    [Plugin] Selection Memory
    39 Posts 17 Posters 26.3k Views 17 Watching
    • halroachH Offline
      halroach
      Thanks Thom!
      You could add it to your already marvelous set of tools in 'selection toys'.
      That's it!
      I'm all out of keys on my keyboard for another shortcut for such a good tool. either I scrap some short cut I barely use, or I'll bump it up to them less used Shift+ and Ctrl+ shortcuts 😉
      FlexTools - Super Quick Windows, Doors, Slats...
      • V Offline
        victor hugo
        Buenos Dias.
        If I want to revert the "selection_stack size" to default which number would be; or by removing the plugin it will go back to default?
        Thanks.
          If you reinstall then it would revert back, yes.
          • gonashviliG Offline
            gonashvili
            This be them bombz.
            Big up yourself, sir, etc.... 😄
              AtefZ
              Hello
              Please how can I modify this constant: SELECTION_STACK_SIZE ? 😎
              Thanks 🤓
                You'd have to open the RB file in a text editor and change it.
                  AtefZ
                  Thanks Mister Thomthom, I tried that and when I opended the file (tt_selection_memory-1.1.0.rbz) with a notepad as a text editor it shows me that somthing like that :
                  "...‚e[.òÈÄ4úõå‡wK?\¾…Z^MHxDËv·ñ;öOã.h†îm¤Ë*Êс04a8Ûd&U´9ynV+ÒP«0 CLú5:i Ÿ9eÎÁÛôˆÌ¤G¾M˜÷‰..."
                    RBZ files are really ZIP files. They are used to package the extension for distribution - but are unpacked when installed into the Plugins folder. Either you need to find the rb file in the Plugins folder and edit that. Or extract it manually and edit the RB file.
                      AtefZ
                      I made it finally 😉 Thanks a lot!
                      • X Offline
                        Xenobe
                        Thanks!!, Says The fella with 4 thumbs & 2 happy trigger fingers.
                        • jgbJ Offline
                          jgb
                          OK, I'm a bit dumb..... 😕
                          Exactly how do I cycle back through the selections? 😳
                          I mean what buttons do I press?
                          It is installed and active.
                          jgb
                          • filibisF Offline
                            filibis
                            You select couple of entities and make an 'accidental' left click to empty space, then retrieve the previous selection via Edit > Cycle Previous Selections (up to 5 times)
                            But I suggest checking this plugin for more advanced selection features: Selection Manager
                            • jgbJ Offline
                              jgb
                              Thanks. A bit tedious going that route, so I made the "Q" key a shortcut.
                              jgb
                              • 2 / 2
