    SketchUcation Tools in 2017
    113 Posts 17 Posters 5.9k Views 17 Watching
    • ntxdaveN Offline
      ntxdave
      I installed the SketchUcation Tools in 2017 and here is what I am seeing:
      • cottyC Offline
        cotty
        Me too.
        my SketchUp gallery
          I can't reproduce this. All i know is that it seems to happen on Windows only.
          What version of Windows are you both on? I'm on Win10
          • cottyC Offline
            cotty
            my SketchUp gallery
            • ntxdaveN Offline
              ntxdave
              @cotty said:
              [attachment=0:2ggx1i0k]<!-- ia0 -->winver.JPG<!-- ia0 -->[/attachment:2ggx1i0k]
              Same 😛
              • JQLJ Offline
                JQL
                Win 10 Home here too and I have the same issue.
                www.casca.pt
                Visit us on facebook!
                • Bob JamesB Offline
                  Bob James
                  Here's what I see in Win10 Pro
                  • bazB Offline
                    baz
                    All good on Win10 Pro
                      We are trying to find a cause but nothing so far?
                      Anyone got any more clues on what happens? Box reported that if you try to maximise the dialog it disappears. Can others confirm this?
                      • BoxB Offline
                        I can even confirm that anymore, as now it's working.
                        I just did a clean install (uninstall all versions of 2017 including plugin folder, then right click install as admin)on my Win10 machine after doing a full wacom driver update.
                        Then installed the toolset_v3.0.0b.rbz and nothing else and it's all looking good.
                        • JQLJ Offline
                          JQL
                          Mine gets here:
                          www.casca.pt
                          • BoxB Offline
                            That's what I was getting until just now. So i can only guess it was something in my driver update. This is a wacom tablet so it has a specific bunch of drivers that it updates.
                            But gives you no idea of the specifics.
                              Bruce Watt
                              I am using windows 10 with Sketchup 2017 and I am not seeing any issues.
                              Although Bob James screen shot of Sketchucation Tools looks a bit different to mine.
                              sketchucation tools 3.01
                              SKUP PRO 2021 latest version / update
                              Windows 10 Pro
                              Dell Alienware Aurora R10 AMD
                              AMD Ryzen™ 9 3900X
                              NVIDIA® GeForce RTX™ 2080 Ti 11GB GDDR6
                                [attachment=0:3eahkxs8]<!-- ia0 -->skup.png<!-- ia0 -->[/attachment:3eahkxs8]
                                If you resize the dialog wider or smaller the appearance changes. Try making yours wider
                                  Bruce Watt
                                  lovely! that did the trick, thanks Rich.
                                  Windows 10 Pro
                                  AMD Ryzen™ 9 3900X
                                  • FrederikF Offline
                                    Frederik
                                    Unfortunately I see the same as JQL...
                                    I'm on Win 10...
                                    Cheers
                                    Kim Frederik
                                    • TIGT Online
                                      I'm on Win 10 and in v2017 ExtensionStore³, and everything else, works the same as v2016.
                                      The newer SketchUp uses its own built-in browser for all its WebDialogs [Chromium] it used to use Internet Explorer or Safari.
                                      Your Internet Options settings [Control Panel] might prevent the successful use of other browsers if it has some excessively harsh settings.
                                      Look at those and see if it helps...
                                      Since all v2017 users now use this newfangled Chromium OR IE browser for dialogs, it's odd that some of us have no issues but others do.
                                      If you have the Ruby Console open are there any messages when you try to open the dialog ?
                                      Do the other SCF dialogs like Plugins Manager work OK ?
                                      Do other extensions using WebDialogs work ?
                                      One option on PC to force a brand new dialog is this...
                                      Only do it if you are comfortable editing the Registry - change nothing else !
                                      Close v2017.
                                      Run > Regedit > OK
                                      In Regedit use Find or browse to this entry...
                                      HKEY_CURRENT_USER\SOFTWARE\SketchUp\SketchUp 2017\**WebDialog_SketchUcation ExtensionStore**
                                      Select it and Delete it.
                                      Close Regedit.
                                      Open v2017.
                                      Open the Ruby Console.
                                      Open open the ExtensionStore³ dialog...
                                      If it opens narrow then pull the right side out until all buttons display...
                                      Report back...
                                        blue442
                                        Windows 10 pro with dual 4k displays.
                                        I get the thin box, enlarging doesn't help.
                                        Performed a fresh Installation after deleting 2017 registry keys and all files in folder. Same results. 2016 is still installed.
                                        stumped.
                                        • JQLJ Offline
                                          JQL
                                          I'm also on a single 4k display, if it matters.
                                          www.casca.pt
                                          • N Offline
                                            NickW
                                            I'm having the same problems too. Win 10 all up to date. I've tried the Regedit suggestion, and resizing the dialog but no joy.
                                            Interestingly the SU Extension Manager says the signature has expired - see attached screen capture.
                                            EDIT: But I see someone else has beaten me to that one. 😳
                                            • 1 / 6
