    1.5k Posts 477 Posters 4.2m Views 477 Watching
    • N
      numerobis
      @numerobis said:
      The edges are showing up correctly (hard edges) but the shading is messed up in display and rendering.
      I have to use the smoothing controls after the beveling and set it to hard egdes again to get this fixed.
      Any chance to get this fixed? Here is an example how it looks like in SU. Just like smoothing >45° + hard edges.
      The left cube is the direct result of the beveling. The right one is the same model with corrected normals (0°).
      https://abload.de/img/chamfer017fu3y.png
      (The lighting is the same)
      • C
        cowboyathome
        @box said:
        Do you mean like this?
        Round corner will often fill in faces and you just need to remove them.
        Fredo, is this an unavoidable side effect which can't be fixed?
        • K
          keyudits
          yes! didnt think to try that. I appreciate the speedy response.
          • W
            whitelock
            Hi any ideas what combination of edge filters i need on round corner in order to just see the border lines. look at the image. On the left is how I would like to see it on the right is the best I can get and I end up having to do loads of clean up. any help greatly appreciated
            • BoxB
              Could you attach that model so we can look at it, as I can't replicate your problem.
              • deaneauD
                deaneau
                @whitelock
                Try to select your lines and then use hide (from context-menu)
                • fredo6F
                  NEW RELEASE: RoundCorner v3.1b - 04 Sep 16
                  RoundCorner 3.1b is a maintenance release. It fixes a bug preventing to make a sphere and a dome from a cube, as shown in the video below.
                  • pep75P
                    pep75
                    Great Fredo!!! Thanks!
                    • sicksickisckS
                      sicksickisck
                      hmm 3.1b so You mean there are no overlaps problem now ?!
                      • fredo6F
                        Actually overlaps are just detected and signaled (since v3.0). But you need to sort out the issue in the model (reducing the offset or modifying the model).
                          Thanks for the updates Fredo. You do marvelous work.
                          • sicksickisckS
                            sicksickisck
                            yep; thanks for the plugin anyway;
                            • B
                              Ben Ritter
                              Thank you Fredo!
                              • L
                                LucasBarbos4
                                Wow. Thanks for this Fredo.
                                • P
                                  pedrinalex
                                  Many Thanks Freddo ¡¡¡
                                  MB ASUS x99M-WS, Xeon e5 2695 v3, 64 GB RAM 2400, 2x gforce gtx 1060, 1 SSDH 1 tb & 3 HD 1 TB c/u
                                    rolopolo
                                    roundcorner will not work! i cant get the palette to load.
                                    i have installed roundcorner via the extension store.
                                    all other fredo tools are working correctly
                                    libfredo6 is all up to date
                                    the footprint is correct - see upload attach
                                    win10 sketchup2016pro
                                    I cant think what to try next after reinstalling multiple times
                                    Can anybody help?
                                    thanks
                                    • N
                                      namelessone
                                      Hey fredo,
                                      I'm having difficulties with getting round corners correct on some edges of my model. To make things simpler, I can provide screenshots of selected problematic edges and .skp file of model part I'm working on. Is it just limitation or perhaps plugin is confused?
                                      http://tonic-art.com/round1.jpg
                                      http://tonic-art.com/round2.jpg
                                      http://tonic-art.com/round.skp
                                      • gillesG
                                        gilles
                                        First thing, SU does not manage too small faces; so make your part a component, create a copy, scale up the copy X1000, work on the copy.
                                          Can anybody help?
                                          thanks
                                          According to your screenshot you have round Corner disabled by the addition of ! to the file extension. Try changing it to just .rb
                                            @rolopolo
                                            Somehow you have disabled the Fredo6_RoundCorner .RB file.
                                            It is listed a an .RB! file, which mean it is disabled using the SketchUcation Plugins Manager, therefore it will not load as SketchUp starts.
                                            In SketchUp open the SketchUcation Plugins Manager, in the right-hand column are the disabled plugins.
                                            Select the RoundCorner one and use the Green button to move it into the enabled left-hand column.
                                            Because of the nature of Fredo's tools and his Lib [which should also be enabled/active] you are best off closing SketchUp and restarting.
                                            That way everything will be registered properly.
                                            Since it is an Extension it might be deactivated and at this point not add menu of toolbar entries, so you should then check the SketchUcation Extensions Manager's listing: if it appears in the deactivated right-column, again activate it by selecting and using the green-button to move it into the left-column.
                                            You might need to activate the toolbar from the separate Toolbar list...
                                            It should then load and be active every time SketchUp starts...
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 74
                                            • 75
                                            • 56 / 75
