    Terrain-related plugin I cannot remember!
    17 Posts 9 Posters 2.7k Views 9 Watching
    • EdsonE Offline
      Edson
      I cannot remember which plugin can be used to build a base for a terrain. It turns the terrain into a box, so to speak, in which the top part is the terrain proper.
      Does anyone out there remember which one does that?
      Thanks.
      http://www.mahfuz.arq.br
      • TIGT Online
        My CutNFill has an 'add skirt' option.
        Sdmitch has a separate one too - available from the PluginStore - http://sketchucation.com/pluginstore?pln=Add_Terrain_Skirt
          Also Fredo's Toposhaper adds Skirts or Sdmitch Skirt tool
          • EdsonE Offline
            Edson
            thanks, Rich and Tig. I managed to it with Add Skirt but will try as well with TopoShaper.
            • jujuJ Offline
              juju
              Eneroth also has the Terrain Volume extension that will add a skirt to the terrain.
                Joint Push Pull can do that also! πŸ˜„
                With any reasonable surfaces! Any number and nature of sides! πŸ€“
                • pbacotP Offline
                  Never tried JPP that way Pilou. Clever plugin. Fredos tools seem to work out all possible ramifications of a concept!
                    Yes quasi all plugins by Fredo are "standalone program" inside SU by themselves! πŸ˜‰
                    • Collage ArchitectureC Offline
                      Selection toy(only border edges) and Vertex tool can add skirt too
                      δ»Žζˆ‘ηš„ iPhone ε‘ι€οΌŒδ½Ώη”¨ Tapatalk
                      I love Sketchup
                      • EdsonE Offline
                        Edson
                        what you are suggesting is that I select only the border edges and then extrude them to form a skirt, right?
                        and how would you do it with Vertex Tools?
                        • pbacotP Offline
                          I think vertex tools does this with the (+) action of the modifier key (option on Mac) when moving with the gizmo. However I think it leaves the vertices in the same relative positions--not flat. I would do with Extrude tools---extrude edges to face (or whatever it's called) for a similar sort of tool. That way all the faces formed should end up on the same plane.
                            Yes, and don't be afraid that it is not flat. You could then scale your vertices to 0, it will be flat after scaling.
                            I love Sketchup
                              rv1974
                              VT don't scale to 0 precisely
                              • panixiaP Offline
                                panixia
                                you can scale at any random size with the vertex tools gizmo and then input 0 in the vcb and hit return.. and they will be 100% flat
                                  It's a pity that you can't input value via VCB, but you can make it , just cumbersome
                                  I love Sketchup
                                  • panixiaP Offline
                                    panixia
                                    you can actually do this, as demonstrated in this video i did.. take a look at about 11.30/12.30 πŸ‘
                                      oops, I should definitely try it.Thanks for your Info!
                                      I love Sketchup
