    Animator Gallery
    renderpluginsextensions
    106 Posts 30 Posters 486.7k Views 30 Watching
      • ntxdaveN Offline
        ntxdave
        Nice Rick - I like this one. Bet it would look good in a rendered version so the paint could take on a bit of a metallic look.
        Press F1...thank me later
        • F Offline
          fluid
          Forklift animation with SketchFX using AmbientOcclusion integration:
          [flash 640,480:3e6jsrr6]https://www.youtube.com/v/WeFZ08I3TD8[/flash:3e6jsrr6]
          • ntxdaveN Offline
            ntxdave
            Car Wash - Pendulum with sprays
            • TwilightRenderT Offline
              TwilightRender
              Here is the forklift demo rendered in Twilight Render with SketchUp screenshot overlay. I believe support for Twilight Render animation rendering should be in the next version ( > 1.0v) We will post soon an installer (for Windows at first) for Twilight Render V2 Pro that supports Animator inter-operation for beta testers to try it out (this will be a Pro feature). Again, it will require both an update from Animator and TWR, which should be available pretty soon.
              • ntxdaveN Offline
                ntxdave
                Even though I do not have a Twilight Pro license, I am exciting announcement and hope that some Pro users will post some samples.
                • ntxdaveN Offline
                  ntxdave
                  @Falstaff, if you edit your post and remove the "s" and just make it http:// in the URLthen the videos will show up inline.
                  • F Offline
                    Falstaff
                    Just tested the new tracking camera movement.
                    Vehicle POV
                    Cyclist POV
                    • ntxdaveN Offline
                      ntxdave
                      @Falstaff I really like you examples of the camera following an object. I am going to work on one for learning purposes but I think you have a perfect example.
                      • F Offline
                        faust07
                        @Falstaff: this are really impressing examples for the use of Animator. The walking and gesturing people are well made. The SketchUp design is simple and clear.
                          click to watch....
                          interesting that TIG SKMtools works with Animator.
                          • JQLJ Offline
                            JQL
                            Could you try rendering that with Thea Rich? Please?
                            www.casca.pt
                            Visit us on facebook!
                              No point. The image sequence plays in the viewport so it would not sync with the frame rate.
                              Only direct viewport recording would work.
                              • JQLJ Offline
                                JQL
                                Ok, thanks! Then I guess I'll wait for other kind of implementation...
                                I've got a certain project wich would really benefit from texture animation, particularly .exr/.hdr files for animated hdri skies.
                                Alas, I will probably learn Unreal engine someday.
                                www.casca.pt
                                  Unreal is some more difficult than Unity! πŸ˜‰
                                  • JQLJ Offline
                                    JQL
                                    I've seen nicer images from Unreal than Unity. Basically, lighting is better. However I've heard something about Unity having revamped their lighting... Why is it easier?
                                    www.casca.pt
                                    • ntxdaveN Offline
                                      ntxdave
                                      So, are you saying this would not work with Animator or was you animation generated with Animator?
                                        I'm saying to only way to capture the animated texture is to record the viewport.
                                        Exporting the animation won't export the animation applied with SKMtools.
                                        • ntxdaveN Offline
                                          ntxdave
                                          That is what I thought you were saying. What did you use to create the animated gif?
                                            It's not a gif. It's an image sequence of pngs.
                                            If you google fire image sequence you get a result for them at opengameart
                                            You could even try for water spray to see if you can find something for your car wash
                                            • 3 / 6
