    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 271.7k Views 135 Watching
    • Rich O BrienR Online
      @jiminy-billy-bob said:
      Are you bringing these to the Basecamp? ๐Ÿ˜„
      Who said that?
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        Nobody, I'm just wondering
          I'm not bringing them. But they could be there.
            jiminy-billy-bob
            You're not coming?
            • sfto1S Offline
              sfto1
              I like to place section planes at specific locations. So, when I learned that if I hold down CTRL before clicking to locate section plane, it will stick to the face it is near. Then I move the plane using the move tool relative to that face. Duh or D'oh, I don't know, but I like it.
              • E Offline
                Ecuadorian
                Hey, everyone! I just downloaded the book. Thank you for the good memories! ๐Ÿ˜ƒ
                -Miguel Lescano
                • GarethG Offline
                  Gareth
                  Great book....love it....!!
                  Well done.
                  • genki.ttG Offline
                    genki.tt
                    I found a small miss type on The D'oh! Book P61(ver.1.0) P63(ver.1.1)
                    [20mm, 10mm, 30mm] absolute move -> <20mm, 10mm, 30mm> relative move
                    By the way I could find Doh about Array Command, we can change operation 'x' to '/' with using 'x1' , or we can change '/' to 'x' with using '/1'.
                    copy(move + 'alt') some object and type VCB
                    <1000,,>
                    x4
                    10000
                    x1
                    /4
                    20000
                    /1
                    <1000, 1000, 1000>
                    x10
                    .... we can continue 'x', '/', distance value, relative vertics, absolute vertics.
                    'x1' or '/1' is important.
                    Thank you for GREAT BOOK!!
                      Doh of the day! Surely trivial but never remarked! ๐Ÿ’š
                      Saving a file with objects who are not Components and Groups
                      New File
                      Import this file : it's converted in a Component! ๐Ÿ˜ฎ
                        New File
                        And if you create a component and save it using File>Save as... and then import it, it'll be double wrapped.
                          And Making a Component creates a new context menu on the Right Click Menu!
                          "Save As" (+ "Reload" + "Detach")
                          So more speed than the menu "File Save as" ! ๐Ÿ˜‰
                          • E Offline
                            Ecuadorian
                            I've just spent one hour asking myself why I could not copy-paste from an old SKP file to a new SKP file with a newly imported AutoCAD drawing. I run SketchUp's checkup, GPU-Z, Repaired SketchUp, reinstalled SketchUp... Nothing. Until I remembered these guys send me the AutoCAD drawings in milimeters instead of meters, but I imported it as meters... So the new drawing was gigantic and anything I copy-pasted from the old file was just too tiny to be seen.
                            -Miguel Lescano
                              Why not use the "Zoom Extended" in a new file ? ๐Ÿ˜ฎ ๐Ÿ˜„
                                rv1974
                                Today Penny has Dropped:
                                XnView is way better BP2 library explorer then a built-in one.
                                As well I use XnView as Component explorer for years now. Excellent with 2nd disply + drag'n'drop.
                                  Sleipnir
                                  New to this program, looking for a good extension for cabinet building and or wood working draw up.
                                  Odin's Favorite Eight Legged Horse'
                                    Super Doh of the day! Thanks Dave! ๐Ÿ‘
                                    The arc Circle "Knife"! Make a Double Click at the end of the Arc Drawing! ๐Ÿค“
                                    Excellent! ๐Ÿ˜Ž โ˜€
                                    Never made the Double Click! (just simple click: as it was not writed on the bottom help line! ๐Ÿ˜ณ
                                    And I surrely missed it on the manual! ๐Ÿ˜ณ
                                    Animation by Dave
                                    https://sketchucation.com/forums/download/file.php?id=148790&mode=view/rokbox.jpg
                                      You probably missed this, too. If you want to place the same radius on other corners, double click near them.
                                      Click on pic if it doesn't move.
                                        Very cool! โ˜€ ๐Ÿ‘
                                        I suppose I am not the only one! ๐Ÿ’š
                                          kaas
                                          I don't know if this is a new feature but I was pleasantly surprised to learn about it:
                                          In the 3dWarehouse, select a model, look at the statistics in the panel on the right, if you hover / click on a tag (materials/components) you can import just one of those elements instead of the whole model.
                                          Great feature if you just need 1 material of 1 element from a collection.
                                          • boofredlayB Offline
                                            boofredlay
                                            https://media.giphy.com/media/EldfH1VJdbrwY/giphy.gif
                                            • 34
                                            • 35
                                            • 3 / 35
