    [Plugin] QuadFaceTools
    680 Posts 116 Posters 771.9k Views 116 Watching
      Got a sample model? Screenshot?
      • K
        kaas
        Just a simple box and there we go again. If nobody else has problems I guess its a clash with other plugins. I will try to do a clean install for all my plugins soon.
          Doesn't have to be a clash. The offset tool is a recent one that was more of an experiment. I had it hidden for a while but people insisted it should be visible by default. But it will have some problems still. I have an open issue to improve or rewrite it.
          That being said - I wasn't able to reproduce your exact scenario. Can you share the model please?
          Also, what version of the extension do you have?
          • K
            kaas
            I'm using
            QFC 0.12.0
            TTlib 2.10.6
            I attached a file. The shape doesn't really matter though - sometimes it crashes on me on a simple box...
            Edit 10-10-2016: just cleaned my plugin directory. Installed TT_lib2, QFT, Selectiontoys and tested again. Same crashes so I would suspect no clashing plugins.
            qft_oops.skp
              Hmm.... I cannot reproduce on this one either. Can you do a video capture to show your steps?
              • K
                kaas
                Here you go - shocking isn't it? I'm thinking I'm wasting your time. There must be something wrong at my end. Although it is strange; only TTlib2, QFT, Selection toys installed (all fresh from SketchUcation tools & TTlib2 from Extension warehouse). SU-pro 16.1.1449 64 bit.
                Edit + pic: it also crashes after adding a few loops and at some point it doesn't detect the loop anymore (blue line) and...ooops
                qft_oops.avi
                  Hmm... have you submitted the reports? Did you include your name/email other info?
                  Also, what version of Internet Explorer do you have installed? The error reporting dialog looks odd.
                  • K
                    kaas
                    I have submitted only a very few (user name Max). Sometimes it caused an oops-loop and I didn't report those either.
                    I'm running win7 x64 on my desktop with IE11.0.9600.18449
                      I see the issue now. It's when you offset only one edge.
                      https://bitbucket.org/thomthom/quadface-tools/issues/103/offsetloop-errors-when-selecting-only-one
                      I also noticed another issue, if you pick an edge at the end of your selection the offset is missing an edge.
                      https://bitbucket.org/thomthom/quadface-tools/issues/104/offsetloop-missing-edges
                      • K
                        kaas
                        .. I also noticed another issue, if you pick an edge at the end of your selection the offset is missing an edge...
                        Both true. Glad you could reproduce the issue. I'm a bit confused nobody has noticed this before. The offset tool itself could be quite useful.
                          As it is now, consider the OffsetTool an alpha-version. I would not have exposed it yet had it not been for being persistently nagged to do so. 😉
                          • HornOxxH
                            HornOxx
                            Hi All
                            I just nee a little help how to install the current QuadFace tools correctly, to get
                            access to this cool live mesh analysis feature.
                            I always get the error message (shown below) when I activate live mesh analysis.
                            I also installed the current tt Lib².
                            I´m trying to run Quadface tools within my SU 2015 Make which is my prefered Quad-version
                            with tools like SubD, Vertex tools etc...
                            I appreciate any help - Thanks
                            never trust a skinny cook
                              Ah, sorry - bad user feedback on my end. The error is due to the functionality being SU2016+ only.
                              • O
                                optimaforever
                                Hello Thomas,
                                Perhaps has it been asked before, but is there a way to tweak the bydefault colors for the analysis tool? Not that I don't understand your wise choice of colors, but I'd prefer more contrasted colors like white-red...
                                And I agree, it's a pity one can't replace a default sketchUp view mode (like monochrome or x-ray that I don't use often) with this analyse view mode, to keep the textures/UVW mapping.
                                Otherwise, good job! 👍
                                  No color options as of yet. But it's something I wanted to add. The current version was a quick and dirty tool - turns out to be more useful than expected.
                                  • eneroth3E
                                    eneroth3
                                    I've just discovered the UV Mapping Tool in this plugin and it's so incredible useful. Not finding it earlier is definitely a Doh Moment for me. I'm a quad fan now! 😛
                                    My website: http://julia-christina-eneroth.se/
                                      whohoo! 😄
                                      • C
                                        cmoreink
                                        How do you import an .obj file?
                                        It crashes every time I try ---> file, import, select .obj file "oops, an error occurred 😞" a message displays (box) askes me if I want to send a report.
                                        The tool bar displays ok
                                        Any idea why?
                                        my portfolio
                                        • jo-keJ
                                          jo-ke
                                          I would like to use this plugin to texture a curtain.
                                          3D Warehouse
                                          (3dwarehouse.sketchup.com)
                                          I tried to convert the mesh but it doesn't work.
                                          What did I wrong?
                                          same with that one:
                                          3D Warehouse
                                          http://www.zz7.de
                                          • jo-keJ
                                            jo-ke
                                            I really don't know how to convert the mesh, to let the texturing tool work.
                                            anybody has got an idea?
                                            http://www.zz7.de
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 33
                                            • 34
                                            • 26 / 34
