    [Plugin] Recall last tool v1.2
    60 Posts 28 Posters 66.0k Views 28 Watching
    • plot-parisP
      plot-paris
      another idea, although probably not managable with ruby, is a much more graphical approach:
      when you hold down the space bar, a ring with tool buttons appears around your cursor in a circular fashion. you can now left click any button to get the tool. or you can simply turn the scroll wheel to file through them, either clockwise or counterclockwise. by default the selection tool is highlighted - so if you just press the space bar once, you get the select tool.
      you can easily customise this tool-circle by holding down the space bar and then dragging unwanted tools out of the circle and vice versa.
      well, maybe Google comes up with soemthing similar in the next release 😄
      • juan974J
        juan974
        Merci MATT ...
        juan974 (Réunion island)
        website : http://sketchucation.com/click.php?url=http://www.tarn.us
        • B
          bitsnbites
          Thank you very much, Matt666.
          That´s the Plugin i was lookin for.
          thx a lot
            Matt666
            I will try to find a solution.
            Frenglish at its best !
            My scripts
              Matt666
              Sorry, I don't know how to create a personal observer for controlling mouse events...
              My scripts
              • P
                Pherim
                Neat, I didn't know this yet. Great timesaver when switching to select tool to return to the previously used tool.
                  mirale999
                  Merci Matt! Great plugin~
                  By the way, I come up with an idea, I think maybe it's useful!
                  I use the shortcut“shift+Y” to recall the last tool. When I use this plugin, a situation like this will happen:
                  first I use the "Edge follow me" tool to build a face,
                  then I move it to another place, and use move and scale to modify the curves,
                  then I want to do "Edge follow me" again
                  so the idea comes:------this tool have a function: ignore the move, scale, rotate, line, arc, rectangle, circle...(because they are so useful and they have shortcuts), but recall edge follow me, blend, extrapolate colors...(you must find it in a submenu).
                  On my bad English... hope you get my meaning... ☀
                  paranoia is a higher form of awareness...
                    Matt666
                    Hi mirale999!
                    So you want RLT ignores some native tools you would be able to choose? Do you agree with this "way of explanation" (I dont know how to tell it in english 😳 )?
                    I don't know if it's possible... But I can try.
                    My scripts
                      jdtsmith
                      Just an FYI for any Mac users. Pecan's version above with the "exceptions" list works fine for me in SU 8.0. I use it with BetterTouchTool and a Magic Trackpad:
                      • Three Finger TipTap Left: Orbit (O)
                      • 3 Finger Tip Tap Right: Recall Last Tool (which I have as F2)
                      • Pinch Out: Zoom Extents (I have as Shift-Z)
                      This plugin, with Lion's native three finger dragging make using SU with the trackpad much more enjoyable. Here's how I use it:
                      • Two finger "scroll": zooms in and out
                      • 3 Finger move: same as click and drag for selection
                      • Tip Tap Left (drop two fingers and tap another to the left): switch to orbit tool
                      • Tip Tap Right: switch back to whichever tool I'm in the middle of using
                      • Get Lost? Pinch to Zoom Out
                      Thanks to the plugin's authors!
                        alex_picas
                        Hi Matt. Recall command of autocad is good too. Can you do other 'last tool recall' version like autocad with using only a space bar? Thanks Matt.
                        • O
                          Omaha
                          In this case, I want to say that for sure, Thank you. You saved the day.
                          • P
                            Pherim
                            Makes SU Make 2017 (Windows) crash.
                            • CadFatherC
                              CadFather
                              mmm... works fine with me - is it wrapped in a module?
                              require 'sketchup.rb'
                              module MATT_Recall
                              class Matt_Observer < Sketchup;;ToolsObserver
                              	@@Matt_Model_Toolid = nil
                              	@@Matt_Model_Toolid2 = nil
                              	def onActiveToolChanged (tools_object, toolname, toolid)
                              		@@Matt_Model_Toolid = @@Matt_Model_Toolid2 if @@Matt_Model_Toolid2
                              		@@Matt_Model_Toolid2 = toolid if not([10508].index toolid)
                              	def self.recall_last
                              			return Sketchup.send_action(@@Matt_Model_Toolid)
                              		else
                              			puts "No tool used before."
                              			return Sketchup.send_action("selectSelectionTool;")
                              end  #class
                              Sketchup.active_model.tools.add_observer(Matt_Observer.new)
                              unless file_loaded?(__FILE__)
                                 UI.menu('Edit').add_item("RECALL LAST TOOL"){ Matt_Observer.recall_last }
                              	file_loaded(__FILE__)
                              end#module
                              • CadFatherC
                                CadFather
                                just in case anyone else asks, the following is totally fine on my pc:
                                module MATT_Recall
                                	def onActiveToolChanged (tools, tool_name, tool_id)
                                    puts "Tool Used; #{tool_name}"
                                		@@Matt_Model_Toolid2 = tool_id if not([10508].index tool_id)
                                		else
                                end  #class
                                end#module
                                • P
                                  Pherim
                                  Using the one from the ExtensionStore... but no, it's not. Will try it out, thank you.
                                  Edit: Still crashes on start. Well, it doesn't work with tools from plugins, anyway.
                                  • B
                                    booglabird
                                    Nice tool, but i wish it worked after panning or rotating, avoiding those inputs
                                    • E
                                      Einstein
                                      The RB file has a very strange name: "Recall_last_tool%5Bv1.2%5D.rb" and its installation caused a bugsplat in SU17. I changed RB name to "Recall_last_tool" and bugsplat didn't appear anymore 😄
                                        Actually it shows up that way when you download it because Windows doesn't resolve the square brackets in file names. You could have edited the file name and removed %5B and %5D and been just fine.
                                        • E
                                          Einstein
                                          Hi!
                                          This plugin works well with native SU tools but causes serious problems when combined with plugins. For example: when I perform RotaScale (ThomThom), 3D Rotate (Eneroth) or Free rotate (TIG) and then try to Recall it, it leads to bugsplat.
                                          When I use Extrude Lines [D. Bur], then Recall Last Tool it just "omits" it and brings a native tool I used proviously.
                                          I'd really like to test it with more plugins and see what happens but it takes too long, with one bugsplat after another...
                                          • V
                                            Vigy
                                            Please anyone or Matt666!!!
                                            I download this plug-in via sketchucation plug-in manager, right after downloading SU crashed on me, it won’t reopen again. I tried to restore SU but it didn’t help nether. Nor did I have a windows backup restored. 😢 😢 Can anyone PLEASE help me!
                                            SU18 pro User
                                            Tx in advance! Vigy!
                                            • 3 / 3
