    [Plugin] Recall last tool v1.2
    60 Posts 28 Posters 65.3k Views 28 Watching
      Matt666
      Sorry, I don't know how to create a personal observer for controlling mouse events...
      Frenglish at its best !
      My scripts
        Pherim
        Neat, I didn't know this yet. Great timesaver when switching to select tool to return to the previously used tool.
          mirale999
          Merci Matt! Great plugin~
          By the way, I come up with an idea, I think maybe it's useful!
          I use the shortcut“shift+Y” to recall the last tool. When I use this plugin, a situation like this will happen:
          first I use the "Edge follow me" tool to build a face,
          then I move it to another place, and use move and scale to modify the curves,
          then I want to do "Edge follow me" again
          so the idea comes:------this tool have a function: ignore the move, scale, rotate, line, arc, rectangle, circle...(because they are so useful and they have shortcuts), but recall edge follow me, blend, extrapolate colors...(you must find it in a submenu).
          On my bad English... hope you get my meaning... ☀
          paranoia is a higher form of awareness...
            Matt666
            Hi mirale999!
            So you want RLT ignores some native tools you would be able to choose? Do you agree with this "way of explanation" (I dont know how to tell it in english 😳 )?
            I don't know if it's possible... But I can try.
            My scripts
              jdtsmith
              Just an FYI for any Mac users. Pecan's version above with the "exceptions" list works fine for me in SU 8.0. I use it with BetterTouchTool and a Magic Trackpad:
              • Three Finger TipTap Left: Orbit (O)
              • 3 Finger Tip Tap Right: Recall Last Tool (which I have as F2)
              • Pinch Out: Zoom Extents (I have as Shift-Z)
              This plugin, with Lion's native three finger dragging make using SU with the trackpad much more enjoyable. Here's how I use it:
              • Two finger "scroll": zooms in and out
              • 3 Finger move: same as click and drag for selection
              • Tip Tap Left (drop two fingers and tap another to the left): switch to orbit tool
              • Tip Tap Right: switch back to whichever tool I'm in the middle of using
              • Get Lost? Pinch to Zoom Out
              Thanks to the plugin's authors!
                alex_picas
                Hi Matt. Recall command of autocad is good too. Can you do other 'last tool recall' version like autocad with using only a space bar? Thanks Matt.
                • O Offline
                  Omaha
                  In this case, I want to say that for sure, Thank you. You saved the day.
                    Pherim
                    Makes SU Make 2017 (Windows) crash.
                    • CadFatherC Offline
                      CadFather
                      mmm... works fine with me - is it wrapped in a module?
                      require 'sketchup.rb'
                      module MATT_Recall
                      class Matt_Observer < Sketchup;;ToolsObserver
                      	@@Matt_Model_Toolid = nil
                      	@@Matt_Model_Toolid2 = nil
                      	def onActiveToolChanged (tools_object, toolname, toolid)
                      		@@Matt_Model_Toolid = @@Matt_Model_Toolid2 if @@Matt_Model_Toolid2
                      		@@Matt_Model_Toolid2 = toolid if not([10508].index toolid)
                      	def self.recall_last
                      			return Sketchup.send_action(@@Matt_Model_Toolid)
                      		else
                      			puts "No tool used before."
                      			return Sketchup.send_action("selectSelectionTool;")
                      end  #class
                      Sketchup.active_model.tools.add_observer(Matt_Observer.new)
                      unless file_loaded?(__FILE__)
                         UI.menu('Edit').add_item("RECALL LAST TOOL"){ Matt_Observer.recall_last }
                      	file_loaded(__FILE__)
                      end#module
                        CadFather
                        just in case anyone else asks, the following is totally fine on my pc:
                        module MATT_Recall
                        	def onActiveToolChanged (tools, tool_name, tool_id)
                            puts "Tool Used; #{tool_name}"
                        		@@Matt_Model_Toolid2 = tool_id if not([10508].index tool_id)
                        		else
                        end  #class
                        end#module
                          Pherim
                          Using the one from the ExtensionStore... but no, it's not. Will try it out, thank you.
                          Edit: Still crashes on start. Well, it doesn't work with tools from plugins, anyway.
                            booglabird
                            Nice tool, but i wish it worked after panning or rotating, avoiding those inputs
                            • E Offline
                              Einstein
                              The RB file has a very strange name: "Recall_last_tool%5Bv1.2%5D.rb" and its installation caused a bugsplat in SU17. I changed RB name to "Recall_last_tool" and bugsplat didn't appear anymore 😄
                                Actually it shows up that way when you download it because Windows doesn't resolve the square brackets in file names. You could have edited the file name and removed %5B and %5D and been just fine.
                                • E Offline
                                  Einstein
                                  Hi!
                                  This plugin works well with native SU tools but causes serious problems when combined with plugins. For example: when I perform RotaScale (ThomThom), 3D Rotate (Eneroth) or Free rotate (TIG) and then try to Recall it, it leads to bugsplat.
                                  When I use Extrude Lines [D. Bur], then Recall Last Tool it just "omits" it and brings a native tool I used proviously.
                                  I'd really like to test it with more plugins and see what happens but it takes too long, with one bugsplat after another...
                                  • V Offline
                                    Vigy
                                    Please anyone or Matt666!!!
                                    I download this plug-in via sketchucation plug-in manager, right after downloading SU crashed on me, it won’t reopen again. I tried to restore SU but it didn’t help nether. Nor did I have a windows backup restored. 😢 😢 Can anyone PLEASE help me!
                                    SU18 pro User
                                    Tx in advance! Vigy!
                                      SU18 pro User
                                      This is a very old plugin...
                                      When you installed its RBZ it will have added a RB file into your Plugins folder.
                                      Looks like this is loading and breaking things.
                                      It's named something like:
                                      Open your Plugins folder and remove it...
                                      Then retry starting SketchUp...
                                      Your profile says you use v8 [but that is very old and I suspect it's out of date !], but if it is so then your Plugins folder is probably here:
                                      C:\Program Files\SketchUp\SketchUp 8\Plugins
                                      Otherwise if you have a newer version it's probably found here:
                                      C:\Users\YOUR_USER_NAME\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Plugins
                                      That AppData folder might be hidden by default, but pasting the full path in a Windows Explorer window's top-bar should open it, otherwise reset your Folder-Options to show hidden content...
                                      • jujuJ Offline
                                        juju
                                        Eneroth has a similar extension, not free though. SU2016 + only.
                                        Eneroth Tool Memory
                                        • V Offline
                                          Vigy
                                          Thanks so much TIG! yes I found it in the hidden folder, and works very well now.
                                          Juju I will check it out, Tx
                                          • Z Offline
                                            zhangruofei
                                            • 3 / 3
