    SketchUcation Tools in 2017
    113 Posts 17 Posters 14.8k Views 17 Watching
      Can you please try this alternative RBS in the attached ZIP.
      As well as setting a min height [500] it also sets a max height [900] - which I hope might make the dialog see sense for those of you with the issue - it already works for me with no tweaks...
      Please report back asap...
      I need to get this fixed...
      SCF_Dialog.rbs.zip
        blue442
        This worked flawlessly for me.
        I had the weird box problem before.
        -- it also remembers the size and location.
        • BoxB Offline
          Nice one Tig, although I don't need it.
          • N Offline
            NickW
            Yes, that seems to work fine, though I'm not sure I can tell the difference from the previous version.
              So you are saying that giving an explicit min & max height resolves the issue - it is now vertically resize-able between those limits... and its last used height is remembered on a restart... ??
              Can someone else confirm this works for them too, so I can make an update...
              • JQLJ Offline
                JQL
                Here it is Tig:
                www.casca.pt
                Visit us on facebook!
                • josephkim626J Offline
                  josephkim626
                  TIG,
                  Thanks for the RBS files it works flawlessly with the machines that had store not appearing.
                  I have test those behaviors and reporting to you:
                  The window is resize-able with some minimum restrictions
                  The last used height is remembered on restart as well as the width.
                  I think it is good to be updated as 3.0.3 version.
                    Thanks for all of your responses...
                    I'll send Rich a signed v3.0.3 RBZ and I'm sure he'll add it to the PluginStore asap...
                    • N Offline
                      NickW
                      Version 3.0.3 downloaded from the SketchUcation store and working fine. Thanks TIG.
                      • N Offline
                        NickW
                        But I'm afraid that the next thing I downloaded (LibFred06) doesn't resize and cannot be moved.
                          that's Fredo's Update Checker. Just close it.
                          • PixeroP Offline
                            Pixero
                            3.0.3 Worked for me.
                            But I'd like to be able to make the window higher. I have a highres screen...
                              I set the maximum height arbitrarily at 900px.
                              What do you think a reasonable maximum might be ?
                              I can always adjust the code...
                              • PixeroP Offline
                                Pixero
                                My screens vertical resolution is 1800 pixels. Maybe slightly less. 1600 pixels perhaps?
                                  OK, I'll discuss it with Rich...
                                  • ntxdaveN Offline
                                    ntxdave
                                    TIG, Rich - Thanks so much for the update. I am now running fine. 😎
                                    Just got to go through and install all of my plugins in 2017 now.
                                    TIG - The size if fine for my laptop.
                                    Press F1...thank me later
                                      josephkim626
                                      Version still showing as 3.0.2 on store, but 3.0.3 on manager.
                                        v3.0.4 now includes dialog height fix for Pixero and and a secondary fix for additional folder dialog popup
                                        Thanks guys for helping us fix this so quickly
                                        • JQLJ Offline
                                          JQL
                                          I got a 4k and it's 3840x2160 there are 5k and more.
                                          In reality I don't know of a reason why the limit should exist (besides the hack of course). Why not put it at 3000px or more?
                                          www.casca.pt
                                            The ExtensionStore³ dialog's max height is currently set to be 1600px.
                                            If anyone has a very good reason to make it bigger, then please state your case...
                                            But, no promises...
                                            • 5 / 6
