    1.5k Posts 477 Posters 4.2m Views 477 Watching
    • C
      chowette
      I am having the same issue here.
      It does work ok on my laptop with Win7 and SU2016 and only libfredo and round corner.
      But on my linux box under wine with both libfredo and roundcorner, it does show the same error message as _reinhart asking for libfredo...
      Is there a debug flag somewhere to get some details in the ruby console? Maybe something else i can try to give you a more detailed error report. As a software dev, I can help you debug this, but with some guidance because I am not familiar with ruby.
      chowette
      • fredo6F
        I think on Linux, the problem may come from the order of loading.
        So the best is to delete the file Fredo6_Roundcorner.rb (and thus run without security mode).
        • C
          chowette
          Yes this is the problem, if I run
          load "Fredo6_Roundcorner.rb"
          in the console, it runs ok.
          that does nothing; eg. no error, but no plugins loaded either.
          I have fixed it by requiring explicitly libFredo6 before using it.
          here is my Fredo6_Roundcorner.rb
          =begin
          # Copyright © 2015 Fredo6 - Designed and written August 2011 by Fredo6
          # Permission to use this software for any purpose and without fee is hereby granted
          # Distribution of this software for commercial purpose is subject to;
          #  - the expressed, written consent of the author
          #  - the inclusion of the present copyright notice in all copies.
          # THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
          # IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
          # WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
          # Description	;  Generic top loader for LibFredo6-compliant scripts.
          # This file does checking on the environment for correct installation of LibFredo6 and the script itself
          # The file is identical for all my plugins relying on LibFredo6
          =end
          require 'sketchup.rb'
          require 'extensions.rb'
          require 'Fredo6_!LibFredo6.rb'  # explicit call to fix loading order under wine on linux
          module Fredo6
          if defined?(LibFredo6.top_load)
          	hsh_ext, plugin, ext = LibFredo6.top_load(__FILE__, true)
          	if hsh_ext && plugin && !ext
          		ext = SketchupExtension.new hsh_ext[;name], hsh_ext[;floader]
          		ext.creator = hsh_ext[;creator]
          		ext.description = hsh_ext[;description]
          		ext.version = hsh_ext[;version]
          		ext.copyright = hsh_ext[;copyright]
          		status = Sketchup.register_extension ext, true
          		plugin.load_finalize ext
          else
          	UI.messagebox "You must install LibFredo6 version 6.9 or higher to run #{File.basename(__FILE__, ".rb")}"
          end	#module Fredo6
          note sure if it is the right thing to do...
          Chowette
          • P
            pmgbubolz
            Plugin is extremely useful! But it would be even more powerful if allow different values for angles.
            Any possibility to add this functionality?
            • K
              keyudits
              Im running into an issue where I am trying to smooth out the tops, corners and bottoms of an interior rectangle, (think, bathtub.) but when I execute it appears as though the program just fills in the interior space.
              I have had good luck with interior and exterior corners, just not combining edges and corners..any suggestions?
              • BoxB
                Do you mean like this?
                Round corner will often fill in faces and you just need to remove them.
                • N
                  numerobis
                  @numerobis said:
                  The edges are showing up correctly (hard edges) but the shading is messed up in display and rendering.
                  I have to use the smoothing controls after the beveling and set it to hard egdes again to get this fixed.
                  Any chance to get this fixed? Here is an example how it looks like in SU. Just like smoothing >45° + hard edges.
                  The left cube is the direct result of the beveling. The right one is the same model with corrected normals (0°).
                  https://abload.de/img/chamfer017fu3y.png
                  (The lighting is the same)
                  • C
                    cowboyathome
                    Fredo, is this an unavoidable side effect which can't be fixed?
                    • K
                      keyudits
                      yes! didnt think to try that. I appreciate the speedy response.
                      • W
                        whitelock
                        Hi any ideas what combination of edge filters i need on round corner in order to just see the border lines. look at the image. On the left is how I would like to see it on the right is the best I can get and I end up having to do loads of clean up. any help greatly appreciated
                        • BoxB
                          Could you attach that model so we can look at it, as I can't replicate your problem.
                          • deaneauD
                            deaneau
                            @whitelock
                            Try to select your lines and then use hide (from context-menu)
                            • fredo6F
                              NEW RELEASE: RoundCorner v3.1b - 04 Sep 16
                              RoundCorner 3.1b is a maintenance release. It fixes a bug preventing to make a sphere and a dome from a cube, as shown in the video below.
                              • pep75P
                                pep75
                                Great Fredo!!! Thanks!
                                • sicksickisckS
                                  sicksickisck
                                  hmm 3.1b so You mean there are no overlaps problem now ?!
                                  • fredo6F
                                    Actually overlaps are just detected and signaled (since v3.0). But you need to sort out the issue in the model (reducing the offset or modifying the model).
                                      Thanks for the updates Fredo. You do marvelous work.
                                      • sicksickisckS
                                        sicksickisck
                                        yep; thanks for the plugin anyway;
                                        • B
                                          Ben Ritter
                                          Thank you Fredo!
                                          • L
                                            LucasBarbos4
                                            Wow. Thanks for this Fredo.
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 74
                                            • 75
                                            • 56 / 75
