    1.5k Posts 478 Posters 4.3m Views 478 Watching
    • C
      chowette
      @fredo6 said:
      I think on Linux, the problem may come from the order of loading.
      Yes this is the problem, if I run
      load "Fredo6_Roundcorner.rb"
      in the console, it runs ok.
      @fredo6 said:
      So the best is to delete the file Fredo6_Roundcorner.rb (and thus run without security mode).
      that does nothing; eg. no error, but no plugins loaded either.
      I have fixed it by requiring explicitly libFredo6 before using it.
      here is my Fredo6_Roundcorner.rb
      =begin
      # Copyright © 2015 Fredo6 - Designed and written August 2011 by Fredo6
      # Permission to use this software for any purpose and without fee is hereby granted
      # Distribution of this software for commercial purpose is subject to;
      #  - the expressed, written consent of the author
      #  - the inclusion of the present copyright notice in all copies.
      # THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
      # IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
      # WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      # Description	;  Generic top loader for LibFredo6-compliant scripts.
      # This file does checking on the environment for correct installation of LibFredo6 and the script itself
      # The file is identical for all my plugins relying on LibFredo6
      =end
      require 'sketchup.rb'
      require 'extensions.rb'
      require 'Fredo6_!LibFredo6.rb'  # explicit call to fix loading order under wine on linux
      module Fredo6
      if defined?(LibFredo6.top_load)
      	hsh_ext, plugin, ext = LibFredo6.top_load(__FILE__, true)
      	if hsh_ext && plugin && !ext
      		ext = SketchupExtension.new hsh_ext[;name], hsh_ext[;floader]
      		ext.creator = hsh_ext[;creator]
      		ext.description = hsh_ext[;description]
      		ext.version = hsh_ext[;version]
      		ext.copyright = hsh_ext[;copyright]
      		status = Sketchup.register_extension ext, true
      		plugin.load_finalize ext
      else
      	UI.messagebox "You must install LibFredo6 version 6.9 or higher to run #{File.basename(__FILE__, ".rb")}"
      end	#module Fredo6
      note sure if it is the right thing to do...
      Chowette
      • P
        pmgbubolz
        Plugin is extremely useful! But it would be even more powerful if allow different values for angles.
        Any possibility to add this functionality?
        • K
          keyudits
          Im running into an issue where I am trying to smooth out the tops, corners and bottoms of an interior rectangle, (think, bathtub.) but when I execute it appears as though the program just fills in the interior space.
          I have had good luck with interior and exterior corners, just not combining edges and corners..any suggestions?
          • BoxB
            Do you mean like this?
            Round corner will often fill in faces and you just need to remove them.
            • N
              numerobis
              @numerobis said:
              The edges are showing up correctly (hard edges) but the shading is messed up in display and rendering.
              I have to use the smoothing controls after the beveling and set it to hard egdes again to get this fixed.
              Any chance to get this fixed? Here is an example how it looks like in SU. Just like smoothing >45° + hard edges.
              The left cube is the direct result of the beveling. The right one is the same model with corrected normals (0°).
              https://abload.de/img/chamfer017fu3y.png
              (The lighting is the same)
              • C
                cowboyathome
                Fredo, is this an unavoidable side effect which can't be fixed?
                • K
                  keyudits
                  yes! didnt think to try that. I appreciate the speedy response.
                  • W
                    whitelock
                    Hi any ideas what combination of edge filters i need on round corner in order to just see the border lines. look at the image. On the left is how I would like to see it on the right is the best I can get and I end up having to do loads of clean up. any help greatly appreciated
                    • BoxB
                      Could you attach that model so we can look at it, as I can't replicate your problem.
                      • deaneauD
                        deaneau
                        @whitelock
                        Try to select your lines and then use hide (from context-menu)
                        • fredo6F
                          NEW RELEASE: RoundCorner v3.1b - 04 Sep 16
                          RoundCorner 3.1b is a maintenance release. It fixes a bug preventing to make a sphere and a dome from a cube, as shown in the video below.
                          • pep75P
                            pep75
                            Great Fredo!!! Thanks!
                            • sicksickisckS
                              sicksickisck
                              hmm 3.1b so You mean there are no overlaps problem now ?!
                              • fredo6F
                                Actually overlaps are just detected and signaled (since v3.0). But you need to sort out the issue in the model (reducing the offset or modifying the model).
                                  Thanks for the updates Fredo. You do marvelous work.
                                  • sicksickisckS
                                    sicksickisck
                                    yep; thanks for the plugin anyway;
                                    • B
                                      Ben Ritter
                                      Thank you Fredo!
                                      • L
                                        LucasBarbos4
                                        Wow. Thanks for this Fredo.
                                        • P
                                          pedrinalex
                                          Many Thanks Freddo ¡¡¡
                                          MB ASUS x99M-WS, Xeon e5 2695 v3, 64 GB RAM 2400, 2x gforce gtx 1060, 1 SSDH 1 tb & 3 HD 1 TB c/u
                                            rolopolo
                                            roundcorner will not work! i cant get the palette to load.
                                            i have installed roundcorner via the extension store.
                                            all other fredo tools are working correctly
                                            libfredo6 is all up to date
                                            the footprint is correct - see upload attach
                                            win10 sketchup2016pro
                                            I cant think what to try next after reinstalling multiple times
                                            Can anybody help?
                                            thanks
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 74
                                            • 75
                                            • 56 / 75
