    SketchUcation Tools in 2017
    113 Posts 17 Posters 20.0k Views 17 Watching
    • JQLJ
      JQL
      Cool hack:
      I feel we're getting there... can't we have a minimum value bigger than 100
      www.casca.pt
      Visit us on facebook!
        The RBS in the attached ZIP has a larger min height [500] so it might at least be usable, at least until I get to the bottom of this weirdness...
        Please follow the earlier instructions and retest.
        I can't see how the window is not resize-able for you !
        It is for me and the code specifically makes it so...
        Anyway, thanks for the testing...
        Please report back...
        SCF_Dialog.rbs.zip
        • JQLJ
          JQL
          Nice this one is useable:
          Nicelly done, Thanks!
          www.casca.pt
          • N
            NickW
            I now have a scrollable area, and the scrollbar works. Still cannot resize vertically, but at least it's usable in this form.
            Thanks, and good luck with finding the root cause. Post again if I can help further.
            • N
              NickW
              JQL
              Your last three images are blank apart from a caption in the middle.
              EDIT: ...four...
              • JQLJ
                JQL
                They are not images, they are gifs, Click on them. Sorry for that I usually say you have to click on them but I believe Tig has seen those before, so I assume he knows he has to click them already. My mistake...
                www.casca.pt
                • JQLJ
                  JQL
                  Here's how they are done with Licecap:
                  www.casca.pt
                  • N
                    NickW
                    If I click on them I just get a popup window with the same, mostly black, image.
                    EDIT: AH, no, it just takes a little time to load. Sorry. 😳
                    • JQLJ
                      JQL
                      Damn... I'm not telling everything again. Click on them and wait 3 secs...
                      www.casca.pt
                      • N
                        NickW
                        😳 Sorry JQL.
                        Good app that though, thanks for pointing it out.
                          Can you please try this alternative RBS in the attached ZIP.
                          As well as setting a min height [500] it also sets a max height [900] - which I hope might make the dialog see sense for those of you with the issue - it already works for me with no tweaks...
                          Please report back asap...
                          I need to get this fixed...
                          SCF_Dialog.rbs.zip
                          • B
                            blue442
                            This worked flawlessly for me.
                            I had the weird box problem before.
                            -- it also remembers the size and location.
                            • BoxB
                              Nice one Tig, although I don't need it.
                              • N
                                NickW
                                Yes, that seems to work fine, though I'm not sure I can tell the difference from the previous version.
                                  So you are saying that giving an explicit min & max height resolves the issue - it is now vertically resize-able between those limits... and its last used height is remembered on a restart... ??
                                  Can someone else confirm this works for them too, so I can make an update...
                                  • JQLJ
                                    JQL
                                    Here it is Tig:
                                    www.casca.pt
                                    • josephkim626J
                                      josephkim626
                                      TIG,
                                      Thanks for the RBS files it works flawlessly with the machines that had store not appearing.
                                      I have test those behaviors and reporting to you:
                                      The window is resize-able with some minimum restrictions
                                      The last used height is remembered on restart as well as the width.
                                      I think it is good to be updated as 3.0.3 version.
                                        Thanks for all of your responses...
                                        I'll send Rich a signed v3.0.3 RBZ and I'm sure he'll add it to the PluginStore asap...
                                        • N
                                          NickW
                                          Version 3.0.3 downloaded from the SketchUcation store and working fine. Thanks TIG.
                                          • N
                                            NickW
                                            But I'm afraid that the next thing I downloaded (LibFred06) doesn't resize and cannot be moved.
                                            • 4 / 6
