    Terrain-related plugin I cannot remember!
    17 Posts 9 Posters 3.0k Views 9 Watching
      Yes quasi all plugins by Fredo are "standalone program" inside SU by themselves! πŸ˜‰
      • Collage ArchitectureC Offline
        Selection toy(only border edges) and Vertex tool can add skirt too
        δ»Žζˆ‘ηš„ iPhone ε‘ι€οΌŒδ½Ώη”¨ Tapatalk
        I love Sketchup
        • EdsonE Offline
          Edson
          what you are suggesting is that I select only the border edges and then extrude them to form a skirt, right?
          and how would you do it with Vertex Tools?
          http://www.mahfuz.arq.br
          • pbacotP Offline
            I think vertex tools does this with the (+) action of the modifier key (option on Mac) when moving with the gizmo. However I think it leaves the vertices in the same relative positions--not flat. I would do with Extrude tools---extrude edges to face (or whatever it's called) for a similar sort of tool. That way all the faces formed should end up on the same plane.
              Yes, and don't be afraid that it is not flat. You could then scale your vertices to 0, it will be flat after scaling.
              I love Sketchup
                rv1974
                VT don't scale to 0 precisely
                • panixiaP Offline
                  panixia
                  you can scale at any random size with the vertex tools gizmo and then input 0 in the vcb and hit return.. and they will be 100% flat
                    It's a pity that you can't input value via VCB, but you can make it , just cumbersome
                    I love Sketchup
                    • panixiaP Offline
                      panixia
                      you can actually do this, as demonstrated in this video i did.. take a look at about 11.30/12.30 πŸ‘
                        oops, I should definitely try it.Thanks for your Info!
                        I love Sketchup
