    [Plugin] Recall last tool v1.2
    60 Posts 28 Posters 64.1k Views 28 Watching
    • O Offline
      Omaha
      In this case, I want to say that for sure, Thank you. You saved the day.
        Pherim
        Makes SU Make 2017 (Windows) crash.
        • CadFatherC Offline
          CadFather
          mmm... works fine with me - is it wrapped in a module?
          require 'sketchup.rb'
          module MATT_Recall
          class Matt_Observer < Sketchup;;ToolsObserver
          	@@Matt_Model_Toolid = nil
          	@@Matt_Model_Toolid2 = nil
          	def onActiveToolChanged (tools_object, toolname, toolid)
          		@@Matt_Model_Toolid = @@Matt_Model_Toolid2 if @@Matt_Model_Toolid2
          		@@Matt_Model_Toolid2 = toolid if not([10508].index toolid)
          	def self.recall_last
          			return Sketchup.send_action(@@Matt_Model_Toolid)
          		else
          			puts "No tool used before."
          			return Sketchup.send_action("selectSelectionTool;")
          end  #class
          Sketchup.active_model.tools.add_observer(Matt_Observer.new)
          unless file_loaded?(__FILE__)
             UI.menu('Edit').add_item("RECALL LAST TOOL"){ Matt_Observer.recall_last }
          	file_loaded(__FILE__)
          end#module
            CadFather
            just in case anyone else asks, the following is totally fine on my pc:
            module MATT_Recall
            	def onActiveToolChanged (tools, tool_name, tool_id)
                puts "Tool Used; #{tool_name}"
            		@@Matt_Model_Toolid2 = tool_id if not([10508].index tool_id)
            		else
            end  #class
            end#module
              Pherim
              Using the one from the ExtensionStore... but no, it's not. Will try it out, thank you.
              Edit: Still crashes on start. Well, it doesn't work with tools from plugins, anyway.
                booglabird
                Nice tool, but i wish it worked after panning or rotating, avoiding those inputs
                • E Offline
                  Einstein
                  The RB file has a very strange name: "Recall_last_tool%5Bv1.2%5D.rb" and its installation caused a bugsplat in SU17. I changed RB name to "Recall_last_tool" and bugsplat didn't appear anymore 😄
                    Actually it shows up that way when you download it because Windows doesn't resolve the square brackets in file names. You could have edited the file name and removed %5B and %5D and been just fine.
                    • E Offline
                      Einstein
                      Hi!
                      This plugin works well with native SU tools but causes serious problems when combined with plugins. For example: when I perform RotaScale (ThomThom), 3D Rotate (Eneroth) or Free rotate (TIG) and then try to Recall it, it leads to bugsplat.
                      When I use Extrude Lines [D. Bur], then Recall Last Tool it just "omits" it and brings a native tool I used proviously.
                      I'd really like to test it with more plugins and see what happens but it takes too long, with one bugsplat after another...
                      • V Offline
                        Vigy
                        Please anyone or Matt666!!!
                        I download this plug-in via sketchucation plug-in manager, right after downloading SU crashed on me, it won’t reopen again. I tried to restore SU but it didn’t help nether. Nor did I have a windows backup restored. 😢 😢 Can anyone PLEASE help me!
                        SU18 pro User
                        Tx in advance! Vigy!
                          SU18 pro User
                          This is a very old plugin...
                          When you installed its RBZ it will have added a RB file into your Plugins folder.
                          Looks like this is loading and breaking things.
                          It's named something like:
                          Open your Plugins folder and remove it...
                          Then retry starting SketchUp...
                          Your profile says you use v8 [but that is very old and I suspect it's out of date !], but if it is so then your Plugins folder is probably here:
                          C:\Program Files\SketchUp\SketchUp 8\Plugins
                          Otherwise if you have a newer version it's probably found here:
                          C:\Users\YOUR_USER_NAME\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Plugins
                          That AppData folder might be hidden by default, but pasting the full path in a Windows Explorer window's top-bar should open it, otherwise reset your Folder-Options to show hidden content...
                          • jujuJ Offline
                            juju
                            Eneroth has a similar extension, not free though. SU2016 + only.
                            Eneroth Tool Memory
                            • V Offline
                              Vigy
                              Thanks so much TIG! yes I found it in the hidden folder, and works very well now.
                              Juju I will check it out, Tx
                              • Z Offline
                                zhangruofei
                                  LeoSam
                                  Hello Matt,
                                  This is a very old thread, but I have to give it a shot. I'm running latest SketchUp - V21.1. Extensions I install are (.rbz) file type, but the file you have here for download is (.rb). How can I install it?
                                  I needed a tool to repeat last command since I started working on SketchUp 3 years ago! I really, really wish to have it. Thank you
                                    To install a lone RB file you need to put it into your Plugins folder...
                                    C:\Users\YOUR_USER_NAME\AppData\Roaming\SketchUp\SketchUp 2021\SketchUp\Plugins
                                    Restart SketchUp to see if it loads OK...
                                    It is an old plugin...
                                      rv1974
                                      Fredo's LOTT has this command binded to double space bar key
                                      • 3 / 3
