    [Plugin] Recall last tool v1.2
    60 Posts 28 Posters 66.0k Views 28 Watching
    • CadFatherC
      CadFather
      mmm... works fine with me - is it wrapped in a module?
      require 'sketchup.rb'
      module MATT_Recall
      class Matt_Observer < Sketchup;;ToolsObserver
      	@@Matt_Model_Toolid = nil
      	@@Matt_Model_Toolid2 = nil
      	def onActiveToolChanged (tools_object, toolname, toolid)
      		@@Matt_Model_Toolid = @@Matt_Model_Toolid2 if @@Matt_Model_Toolid2
      		@@Matt_Model_Toolid2 = toolid if not([10508].index toolid)
      	def self.recall_last
      			return Sketchup.send_action(@@Matt_Model_Toolid)
      		else
      			puts "No tool used before."
      			return Sketchup.send_action("selectSelectionTool;")
      end  #class
      Sketchup.active_model.tools.add_observer(Matt_Observer.new)
      unless file_loaded?(__FILE__)
         UI.menu('Edit').add_item("RECALL LAST TOOL"){ Matt_Observer.recall_last }
      	file_loaded(__FILE__)
      end#module
      • CadFatherC
        CadFather
        just in case anyone else asks, the following is totally fine on my pc:
        module MATT_Recall
        	def onActiveToolChanged (tools, tool_name, tool_id)
            puts "Tool Used; #{tool_name}"
        		@@Matt_Model_Toolid2 = tool_id if not([10508].index tool_id)
        		else
        end  #class
        end#module
        • P
          Pherim
          Using the one from the ExtensionStore... but no, it's not. Will try it out, thank you.
          Edit: Still crashes on start. Well, it doesn't work with tools from plugins, anyway.
          • B
            booglabird
            Nice tool, but i wish it worked after panning or rotating, avoiding those inputs
            • E
              Einstein
              The RB file has a very strange name: "Recall_last_tool%5Bv1.2%5D.rb" and its installation caused a bugsplat in SU17. I changed RB name to "Recall_last_tool" and bugsplat didn't appear anymore 😄
                Actually it shows up that way when you download it because Windows doesn't resolve the square brackets in file names. You could have edited the file name and removed %5B and %5D and been just fine.
                • E
                  Einstein
                  Hi!
                  This plugin works well with native SU tools but causes serious problems when combined with plugins. For example: when I perform RotaScale (ThomThom), 3D Rotate (Eneroth) or Free rotate (TIG) and then try to Recall it, it leads to bugsplat.
                  When I use Extrude Lines [D. Bur], then Recall Last Tool it just "omits" it and brings a native tool I used proviously.
                  I'd really like to test it with more plugins and see what happens but it takes too long, with one bugsplat after another...
                  • V
                    Vigy
                    Please anyone or Matt666!!!
                    I download this plug-in via sketchucation plug-in manager, right after downloading SU crashed on me, it won’t reopen again. I tried to restore SU but it didn’t help nether. Nor did I have a windows backup restored. 😢 😢 Can anyone PLEASE help me!
                    SU18 pro User
                    Tx in advance! Vigy!
                      SU18 pro User
                      This is a very old plugin...
                      When you installed its RBZ it will have added a RB file into your Plugins folder.
                      Looks like this is loading and breaking things.
                      It's named something like:
                      Open your Plugins folder and remove it...
                      Then retry starting SketchUp...
                      Your profile says you use v8 [but that is very old and I suspect it's out of date !], but if it is so then your Plugins folder is probably here:
                      C:\Program Files\SketchUp\SketchUp 8\Plugins
                      Otherwise if you have a newer version it's probably found here:
                      C:\Users\YOUR_USER_NAME\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Plugins
                      That AppData folder might be hidden by default, but pasting the full path in a Windows Explorer window's top-bar should open it, otherwise reset your Folder-Options to show hidden content...
                      • jujuJ
                        juju
                        Eneroth has a similar extension, not free though. SU2016 + only.
                        Eneroth Tool Memory
                        • V
                          Vigy
                          Thanks so much TIG! yes I found it in the hidden folder, and works very well now.
                          Juju I will check it out, Tx
                          • Z
                            zhangruofei
                            • L
                              LeoSam
                              Hello Matt,
                              This is a very old thread, but I have to give it a shot. I'm running latest SketchUp - V21.1. Extensions I install are (.rbz) file type, but the file you have here for download is (.rb). How can I install it?
                              I needed a tool to repeat last command since I started working on SketchUp 3 years ago! I really, really wish to have it. Thank you
                                To install a lone RB file you need to put it into your Plugins folder...
                                C:\Users\YOUR_USER_NAME\AppData\Roaming\SketchUp\SketchUp 2021\SketchUp\Plugins
                                Restart SketchUp to see if it loads OK...
                                It is an old plugin...
                                  rv1974
                                  Fredo's LOTT has this command binded to double space bar key
                                  • 3 / 3
