    SketchUcation Tools in 2017
    113 Posts 17 Posters 20.0k Views 17 Watching
    • B
      blue442
      @tig said:
      Can you please try this alternative RBS in the attached ZIP.
      As well as setting a min height [500] it also sets a max height [900] - which I hope might make the dialog see sense for those of you with the issue - it already works for me with no tweaks...
      Please report back asap...
      I need to get this fixed...
      This worked flawlessly for me.
      I had the weird box problem before.
      -- it also remembers the size and location.
      • BoxB
        Nice one Tig, although I don't need it.
        • N
          NickW
          Yes, that seems to work fine, though I'm not sure I can tell the difference from the previous version.
            So you are saying that giving an explicit min & max height resolves the issue - it is now vertically resize-able between those limits... and its last used height is remembered on a restart... ??
            Can someone else confirm this works for them too, so I can make an update...
            • JQLJ
              JQL
              Here it is Tig:
              www.casca.pt
              Visit us on facebook!
              • josephkim626J
                josephkim626
                TIG,
                Thanks for the RBS files it works flawlessly with the machines that had store not appearing.
                I have test those behaviors and reporting to you:
                The window is resize-able with some minimum restrictions
                The last used height is remembered on restart as well as the width.
                I think it is good to be updated as 3.0.3 version.
                  Thanks for all of your responses...
                  I'll send Rich a signed v3.0.3 RBZ and I'm sure he'll add it to the PluginStore asap...
                  • N
                    NickW
                    Version 3.0.3 downloaded from the SketchUcation store and working fine. Thanks TIG.
                    • N
                      NickW
                      But I'm afraid that the next thing I downloaded (LibFred06) doesn't resize and cannot be moved.
                        that's Fredo's Update Checker. Just close it.
                        • PixeroP
                          Pixero
                          3.0.3 Worked for me.
                          But I'd like to be able to make the window higher. I have a highres screen...
                            I set the maximum height arbitrarily at 900px.
                            What do you think a reasonable maximum might be ?
                            I can always adjust the code...
                            • PixeroP
                              Pixero
                              My screens vertical resolution is 1800 pixels. Maybe slightly less. 1600 pixels perhaps?
                                OK, I'll discuss it with Rich...
                                • ntxdaveN
                                  ntxdave
                                  TIG, Rich - Thanks so much for the update. I am now running fine. 😎
                                  Just got to go through and install all of my plugins in 2017 now.
                                  TIG - The size if fine for my laptop.
                                  Press F1...thank me later
                                  • josephkim626J
                                    josephkim626
                                    Version still showing as 3.0.2 on store, but 3.0.3 on manager.
                                      v3.0.4 now includes dialog height fix for Pixero and and a secondary fix for additional folder dialog popup
                                      Thanks guys for helping us fix this so quickly
                                      • JQLJ
                                        JQL
                                        I got a 4k and it's 3840x2160 there are 5k and more.
                                        In reality I don't know of a reason why the limit should exist (besides the hack of course). Why not put it at 3000px or more?
                                        www.casca.pt
                                          The ExtensionStore³ dialog's max height is currently set to be 1600px.
                                          If anyone has a very good reason to make it bigger, then please state your case...
                                          But, no promises...
                                          • PixeroP
                                            Pixero
                                            @JQL: Wouldn't the scroll bar be very small for users with a lower screen resolution then?
                                            • 5 / 6
