    [Plugin] QuadFaceTools
    680 Posts 116 Posters 699.7k Views 116 Watching
      Hmm... have you submitted the reports? Did you include your name/email other info?
      Also, what version of Internet Explorer do you have installed? The error reporting dialog looks odd.
        kaas
        I have submitted only a very few (user name Max). Sometimes it caused an oops-loop and I didn't report those either.
        I'm running win7 x64 on my desktop with IE11.0.9600.18449
          I see the issue now. It's when you offset only one edge.
          https://bitbucket.org/thomthom/quadface-tools/issues/103/offsetloop-errors-when-selecting-only-one
          I also noticed another issue, if you pick an edge at the end of your selection the offset is missing an edge.
          https://bitbucket.org/thomthom/quadface-tools/issues/104/offsetloop-missing-edges
            kaas
            .. I also noticed another issue, if you pick an edge at the end of your selection the offset is missing an edge...
            Both true. Glad you could reproduce the issue. I'm a bit confused nobody has noticed this before. The offset tool itself could be quite useful.
              As it is now, consider the OffsetTool an alpha-version. I would not have exposed it yet had it not been for being persistently nagged to do so. πŸ˜‰
              • HornOxxH Offline
                HornOxx
                Hi All
                I just nee a little help how to install the current QuadFace tools correctly, to get
                access to this cool live mesh analysis feature.
                I always get the error message (shown below) when I activate live mesh analysis.
                I also installed the current tt LibΒ².
                IΒ΄m trying to run Quadface tools within my SU 2015 Make which is my prefered Quad-version
                with tools like SubD, Vertex tools etc...
                I appreciate any help - Thanks
                never trust a skinny cook
                  Ah, sorry - bad user feedback on my end. The error is due to the functionality being SU2016+ only.
                  • O Offline
                    optimaforever
                    Hello Thomas,
                    Perhaps has it been asked before, but is there a way to tweak the bydefault colors for the analysis tool? Not that I don't understand your wise choice of colors, but I'd prefer more contrasted colors like white-red...
                    And I agree, it's a pity one can't replace a default sketchUp view mode (like monochrome or x-ray that I don't use often) with this analyse view mode, to keep the textures/UVW mapping.
                    Otherwise, good job! πŸ‘
                      No color options as of yet. But it's something I wanted to add. The current version was a quick and dirty tool - turns out to be more useful than expected.
                      • eneroth3E Offline
                        eneroth3
                        I've just discovered the UV Mapping Tool in this plugin and it's so incredible useful. Not finding it earlier is definitely a Doh Moment for me. I'm a quad fan now! πŸ˜›
                        My website: http://julia-christina-eneroth.se/
                          whohoo! πŸ˜„
                            cmoreink
                            How do you import an .obj file?
                            It crashes every time I try ---> file, import, select .obj file "oops, an error occurred 😞" a message displays (box) askes me if I want to send a report.
                            The tool bar displays ok
                            Any idea why?
                            my portfolio
                            • jo-keJ Offline
                              jo-ke
                              I would like to use this plugin to texture a curtain.
                              https://3dwarehouse.sketchup.com/model.html?id=uc7753be5-41c8-4ae0-9ef3-9ce42ea057c5
                              I tried to convert the mesh but it doesn't work.
                              What did I wrong?
                              same with that one:
                              https://3dwarehouse.sketchup.com/model.html?id=5d7792a4d1a7256b9c852951a521b687
                              http://www.zz7.de
                              • jo-keJ Offline
                                jo-ke
                                I really don't know how to convert the mesh, to let the texturing tool work.
                                anybody has got an idea?
                                http://www.zz7.de
                                  alamin
                                  any pdf manual?
                                  • BoxB Offline
                                    Thomthom, any chance of adding a selection option where you can step the ring/loop selected?
                                    So, instead of adding or subtracting, each click moves the selection one loop over and deselects the one you are on.
                                    Edit: I'll just add this gif to help explain what I mean,I have a workaround but it would be helpful to have.
                                      No French UI version ❓
                                        Any idea why?
                                        Can you share this obj file please? (You can PM me if you don't want to share the file publicly)
                                          That's a good idea. Logged it in the issue tracker: https://bitbucket.org/thomthom/quadface-tools/issues/107/shift-loop
                                            No. ...not yet that is... I just set up a Crowdin project for this extension. πŸ˜‰
                                            But give me some time to localise SUbD and move to my new home. πŸ˜„
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 33
                                            • 34
                                            • 26 / 34
