    [Plugin] QuadFaceTools
    673 Posts 116 Posters 524.6k Views 116 Watching
      Doesn't have to be a clash. The offset tool is a recent one that was more of an experiment. I had it hidden for a while but people insisted it should be visible by default. But it will have some problems still. I have an open issue to improve or rewrite it.
      That being said - I wasn't able to reproduce your exact scenario. Can you share the model please?
      Also, what version of the extension do you have?
        kaas
        I'm using
        QFC 0.12.0
        TTlib 2.10.6
        I attached a file. The shape doesn't really matter though - sometimes it crashes on me on a simple box...
        Edit 10-10-2016: just cleaned my plugin directory. Installed TT_lib2, QFT, Selectiontoys and tested again. Same crashes so I would suspect no clashing plugins.
        qft_oops.skp
          Hmm.... I cannot reproduce on this one either. Can you do a video capture to show your steps?
            kaas
            Here you go - shocking isn't it? I'm thinking I'm wasting your time. There must be something wrong at my end. Although it is strange; only TTlib2, QFT, Selection toys installed (all fresh from SketchUcation tools & TTlib2 from Extension warehouse). SU-pro 16.1.1449 64 bit.
            Edit + pic: it also crashes after adding a few loops and at some point it doesn't detect the loop anymore (blue line) and...ooops
            qft_oops.avi
              Hmm... have you submitted the reports? Did you include your name/email other info?
              Also, what version of Internet Explorer do you have installed? The error reporting dialog looks odd.
                kaas
                I have submitted only a very few (user name Max). Sometimes it caused an oops-loop and I didn't report those either.
                I'm running win7 x64 on my desktop with IE11.0.9600.18449
                  I see the issue now. It's when you offset only one edge.
                  https://bitbucket.org/thomthom/quadface-tools/issues/103/offsetloop-errors-when-selecting-only-one
                  I also noticed another issue, if you pick an edge at the end of your selection the offset is missing an edge.
                  https://bitbucket.org/thomthom/quadface-tools/issues/104/offsetloop-missing-edges
                    kaas
                    .. I also noticed another issue, if you pick an edge at the end of your selection the offset is missing an edge...
                    Both true. Glad you could reproduce the issue. I'm a bit confused nobody has noticed this before. The offset tool itself could be quite useful.
                      As it is now, consider the OffsetTool an alpha-version. I would not have exposed it yet had it not been for being persistently nagged to do so. πŸ˜‰
                      • HornOxxH Offline
                        HornOxx
                        Hi All
                        I just nee a little help how to install the current QuadFace tools correctly, to get
                        access to this cool live mesh analysis feature.
                        I always get the error message (shown below) when I activate live mesh analysis.
                        I also installed the current tt LibΒ².
                        IΒ΄m trying to run Quadface tools within my SU 2015 Make which is my prefered Quad-version
                        with tools like SubD, Vertex tools etc...
                        I appreciate any help - Thanks
                        never trust a skinny cook
                          Ah, sorry - bad user feedback on my end. The error is due to the functionality being SU2016+ only.
                          • O Offline
                            optimaforever
                            Hello Thomas,
                            Perhaps has it been asked before, but is there a way to tweak the bydefault colors for the analysis tool? Not that I don't understand your wise choice of colors, but I'd prefer more contrasted colors like white-red...
                            And I agree, it's a pity one can't replace a default sketchUp view mode (like monochrome or x-ray that I don't use often) with this analyse view mode, to keep the textures/UVW mapping.
                            Otherwise, good job! πŸ‘
                              No color options as of yet. But it's something I wanted to add. The current version was a quick and dirty tool - turns out to be more useful than expected.
                              • eneroth3E Offline
                                eneroth3
                                I've just discovered the UV Mapping Tool in this plugin and it's so incredible useful. Not finding it earlier is definitely a Doh Moment for me. I'm a quad fan now! πŸ˜›
                                My website: http://julia-christina-eneroth.se/
                                  whohoo! πŸ˜„
                                    cmoreink
                                    How do you import an .obj file?
                                    It crashes every time I try ---> file, import, select .obj file "oops, an error occurred 😞" a message displays (box) askes me if I want to send a report.
                                    The tool bar displays ok
                                    Any idea why?
                                    my portfolio
                                    • jo-keJ Offline
                                      jo-ke
                                      I would like to use this plugin to texture a curtain.
                                      3D Warehouse
                                      (3dwarehouse.sketchup.com)
                                      I tried to convert the mesh but it doesn't work.
                                      What did I wrong?
                                      same with that one:
                                      3D Warehouse
                                      http://www.zz7.de
                                      • jo-keJ Offline
                                        jo-ke
                                        I really don't know how to convert the mesh, to let the texturing tool work.
                                        anybody has got an idea?
                                        http://www.zz7.de
                                          alamin
                                          any pdf manual?
                                          • BoxB Offline
                                            Thomthom, any chance of adding a selection option where you can step the ring/loop selected?
                                            So, instead of adding or subtracting, each click moves the selection one loop over and deselects the one you are on.
                                            Edit: I'll just add this gif to help explain what I mean,I have a workaround but it would be helpful to have.
                                            • 33
                                            • 34
                                            • 8 / 34
