    [Plugin] Selection Memory
    39 Posts 17 Posters 24.6k Views 17 Watching
      Ben Ritter
      Sweet! Thank you so much, again.
      • john2J Offline
        john2
        thanks a llllot thomthom..great plugin. saves a lot of time during accidents 😉
        http://i.imgur.com/aTTyR.jpg
        Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
        • EarthMoverE Offline
          EarthMover
          Thanks bro for this great tool. I've always enjoyed having the selection in the undo stack with 3ds Max, now it's possible in sketchup as well! You deserve a chocolate fudge covered peanut butter chocolate chip cookie with oreo filling!
          Content Creator at Skapeup
            http://www.talknerdytomelover.com/storage/drooling_homer.gif?__SQUARESPACE_CACHEVERSION=1286480521201
            • StinkieS Offline
              Stinkie
              Thanks, Thom. Most useful. 👍
              • halroachH Offline
                halroach
                Thanks Thom!
                You could add it to your already marvelous set of tools in 'selection toys'.
                That's it!
                I'm all out of keys on my keyboard for another shortcut for such a good tool. either I scrap some short cut I barely use, or I'll bump it up to them less used Shift+ and Ctrl+ shortcuts 😉
                FlexTools - Super Quick Windows, Doors, Slats...
                • V Offline
                  victor hugo
                  Buenos Dias.
                  If I want to revert the "selection_stack size" to default which number would be; or by removing the plugin it will go back to default?
                  Thanks.
                    If you reinstall then it would revert back, yes.
                    • gonashviliG Offline
                      gonashvili
                      This be them bombz.
                      Big up yourself, sir, etc.... 😄
                        AtefZ
                        Hello
                        Please how can I modify this constant: SELECTION_STACK_SIZE ? 😎
                        Thanks 🤓
                          You'd have to open the RB file in a text editor and change it.
                            AtefZ
                            Thanks Mister Thomthom, I tried that and when I opended the file (tt_selection_memory-1.1.0.rbz) with a notepad as a text editor it shows me that somthing like that :
                            "...‚e[.òÈÄ4úõå‡wK?\¾…Z^MHxDËv·ñ;öOã.h†îm¤Ë*Êс04a8Ûd&U´9ynV+ÒP«0 CLú5:i Ÿ9eÎÁÛôˆÌ¤G¾M˜÷‰..."
                              RBZ files are really ZIP files. They are used to package the extension for distribution - but are unpacked when installed into the Plugins folder. Either you need to find the rb file in the Plugins folder and edit that. Or extract it manually and edit the RB file.
                                AtefZ
                                I made it finally 😉 Thanks a lot!
                                • X Offline
                                  Xenobe
                                  Thanks!!, Says The fella with 4 thumbs & 2 happy trigger fingers.
                                  • jgbJ Offline
                                    jgb
                                    OK, I'm a bit dumb..... 😕
                                    Exactly how do I cycle back through the selections? 😳
                                    I mean what buttons do I press?
                                    It is installed and active.
                                    jgb
                                    • filibisF Offline
                                      filibis
                                      You select couple of entities and make an 'accidental' left click to empty space, then retrieve the previous selection via Edit > Cycle Previous Selections (up to 5 times)
                                      But I suggest checking this plugin for more advanced selection features: Selection Manager
                                      • jgbJ Offline
                                        jgb
                                        Thanks. A bit tedious going that route, so I made the "Q" key a shortcut.
                                        jgb
                                        • 2 / 2
