    [Plugin] QuadFaceTools
    680 Posts 116 Posters 745.0k Views 116 Watching
    • C
      Carto
      Hello ThomThom,
      Thank you for looking at this. I was just converting from metric to standard, but it would be convenient if you could enter the actual model units. Thanks again for a great plugin.
      Regards
        Version 0.12.0
        • Made OBJ importer create groups from OBJ groups.
        • Made OBJ importer correct SketchUp's "auto-orientation" of faces which was some times confused by internal faces.
          Version 0.12.0 was made to allow OBJs exported using Mineways read properly in SketchUp:
          http://www.realtimerendering.com/erich/minecraft/public/mineways/
          • eneroth3E
            eneroth3
            This is my home in minecraft πŸ˜„ . This really works and it's amazing! Some manual labor was needed to clean up the edges between blocks but that's fine, the plugin does a great job!
            3D Warehouse
            (3dwarehouse.sketchup.com)
            My website: http://julia-christina-eneroth.se/
            • K
              kaas
              Anyone uses OffsetLoop? Whats the best way to use it? I'm getting mostly crashes / bugreport Oops-loops with 0.12.
                Got a sample model? Screenshot?
                • K
                  kaas
                  Just a simple box and there we go again. If nobody else has problems I guess its a clash with other plugins. I will try to do a clean install for all my plugins soon.
                    Doesn't have to be a clash. The offset tool is a recent one that was more of an experiment. I had it hidden for a while but people insisted it should be visible by default. But it will have some problems still. I have an open issue to improve or rewrite it.
                    That being said - I wasn't able to reproduce your exact scenario. Can you share the model please?
                    Also, what version of the extension do you have?
                    • K
                      kaas
                      I'm using
                      QFC 0.12.0
                      TTlib 2.10.6
                      I attached a file. The shape doesn't really matter though - sometimes it crashes on me on a simple box...
                      Edit 10-10-2016: just cleaned my plugin directory. Installed TT_lib2, QFT, Selectiontoys and tested again. Same crashes so I would suspect no clashing plugins.
                      qft_oops.skp
                        Hmm.... I cannot reproduce on this one either. Can you do a video capture to show your steps?
                        • K
                          kaas
                          Here you go - shocking isn't it? I'm thinking I'm wasting your time. There must be something wrong at my end. Although it is strange; only TTlib2, QFT, Selection toys installed (all fresh from SketchUcation tools & TTlib2 from Extension warehouse). SU-pro 16.1.1449 64 bit.
                          Edit + pic: it also crashes after adding a few loops and at some point it doesn't detect the loop anymore (blue line) and...ooops
                          qft_oops.avi
                            Hmm... have you submitted the reports? Did you include your name/email other info?
                            Also, what version of Internet Explorer do you have installed? The error reporting dialog looks odd.
                            • K
                              kaas
                              I have submitted only a very few (user name Max). Sometimes it caused an oops-loop and I didn't report those either.
                              I'm running win7 x64 on my desktop with IE11.0.9600.18449
                                I see the issue now. It's when you offset only one edge.
                                https://bitbucket.org/thomthom/quadface-tools/issues/103/offsetloop-errors-when-selecting-only-one
                                I also noticed another issue, if you pick an edge at the end of your selection the offset is missing an edge.
                                https://bitbucket.org/thomthom/quadface-tools/issues/104/offsetloop-missing-edges
                                • K
                                  kaas
                                  .. I also noticed another issue, if you pick an edge at the end of your selection the offset is missing an edge...
                                  Both true. Glad you could reproduce the issue. I'm a bit confused nobody has noticed this before. The offset tool itself could be quite useful.
                                    As it is now, consider the OffsetTool an alpha-version. I would not have exposed it yet had it not been for being persistently nagged to do so. πŸ˜‰
                                    • HornOxxH
                                      HornOxx
                                      Hi All
                                      I just nee a little help how to install the current QuadFace tools correctly, to get
                                      access to this cool live mesh analysis feature.
                                      I always get the error message (shown below) when I activate live mesh analysis.
                                      I also installed the current tt LibΒ².
                                      IΒ΄m trying to run Quadface tools within my SU 2015 Make which is my prefered Quad-version
                                      with tools like SubD, Vertex tools etc...
                                      I appreciate any help - Thanks
                                      never trust a skinny cook
                                        Ah, sorry - bad user feedback on my end. The error is due to the functionality being SU2016+ only.
                                        • O
                                          optimaforever
                                          Hello Thomas,
                                          Perhaps has it been asked before, but is there a way to tweak the bydefault colors for the analysis tool? Not that I don't understand your wise choice of colors, but I'd prefer more contrasted colors like white-red...
                                          And I agree, it's a pity one can't replace a default sketchUp view mode (like monochrome or x-ray that I don't use often) with this analyse view mode, to keep the textures/UVW mapping.
                                          Otherwise, good job! πŸ‘
                                            No color options as of yet. But it's something I wanted to add. The current version was a quick and dirty tool - turns out to be more useful than expected.
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 33
                                            • 34
                                            • 26 / 34
