    1.5k Posts 470 Posters 3.3m Views 469 Watching
    • W Offline
      whitelock
      Hi any ideas what combination of edge filters i need on round corner in order to just see the border lines. look at the image. On the left is how I would like to see it on the right is the best I can get and I end up having to do loads of clean up. any help greatly appreciated
      • BoxB Offline
        Could you attach that model so we can look at it, as I can't replicate your problem.
        • deaneauD Offline
          deaneau
          @whitelock
          Try to select your lines and then use hide (from context-menu)
          • fredo6F Offline
            NEW RELEASE: RoundCorner v3.1b - 04 Sep 16
            RoundCorner 3.1b is a maintenance release. It fixes a bug preventing to make a sphere and a dome from a cube, as shown in the video below.
            • pep75P Offline
              pep75
              Great Fredo!!! Thanks!
              • sicksickisckS Offline
                sicksickisck
                hmm 3.1b so You mean there are no overlaps problem now ?!
                • fredo6F Offline
                  Actually overlaps are just detected and signaled (since v3.0). But you need to sort out the issue in the model (reducing the offset or modifying the model).
                    Thanks for the updates Fredo. You do marvelous work.
                      sicksickisck
                      yep; thanks for the plugin anyway;
                        Ben Ritter
                        Thank you Fredo!
                          LucasBarbos4
                          Wow. Thanks for this Fredo.
                            pedrinalex
                            Many Thanks Freddo ¡¡¡
                            MB ASUS x99M-WS, Xeon e5 2695 v3, 64 GB RAM 2400, 2x gforce gtx 1060, 1 SSDH 1 tb & 3 HD 1 TB c/u
                              rolopolo
                              roundcorner will not work! i cant get the palette to load.
                              i have installed roundcorner via the extension store.
                              all other fredo tools are working correctly
                              libfredo6 is all up to date
                              the footprint is correct - see upload attach
                              win10 sketchup2016pro
                              I cant think what to try next after reinstalling multiple times
                              Can anybody help?
                              thanks
                              • N Offline
                                namelessone
                                Hey fredo,
                                I'm having difficulties with getting round corners correct on some edges of my model. To make things simpler, I can provide screenshots of selected problematic edges and .skp file of model part I'm working on. Is it just limitation or perhaps plugin is confused?
                                http://tonic-art.com/round1.jpg
                                http://tonic-art.com/round2.jpg
                                http://tonic-art.com/round.skp
                                • gillesG Offline
                                  gilles
                                  First thing, SU does not manage too small faces; so make your part a component, create a copy, scale up the copy X1000, work on the copy.
                                    Can anybody help?
                                    thanks
                                    According to your screenshot you have round Corner disabled by the addition of ! to the file extension. Try changing it to just .rb
                                      @rolopolo
                                      Somehow you have disabled the Fredo6_RoundCorner .RB file.
                                      It is listed a an .RB! file, which mean it is disabled using the SketchUcation Plugins Manager, therefore it will not load as SketchUp starts.
                                      In SketchUp open the SketchUcation Plugins Manager, in the right-hand column are the disabled plugins.
                                      Select the RoundCorner one and use the Green button to move it into the enabled left-hand column.
                                      Because of the nature of Fredo's tools and his Lib [which should also be enabled/active] you are best off closing SketchUp and restarting.
                                      That way everything will be registered properly.
                                      Since it is an Extension it might be deactivated and at this point not add menu of toolbar entries, so you should then check the SketchUcation Extensions Manager's listing: if it appears in the deactivated right-column, again activate it by selecting and using the green-button to move it into the left-column.
                                      You might need to activate the toolbar from the separate Toolbar list...
                                      It should then load and be active every time SketchUp starts...
                                      • N Offline
                                        namelessone
                                        Sadly, that's not it
                                          How about sharing the SKP file so we can see what happens?
                                            rv1974
                                            There are some areas in your printscreen that couldn't get rounded even theoretically.
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 50
                                            • 73
                                            • 74
                                            • 48 / 74
