    SketchUcation Tools in 2017
    113 Posts 17 Posters 5.1k Views 17 Watching
    • JQLJ Offline
      JQL
      Here's how they are done with Licecap:
      www.casca.pt
      Visit us on facebook!
      • N Offline
        NickW
        @jql said:
        They are not images, they are gifs, Click on them. Sorry for that I usually say you have to click on them but I believe Tig has seen those before, so I assume he knows he has to click them already. My mistake...
        If I click on them I just get a popup window with the same, mostly black, image.
        EDIT: AH, no, it just takes a little time to load. Sorry. 😳
        • JQLJ Offline
          JQL
          Damn... I'm not telling everything again. Click on them and wait 3 secs...
          www.casca.pt
          • N Offline
            NickW
            😳 Sorry JQL.
            Good app that though, thanks for pointing it out.
              Can you please try this alternative RBS in the attached ZIP.
              As well as setting a min height [500] it also sets a max height [900] - which I hope might make the dialog see sense for those of you with the issue - it already works for me with no tweaks...
              Please report back asap...
              I need to get this fixed...
              SCF_Dialog.rbs.zip
                blue442
                This worked flawlessly for me.
                I had the weird box problem before.
                -- it also remembers the size and location.
                • BoxB Offline
                  Nice one Tig, although I don't need it.
                  • N Offline
                    NickW
                    Yes, that seems to work fine, though I'm not sure I can tell the difference from the previous version.
                      So you are saying that giving an explicit min & max height resolves the issue - it is now vertically resize-able between those limits... and its last used height is remembered on a restart... ??
                      Can someone else confirm this works for them too, so I can make an update...
                      • JQLJ Offline
                        JQL
                        Here it is Tig:
                        www.casca.pt
                        • josephkim626J Offline
                          josephkim626
                          TIG,
                          Thanks for the RBS files it works flawlessly with the machines that had store not appearing.
                          I have test those behaviors and reporting to you:
                          The window is resize-able with some minimum restrictions
                          The last used height is remembered on restart as well as the width.
                          I think it is good to be updated as 3.0.3 version.
                            Thanks for all of your responses...
                            I'll send Rich a signed v3.0.3 RBZ and I'm sure he'll add it to the PluginStore asap...
                            • N Offline
                              NickW
                              Version 3.0.3 downloaded from the SketchUcation store and working fine. Thanks TIG.
                              • N Offline
                                NickW
                                But I'm afraid that the next thing I downloaded (LibFred06) doesn't resize and cannot be moved.
                                  that's Fredo's Update Checker. Just close it.
                                  • PixeroP Offline
                                    Pixero
                                    3.0.3 Worked for me.
                                    But I'd like to be able to make the window higher. I have a highres screen...
                                      I set the maximum height arbitrarily at 900px.
                                      What do you think a reasonable maximum might be ?
                                      I can always adjust the code...
                                      • PixeroP Offline
                                        Pixero
                                        My screens vertical resolution is 1800 pixels. Maybe slightly less. 1600 pixels perhaps?
                                          OK, I'll discuss it with Rich...
                                          • ntxdaveN Offline
                                            ntxdave
                                            TIG, Rich - Thanks so much for the update. I am now running fine. 😎
                                            Just got to go through and install all of my plugins in 2017 now.
                                            TIG - The size if fine for my laptop.
                                            • 2 / 6
