    SketchUcation Tools in 2017
    113 Posts 17 Posters 15.1k Views 17 Watching
    • bazB Offline
      baz
      @bob james said:
      Here's what I see in Win10 Pro
      All good on Win10 Pro
      • Rich O BrienR Online
        We are trying to find a cause but nothing so far?
        Anyone got any more clues on what happens? Box reported that if you try to maximise the dialog it disappears. Can others confirm this?
        • BoxB Offline
          I can even confirm that anymore, as now it's working.
          I just did a clean install (uninstall all versions of 2017 including plugin folder, then right click install as admin)on my Win10 machine after doing a full wacom driver update.
          Then installed the toolset_v3.0.0b.rbz and nothing else and it's all looking good.
          • JQLJ Offline
            JQL
            Mine gets here:
            www.casca.pt
            Visit us on facebook!
            • BoxB Offline
              That's what I was getting until just now. So i can only guess it was something in my driver update. This is a wacom tablet so it has a specific bunch of drivers that it updates.
              But gives you no idea of the specifics.
                Bruce Watt
                I am using windows 10 with Sketchup 2017 and I am not seeing any issues.
                Although Bob James screen shot of Sketchucation Tools looks a bit different to mine.
                sketchucation tools 3.01
                SKUP PRO 2021 latest version / update
                Windows 10 Pro
                Dell Alienware Aurora R10 AMD
                AMD Ryzen™ 9 3900X
                NVIDIA® GeForce RTX™ 2080 Ti 11GB GDDR6
                  [attachment=0:3eahkxs8]<!-- ia0 -->skup.png<!-- ia0 -->[/attachment:3eahkxs8]
                  If you resize the dialog wider or smaller the appearance changes. Try making yours wider
                    Bruce Watt
                    lovely! that did the trick, thanks Rich.
                    Windows 10 Pro
                    AMD Ryzen™ 9 3900X
                    • FrederikF Offline
                      Frederik
                      Unfortunately I see the same as JQL...
                      I'm on Win 10...
                      Cheers
                      Kim Frederik
                        I'm on Win 10 and in v2017 ExtensionStore³, and everything else, works the same as v2016.
                        The newer SketchUp uses its own built-in browser for all its WebDialogs [Chromium] it used to use Internet Explorer or Safari.
                        Your Internet Options settings [Control Panel] might prevent the successful use of other browsers if it has some excessively harsh settings.
                        Look at those and see if it helps...
                        Since all v2017 users now use this newfangled Chromium OR IE browser for dialogs, it's odd that some of us have no issues but others do.
                        If you have the Ruby Console open are there any messages when you try to open the dialog ?
                        Do the other SCF dialogs like Plugins Manager work OK ?
                        Do other extensions using WebDialogs work ?
                        One option on PC to force a brand new dialog is this...
                        Only do it if you are comfortable editing the Registry - change nothing else !
                        Close v2017.
                        Run > Regedit > OK
                        In Regedit use Find or browse to this entry...
                        HKEY_CURRENT_USER\SOFTWARE\SketchUp\SketchUp 2017\**WebDialog_SketchUcation ExtensionStore**
                        Select it and Delete it.
                        Close Regedit.
                        Open v2017.
                        Open the Ruby Console.
                        Open open the ExtensionStore³ dialog...
                        If it opens narrow then pull the right side out until all buttons display...
                        Report back...
                          blue442
                          Windows 10 pro with dual 4k displays.
                          I get the thin box, enlarging doesn't help.
                          Performed a fresh Installation after deleting 2017 registry keys and all files in folder. Same results. 2016 is still installed.
                          stumped.
                          • JQLJ Offline
                            JQL
                            I'm also on a single 4k display, if it matters.
                            www.casca.pt
                            • N Offline
                              NickW
                              I'm having the same problems too. Win 10 all up to date. I've tried the Regedit suggestion, and resizing the dialog but no joy.
                              Interestingly the SU Extension Manager says the signature has expired - see attached screen capture.
                              EDIT: But I see someone else has beaten me to that one. 😳
                                When the Extensions Manager says 'Outdated Signature' it means you do not have your Loading Policy in the Extensions Manager settings set to 'Unrestricted'...
                                I think v2017 does not start off set like that - unlike v2016 ?
                                For some reason v2017 is not accepting signed extensions unless they are re-signed.
                                I'll do that and re-post the RBZ - BUT I do not expect that to be the the cause of the originally reported issue...
                                One thought about the other issue...
                                Those of you having the problem...
                                Are you installing v2017 properly ?
                                It is less forgiving than previous versions, and weirdness can pop up from nowhere...
                                You do not need to Uninstall and the Install again, do this...
                                Close v2017.
                                Find the SketchUp v2017 installer's exe [or download a fresh copy].
                                Select it and right-click > context-menu > Run as administrator...
                                When prompted choose to 'Repair'.
                                This should reset this correctly.
                                SketchUp v2017 must be installed as an administrator - even if you have admin-powers this is NOT sufficient.
                                Improper installation can cause all sorts of flay weirdness...
                                I wonder if this is the case here - where those of us who did it right have no issues ??
                                • JQLJ Offline
                                  JQL
                                  Tig, tried your Registry steps and it didn't work. Sketchucation store did open as only the top bar but very small, I pushed it to the right and no buttons poped up.
                                  www.casca.pt
                                  • JQLJ Offline
                                    JQL
                                    I didn't install it as administrator though I have administrator rights... I'll try it and then the registry again.
                                    www.casca.pt
                                    • BoxB Offline
                                      I can assure you, some of us that had the issue certainly installed it correctly.
                                      In my case it seems that a specific device update fixed the issue.
                                        Can you elaborate on your 'fix' - it might help others...
                                        • BoxB Offline
                                          I can only repeat what I posted earlier. And note that I left out the 't of can't in the second word..
                                            At Box is it v3.0.1 you are running? Your post says 3.0.0
                                            • 1 / 6
