    [Plugin] Selection Memory
    39 Posts 17 Posters 27.6k Views 17 Watching
    • andybotA
      andybot
      Thanks Thomthom 👍 👍
      works as expected for me!
        Version 1.0.1
        Did a quick tweak to it. I believe it should retrieve the previous selection more predictably now.
        • massimoM
          massimo Moderator
          Now it seems to work just fine. 👍 👍
          • john2J
            john2
            yeeeeeeeeeaaa
            http://vitalogics.net/wp-content/uploads/2011/02/pic_excited_man.jpg
            Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
            • B
              Ben Ritter
              Sweet! Thank you so much, again.
              • john2J
                john2
                thanks a llllot thomthom..great plugin. saves a lot of time during accidents 😉
                http://i.imgur.com/aTTyR.jpg
                • EarthMoverE
                  EarthMover
                  Thanks bro for this great tool. I've always enjoyed having the selection in the undo stack with 3ds Max, now it's possible in sketchup as well! You deserve a chocolate fudge covered peanut butter chocolate chip cookie with oreo filling!
                  Content Creator at Skapeup
                    http://www.talknerdytomelover.com/storage/drooling_homer.gif?__SQUARESPACE_CACHEVERSION=1286480521201
                    • StinkieS
                      Stinkie
                      Thanks, Thom. Most useful. 👍
                      • halroachH
                        halroach
                        Thanks Thom!
                        You could add it to your already marvelous set of tools in 'selection toys'.
                        That's it!
                        I'm all out of keys on my keyboard for another shortcut for such a good tool. either I scrap some short cut I barely use, or I'll bump it up to them less used Shift+ and Ctrl+ shortcuts 😉
                        FlexTools - Super Quick Windows, Doors, Slats...
                        • V
                          victor hugo
                          Buenos Dias.
                          If I want to revert the "selection_stack size" to default which number would be; or by removing the plugin it will go back to default?
                          Thanks.
                            If you reinstall then it would revert back, yes.
                            • gonashviliG
                              gonashvili
                              This be them bombz.
                              Big up yourself, sir, etc.... 😄
                                AtefZ
                                Hello
                                Please how can I modify this constant: SELECTION_STACK_SIZE ? 😎
                                Thanks 🤓
                                  You'd have to open the RB file in a text editor and change it.
                                    AtefZ
                                    Thanks Mister Thomthom, I tried that and when I opended the file (tt_selection_memory-1.1.0.rbz) with a notepad as a text editor it shows me that somthing like that :
                                    "...‚e[.òÈÄ4úõå‡wK?\¾…Z^MHxDËv·ñ;öOã.h†îm¤Ë*Êс04a8Ûd&U´9ynV+ÒP«0 CLú5:i Ÿ9eÎÁÛôˆÌ¤G¾M˜÷‰..."
                                      RBZ files are really ZIP files. They are used to package the extension for distribution - but are unpacked when installed into the Plugins folder. Either you need to find the rb file in the Plugins folder and edit that. Or extract it manually and edit the RB file.
                                        AtefZ
                                        I made it finally 😉 Thanks a lot!
                                        • X
                                          Xenobe
                                          Thanks!!, Says The fella with 4 thumbs & 2 happy trigger fingers.
                                          • jgbJ
                                            jgb
                                            OK, I'm a bit dumb..... 😕
                                            Exactly how do I cycle back through the selections? 😳
                                            I mean what buttons do I press?
                                            It is installed and active.
                                            jgb
                                            • 2 / 2
