    [Plugin] Lines to tubes
    131 Posts 61 Posters 304.4k Views 61 Watching
    • ntxdaveN Offline
      ntxdave
      One thing that does not work correctly for me is the Materials parameter. It will only allow me to select a material that has already been used in the model.
      Maybe I am doing something wrong................
      Press F1...thank me later
        To give you access to the potentially thousands of material SKM files that are not currently used in the model could be unbelievably complex, even it it were easy to do in the API - which unfortunately it is not...
        To be frank having any material choice seems overkill, as it is really a a geometry creator ?
        • sdmitchS Offline
          sdmitch
          @josephkim626 said:
          Indeed it behaves funny when it is run on rectangles.
          But it seems fine for some others.
          Fixed the problem with rectangles in my Edge_to_Tube plugin. Normal rectangles are bounded by 4 edges and not a 'curve' as polygons and circles are.
          http://sdmitch.blogspot.com/
            Excellent! πŸ‘
            And can we imagine the same with any section ?
              rv1974
              My $0.02:
              1. Fredo's Make curves (weld)
              2. S4u 'Make Frame'
                Yes but quid of differents number of segments of sections ? πŸ˜‰
                @Sdmitch
                Seems the "Do Curve" don't works in the new version!
                Edit: Sorry I don't draw a polygon but a rectangle! 😳
                The trick is draw a poly with 4 edges then resize with FredoScale! πŸ˜„
                • fionmacoolF Offline
                  fionmacool
                  Merci pour le Plugin. : )
                  Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
                  • H Offline
                    huajiet
                    @sdmitch said:
                    Yes, but this particular plugin is scrambled so only the creator can make that change.
                    I'm hoping to set the default 'Precision' input at 20. looked into the .rb file but it's all scrambled. anyone can help?
                    sdmitch, where can I download your Edge_to_Tube plugin?
                      Munene
                      How do you download the extension
                      • Didier BurD Offline
                        Didier Bur
                        Go to the Resources tab and select the PluginStore option.
                        Regards
                        DB
                          samodelkin_77
                          @huajiet said:
                          look at this plugin:
                          https://transfiles.ru/lwtkd
                            samodelkin_77
                            and how to insert images when responding? I didn't find where to click.press. I had to upload it to a file sharing service..
                              You didn't find the part of the Reply page shown in the red box, below?
                              Click on Choose File, select the file on your computer, click Add the file.
                                samodelkin_77
                                And I was looking at the top and side)) and it wasn't even visible below... it didn't fit into the screen)) thanks.
                                And I threw this picture on the file sharing site, maybe this plugin (1001) will help with pipes...
                                • massimoM massimo referenced this topic on
                                  Mahasamaritan Newcomers @Chris Fullmer
                                  @Chris-Fullmer said in [Plugin] Lines to tubes:
                                  It was listed just fine for me on Vista 64bit in the tools menu. Great plugin!
                                  Here's a helix, triple helix, double helix, something that isn't a helix, but sort of close, then another 10x helix or something. I'm sure most of those names are wrong, so just look at the picture πŸ˜„
                                  How can you make Lines to Tubes work in Sketchup 2014?
                                    Dave R @Mahasamaritan
                                    @Mahasamaritan said in [Plugin] Lines to tubes:
                                    Just install it using the Sketchucation ExtensionStore tool, select the edges and then run it. It works just fine in older SketchUps.
                                      mleslieperez Newcomers
                                      Mine is saying "unsigned" so it isn't able to install on my sketchup... can you help me fix this?
                                        Being 'unsigned' need not be a problem.
                                        Edit your native Extension Manager settings - Loading Policy > Unrestricted
                                        Restart SketchUp and version-compatible, but 'unsigned', extensions [i.e. usually older] will then load OK.
                                        Only install extensions from trustworthy sources - like SketchUcation, the Extension-Warehouse and a few developers' sites which offer direct downloads...
                                        • 7 / 7
