    [Plugin] Selection Memory
    39 Posts 17 Posters 27.1k Views 17 Watching
    • gonashviliG Offline
      gonashvili
      This be them bombz.
      Big up yourself, sir, etc.... 😄
        AtefZ
        Hello
        Please how can I modify this constant: SELECTION_STACK_SIZE ? 😎
        Thanks 🤓
          You'd have to open the RB file in a text editor and change it.
            AtefZ
            Thanks Mister Thomthom, I tried that and when I opended the file (tt_selection_memory-1.1.0.rbz) with a notepad as a text editor it shows me that somthing like that :
            "...‚e[.òÈÄ4úõå‡wK?\¾…Z^MHxDËv·ñ;öOã.h†îm¤Ë*Êс04a8Ûd&U´9ynV+ÒP«0 CLú5:i Ÿ9eÎÁÛôˆÌ¤G¾M˜÷‰..."
              RBZ files are really ZIP files. They are used to package the extension for distribution - but are unpacked when installed into the Plugins folder. Either you need to find the rb file in the Plugins folder and edit that. Or extract it manually and edit the RB file.
                AtefZ
                I made it finally 😉 Thanks a lot!
                • X Offline
                  Xenobe
                  Thanks!!, Says The fella with 4 thumbs & 2 happy trigger fingers.
                  • jgbJ Offline
                    jgb
                    OK, I'm a bit dumb..... 😕
                    Exactly how do I cycle back through the selections? 😳
                    I mean what buttons do I press?
                    It is installed and active.
                    jgb
                    • filibisF Offline
                      filibis
                      You select couple of entities and make an 'accidental' left click to empty space, then retrieve the previous selection via Edit > Cycle Previous Selections (up to 5 times)
                      But I suggest checking this plugin for more advanced selection features: Selection Manager
                      • jgbJ Offline
                        jgb
                        Thanks. A bit tedious going that route, so I made the "Q" key a shortcut.
                        jgb
                        • 2 / 2
