    [Plugin] Lines to tubes
    131 Posts 61 Posters 307.7k Views 61 Watching
      Does it possible to modify the plugin
      for have a rotation input?
      Now we have this!
      As you remark there is an Up Orientation!
      Wanted! πŸ€“
      • josephkim626J Offline
        josephkim626
        Now we have this!
        [attachment=1:1rui9dug]<!-- ia1 -->GIF_tube.gif<!-- ia1 -->[/attachment:1rui9dug]
        Wanted! πŸ€“
        [attachment=0:1rui9dug]<!-- ia0 -->squares_w.jpg<!-- ia0 -->[/attachment:1rui9dug]
        Sdmitch has his own plugin that does what you are describing.
        http://sdmitch.blogspot.co.uk/
        find "Edge To Tube"
          josephkim626
          @pilou said:
          Seems bugged! πŸ˜‰
          Or works only for curves ?
          Seems working only from polys of 5 segments! πŸ˜‰
          [attachment=1:17is50ip]<!-- ia1 -->GIF_bugged.gif<!-- ia1 -->[/attachment:17is50ip]
          Indeed it behaves funny when it is run on rectangles.
          But it seems fine for some others.
          [attachment=0:17is50ip]<!-- ia0 -->tube.gif<!-- ia0 -->[/attachment:17is50ip]
            Seems bugged! πŸ˜‰
              The "Do curve" is somptuous! πŸ‘
              (not my video πŸ’š
              (currioussly don't works for the rectangles! 😲
              Bravo to Sdmitch! 😎
              Ps Will be very fine for any "section" πŸ˜‰
              • ntxdaveN Offline
                ntxdave
                One thing that does not work correctly for me is the Materials parameter. It will only allow me to select a material that has already been used in the model.
                Maybe I am doing something wrong................
                Press F1...thank me later
                  To give you access to the potentially thousands of material SKM files that are not currently used in the model could be unbelievably complex, even it it were easy to do in the API - which unfortunately it is not...
                  To be frank having any material choice seems overkill, as it is really a a geometry creator ?
                  • sdmitchS Offline
                    sdmitch
                    Fixed the problem with rectangles in my Edge_to_Tube plugin. Normal rectangles are bounded by 4 edges and not a 'curve' as polygons and circles are.
                    http://sdmitch.blogspot.com/
                      Excellent! πŸ‘
                      And can we imagine the same with any section ?
                        rv1974
                        My $0.02:
                        1. Fredo's Make curves (weld)
                        2. S4u 'Make Frame'
                          Yes but quid of differents number of segments of sections ? πŸ˜‰
                          @Sdmitch
                          Seems the "Do Curve" don't works in the new version!
                          Edit: Sorry I don't draw a polygon but a rectangle! 😳
                          The trick is draw a poly with 4 edges then resize with FredoScale! πŸ˜„
                          • fionmacoolF Offline
                            fionmacool
                            Merci pour le Plugin. : )
                            Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
                            • H Offline
                              huajiet
                              @sdmitch said:
                              Yes, but this particular plugin is scrambled so only the creator can make that change.
                              I'm hoping to set the default 'Precision' input at 20. looked into the .rb file but it's all scrambled. anyone can help?
                              sdmitch, where can I download your Edge_to_Tube plugin?
                                Munene
                                How do you download the extension
                                • Didier BurD Offline
                                  Didier Bur
                                  Go to the Resources tab and select the PluginStore option.
                                  Regards
                                  DB
                                    samodelkin_77
                                    @huajiet said:
                                    look at this plugin:
                                    https://transfiles.ru/lwtkd
                                      samodelkin_77
                                      and how to insert images when responding? I didn't find where to click.press. I had to upload it to a file sharing service..
                                        You didn't find the part of the Reply page shown in the red box, below?
                                        Click on Choose File, select the file on your computer, click Add the file.
                                          samodelkin_77
                                          And I was looking at the top and side)) and it wasn't even visible below... it didn't fit into the screen)) thanks.
                                          And I threw this picture on the file sharing site, maybe this plugin (1001) will help with pipes...
                                          • massimoM massimo referenced this topic on
                                            Mahasamaritan Newcomers @Chris Fullmer
                                            @Chris-Fullmer said in [Plugin] Lines to tubes:
                                            It was listed just fine for me on Vista 64bit in the tools menu. Great plugin!
                                            Here's a helix, triple helix, double helix, something that isn't a helix, but sort of close, then another 10x helix or something. I'm sure most of those names are wrong, so just look at the picture πŸ˜„
                                            How can you make Lines to Tubes work in Sketchup 2014?
                                            • 6 / 7
