    [Plugin] Lines to tubes
    131 Posts 61 Posters 304.4k Views 61 Watching
      Excellent! πŸ‘
      And can we imagine the same with any section ?
        rv1974
        My $0.02:
        1. Fredo's Make curves (weld)
        2. S4u 'Make Frame'
          Yes but quid of differents number of segments of sections ? πŸ˜‰
          @Sdmitch
          Seems the "Do Curve" don't works in the new version!
          Edit: Sorry I don't draw a polygon but a rectangle! 😳
          The trick is draw a poly with 4 edges then resize with FredoScale! πŸ˜„
          • fionmacoolF Offline
            fionmacool
            Merci pour le Plugin. : )
            Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
            • H Offline
              huajiet
              @sdmitch said:
              Yes, but this particular plugin is scrambled so only the creator can make that change.
              I'm hoping to set the default 'Precision' input at 20. looked into the .rb file but it's all scrambled. anyone can help?
              sdmitch, where can I download your Edge_to_Tube plugin?
                Munene
                How do you download the extension
                • Didier BurD Offline
                  Didier Bur
                  Go to the Resources tab and select the PluginStore option.
                  Regards
                  DB
                    samodelkin_77
                    @huajiet said:
                    look at this plugin:
                    https://transfiles.ru/lwtkd
                      samodelkin_77
                      and how to insert images when responding? I didn't find where to click.press. I had to upload it to a file sharing service..
                        You didn't find the part of the Reply page shown in the red box, below?
                        Click on Choose File, select the file on your computer, click Add the file.
                          samodelkin_77
                          And I was looking at the top and side)) and it wasn't even visible below... it didn't fit into the screen)) thanks.
                          And I threw this picture on the file sharing site, maybe this plugin (1001) will help with pipes...
                          • massimoM massimo referenced this topic on
                            Mahasamaritan Newcomers @Chris Fullmer
                            @Chris-Fullmer said in [Plugin] Lines to tubes:
                            It was listed just fine for me on Vista 64bit in the tools menu. Great plugin!
                            Here's a helix, triple helix, double helix, something that isn't a helix, but sort of close, then another 10x helix or something. I'm sure most of those names are wrong, so just look at the picture πŸ˜„
                            How can you make Lines to Tubes work in Sketchup 2014?
                              Dave R @Mahasamaritan
                              @Mahasamaritan said in [Plugin] Lines to tubes:
                              Just install it using the Sketchucation ExtensionStore tool, select the edges and then run it. It works just fine in older SketchUps.
                                mleslieperez Newcomers
                                Mine is saying "unsigned" so it isn't able to install on my sketchup... can you help me fix this?
                                  Being 'unsigned' need not be a problem.
                                  Edit your native Extension Manager settings - Loading Policy > Unrestricted
                                  Restart SketchUp and version-compatible, but 'unsigned', extensions [i.e. usually older] will then load OK.
                                  Only install extensions from trustworthy sources - like SketchUcation, the Extension-Warehouse and a few developers' sites which offer direct downloads...
                                  • 7 / 7
