    SketchUcation Tools in 2017
    113 Posts 17 Posters 10.9k Views 17 Watching
    • N Offline
      NickW
      😳 Sorry JQL.
      Good app that though, thanks for pointing it out.
        Can you please try this alternative RBS in the attached ZIP.
        As well as setting a min height [500] it also sets a max height [900] - which I hope might make the dialog see sense for those of you with the issue - it already works for me with no tweaks...
        Please report back asap...
        I need to get this fixed...
        SCF_Dialog.rbs.zip
          blue442
          This worked flawlessly for me.
          I had the weird box problem before.
          -- it also remembers the size and location.
          • BoxB Offline
            Nice one Tig, although I don't need it.
            • N Offline
              NickW
              Yes, that seems to work fine, though I'm not sure I can tell the difference from the previous version.
                So you are saying that giving an explicit min & max height resolves the issue - it is now vertically resize-able between those limits... and its last used height is remembered on a restart... ??
                Can someone else confirm this works for them too, so I can make an update...
                • JQLJ Offline
                  JQL
                  Here it is Tig:
                  www.casca.pt
                  Visit us on facebook!
                  • josephkim626J Offline
                    josephkim626
                    TIG,
                    Thanks for the RBS files it works flawlessly with the machines that had store not appearing.
                    I have test those behaviors and reporting to you:
                    The window is resize-able with some minimum restrictions
                    The last used height is remembered on restart as well as the width.
                    I think it is good to be updated as 3.0.3 version.
                      Thanks for all of your responses...
                      I'll send Rich a signed v3.0.3 RBZ and I'm sure he'll add it to the PluginStore asap...
                      • N Offline
                        NickW
                        Version 3.0.3 downloaded from the SketchUcation store and working fine. Thanks TIG.
                        • N Offline
                          NickW
                          But I'm afraid that the next thing I downloaded (LibFred06) doesn't resize and cannot be moved.
                            that's Fredo's Update Checker. Just close it.
                            • PixeroP Offline
                              Pixero
                              3.0.3 Worked for me.
                              But I'd like to be able to make the window higher. I have a highres screen...
                                I set the maximum height arbitrarily at 900px.
                                What do you think a reasonable maximum might be ?
                                I can always adjust the code...
                                • PixeroP Offline
                                  Pixero
                                  My screens vertical resolution is 1800 pixels. Maybe slightly less. 1600 pixels perhaps?
                                    OK, I'll discuss it with Rich...
                                    • ntxdaveN Offline
                                      ntxdave
                                      TIG, Rich - Thanks so much for the update. I am now running fine. 😎
                                      Just got to go through and install all of my plugins in 2017 now.
                                      TIG - The size if fine for my laptop.
                                      Press F1...thank me later
                                        josephkim626
                                        Version still showing as 3.0.2 on store, but 3.0.3 on manager.
                                          v3.0.4 now includes dialog height fix for Pixero and and a secondary fix for additional folder dialog popup
                                          Thanks guys for helping us fix this so quickly
                                          • JQLJ Offline
                                            JQL
                                            I got a 4k and it's 3840x2160 there are 5k and more.
                                            In reality I don't know of a reason why the limit should exist (besides the hack of course). Why not put it at 3000px or more?
                                            www.casca.pt
                                            • 5 / 6
