdmitch
                Fixed the problem with rectangles in my Edge_to_Tube plugin. Normal rectangles are bounded by 4 edges and not a 'curve' as polygons and circles are.
                http://sdmitch.blogspot.com/
                  Excellent! πŸ‘
                  And can we imagine the same with any section ?
                    rv1974
                    My $0.02:
                    1. Fredo's Make curves (weld)
                    2. S4u 'Make Frame'
                      Yes but quid of differents number of segments of sections ? πŸ˜‰
                      @Sdmitch
                      Seems the "Do Curve" don't works in the new version!
                      Edit: Sorry I don't draw a polygon but a rectangle! 😳
                      The trick is draw a poly with 4 edges then resize with FredoScale! πŸ˜„
                      • fionmacoolF
                        fionmacool
                        Merci pour le Plugin. : )
                        Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
                        • H
                          huajiet
                          @sdmitch said:
                          Yes, but this particular plugin is scrambled so only the creator can make that change.
                          I'm hoping to set the default 'Precision' input at 20. looked into the .rb file but it's all scrambled. anyone can help?
                          sdmitch, where can I download your Edge_to_Tube plugin?
                            Munene
                            How do you download the extension
                            • Didier BurD
                              Didier Bur
                              Go to the Resources tab and select the PluginStore option.
                              Regards
                              DB
                                samodelkin_77
                                @huajiet said:
                                look at this plugin:
                                https://transfiles.ru/lwtkd
                                  samodelkin_77
                                  and how to insert images when responding? I didn't find where to click.press. I had to upload it to a file sharing service..
                                    You didn't find the part of the Reply page shown in the red box, below?
                                    Click on Choose File, select the file on your computer, click Add the file.
                                      samodelkin_77
                                      And I was looking at the top and side)) and it wasn't even visible below... it didn't fit into the screen)) thanks.
                                      And I threw this picture on the file sharing site, maybe this plugin (1001) will help with pipes...
                                      • massimoM massimo referenced this topic on
                                        Mahasamaritan Newcomers @Chris Fullmer
                                        @Chris-Fullmer said in [Plugin] Lines to tubes:
                                        It was listed just fine for me on Vista 64bit in the tools menu. Great plugin!
                                        Here's a helix, triple helix, double helix, something that isn't a helix, but sort of close, then another 10x helix or something. I'm sure most of those names are wrong, so just look at the picture πŸ˜„
                                        How can you make Lines to Tubes work in Sketchup 2014?
                                        Dave RD 1 Reply Last reply
                                          Dave R @Mahasamaritan
                                          @Mahasamaritan said in [Plugin] Lines to tubes:
                                          Just install it using the Sketchucation ExtensionStore tool, select the edges and then run it. It works just fine in older SketchUps.
                                            mleslieperez Newcomers
                                            Mine is saying "unsigned" so it isn't able to install on my sketchup... can you help me fix this?
                                            • 6 / 7
