    [Plugin] Recall last tool v1.2
    60 Posts 28 Posters 65.3k Views 28 Watching
    • juan974J Offline
      juan974
      Merci MATT ...
      juan974 (Réunion island)
      website : http://sketchucation.com/click.php?url=http://www.tarn.us
        bitsnbites
        Thank you very much, Matt666.
        That´s the Plugin i was lookin for.
        thx a lot
          Matt666
          I will try to find a solution.
          Frenglish at its best !
          My scripts
            Matt666
            Sorry, I don't know how to create a personal observer for controlling mouse events...
            My scripts
              Pherim
              Neat, I didn't know this yet. Great timesaver when switching to select tool to return to the previously used tool.
                mirale999
                Merci Matt! Great plugin~
                By the way, I come up with an idea, I think maybe it's useful!
                I use the shortcut“shift+Y” to recall the last tool. When I use this plugin, a situation like this will happen:
                first I use the "Edge follow me" tool to build a face,
                then I move it to another place, and use move and scale to modify the curves,
                then I want to do "Edge follow me" again
                so the idea comes:------this tool have a function: ignore the move, scale, rotate, line, arc, rectangle, circle...(because they are so useful and they have shortcuts), but recall edge follow me, blend, extrapolate colors...(you must find it in a submenu).
                On my bad English... hope you get my meaning... ☀
                paranoia is a higher form of awareness...
                  Matt666
                  Hi mirale999!
                  So you want RLT ignores some native tools you would be able to choose? Do you agree with this "way of explanation" (I dont know how to tell it in english 😳 )?
                  I don't know if it's possible... But I can try.
                  My scripts
                    jdtsmith
                    Just an FYI for any Mac users. Pecan's version above with the "exceptions" list works fine for me in SU 8.0. I use it with BetterTouchTool and a Magic Trackpad:
                    • Three Finger TipTap Left: Orbit (O)
                    • 3 Finger Tip Tap Right: Recall Last Tool (which I have as F2)
                    • Pinch Out: Zoom Extents (I have as Shift-Z)
                    This plugin, with Lion's native three finger dragging make using SU with the trackpad much more enjoyable. Here's how I use it:
                    • Two finger "scroll": zooms in and out
                    • 3 Finger move: same as click and drag for selection
                    • Tip Tap Left (drop two fingers and tap another to the left): switch to orbit tool
                    • Tip Tap Right: switch back to whichever tool I'm in the middle of using
                    • Get Lost? Pinch to Zoom Out
                    Thanks to the plugin's authors!
                      alex_picas
                      Hi Matt. Recall command of autocad is good too. Can you do other 'last tool recall' version like autocad with using only a space bar? Thanks Matt.
                      • O Offline
                        Omaha
                        In this case, I want to say that for sure, Thank you. You saved the day.
                          Pherim
                          Makes SU Make 2017 (Windows) crash.
                          • CadFatherC Offline
                            CadFather
                            mmm... works fine with me - is it wrapped in a module?
                            require 'sketchup.rb'
                            module MATT_Recall
                            class Matt_Observer < Sketchup;;ToolsObserver
                            	@@Matt_Model_Toolid = nil
                            	@@Matt_Model_Toolid2 = nil
                            	def onActiveToolChanged (tools_object, toolname, toolid)
                            		@@Matt_Model_Toolid = @@Matt_Model_Toolid2 if @@Matt_Model_Toolid2
                            		@@Matt_Model_Toolid2 = toolid if not([10508].index toolid)
                            	def self.recall_last
                            			return Sketchup.send_action(@@Matt_Model_Toolid)
                            		else
                            			puts "No tool used before."
                            			return Sketchup.send_action("selectSelectionTool;")
                            end  #class
                            Sketchup.active_model.tools.add_observer(Matt_Observer.new)
                            unless file_loaded?(__FILE__)
                               UI.menu('Edit').add_item("RECALL LAST TOOL"){ Matt_Observer.recall_last }
                            	file_loaded(__FILE__)
                            end#module
                              CadFather
                              just in case anyone else asks, the following is totally fine on my pc:
                              module MATT_Recall
                              	def onActiveToolChanged (tools, tool_name, tool_id)
                                  puts "Tool Used; #{tool_name}"
                              		@@Matt_Model_Toolid2 = tool_id if not([10508].index tool_id)
                              		else
                              end  #class
                              end#module
                                Pherim
                                Using the one from the ExtensionStore... but no, it's not. Will try it out, thank you.
                                Edit: Still crashes on start. Well, it doesn't work with tools from plugins, anyway.
                                  booglabird
                                  Nice tool, but i wish it worked after panning or rotating, avoiding those inputs
                                  • E Offline
                                    Einstein
                                    The RB file has a very strange name: "Recall_last_tool%5Bv1.2%5D.rb" and its installation caused a bugsplat in SU17. I changed RB name to "Recall_last_tool" and bugsplat didn't appear anymore 😄
                                      Actually it shows up that way when you download it because Windows doesn't resolve the square brackets in file names. You could have edited the file name and removed %5B and %5D and been just fine.
                                      • E Offline
                                        Einstein
                                        Hi!
                                        This plugin works well with native SU tools but causes serious problems when combined with plugins. For example: when I perform RotaScale (ThomThom), 3D Rotate (Eneroth) or Free rotate (TIG) and then try to Recall it, it leads to bugsplat.
                                        When I use Extrude Lines [D. Bur], then Recall Last Tool it just "omits" it and brings a native tool I used proviously.
                                        I'd really like to test it with more plugins and see what happens but it takes too long, with one bugsplat after another...
                                        • V Offline
                                          Vigy
                                          Please anyone or Matt666!!!
                                          I download this plug-in via sketchucation plug-in manager, right after downloading SU crashed on me, it won’t reopen again. I tried to restore SU but it didn’t help nether. Nor did I have a windows backup restored. 😢 😢 Can anyone PLEASE help me!
                                          SU18 pro User
                                          Tx in advance! Vigy!
                                            SU18 pro User
                                            This is a very old plugin...
                                            When you installed its RBZ it will have added a RB file into your Plugins folder.
                                            Looks like this is loading and breaking things.
                                            It's named something like:
                                            Open your Plugins folder and remove it...
                                            Then retry starting SketchUp...
                                            Your profile says you use v8 [but that is very old and I suspect it's out of date !], but if it is so then your Plugins folder is probably here:
                                            C:\Program Files\SketchUp\SketchUp 8\Plugins
                                            Otherwise if you have a newer version it's probably found here:
                                            C:\Users\YOUR_USER_NAME\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Plugins
                                            That AppData folder might be hidden by default, but pasting the full path in a Windows Explorer window's top-bar should open it, otherwise reset your Folder-Options to show hidden content...
                                            • 3 / 3
