    [Plugin] Selection Memory
    39 Posts 17 Posters 27.1k Views 17 Watching
    • massimoM Offline
      massimo Moderator
      Ok, no problem. 😄
      • andybotA Offline
        andybot
        Thanks Thomthom 👍 👍
        works as expected for me!
          Version 1.0.1
          Did a quick tweak to it. I believe it should retrieve the previous selection more predictably now.
          • massimoM Offline
            massimo Moderator
            Now it seems to work just fine. 👍 👍
            • john2J Offline
              john2
              yeeeeeeeeeaaa
              http://vitalogics.net/wp-content/uploads/2011/02/pic_excited_man.jpg
              Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                Ben Ritter
                Sweet! Thank you so much, again.
                • john2J Offline
                  john2
                  thanks a llllot thomthom..great plugin. saves a lot of time during accidents 😉
                  http://i.imgur.com/aTTyR.jpg
                  • EarthMoverE Offline
                    EarthMover
                    Thanks bro for this great tool. I've always enjoyed having the selection in the undo stack with 3ds Max, now it's possible in sketchup as well! You deserve a chocolate fudge covered peanut butter chocolate chip cookie with oreo filling!
                    Content Creator at Skapeup
                      http://www.talknerdytomelover.com/storage/drooling_homer.gif?__SQUARESPACE_CACHEVERSION=1286480521201
                      • StinkieS Offline
                        Stinkie
                        Thanks, Thom. Most useful. 👍
                        • halroachH Offline
                          halroach
                          Thanks Thom!
                          You could add it to your already marvelous set of tools in 'selection toys'.
                          That's it!
                          I'm all out of keys on my keyboard for another shortcut for such a good tool. either I scrap some short cut I barely use, or I'll bump it up to them less used Shift+ and Ctrl+ shortcuts 😉
                          FlexTools - Super Quick Windows, Doors, Slats...
                          • V Offline
                            victor hugo
                            Buenos Dias.
                            If I want to revert the "selection_stack size" to default which number would be; or by removing the plugin it will go back to default?
                            Thanks.
                              If you reinstall then it would revert back, yes.
                              • gonashviliG Offline
                                gonashvili
                                This be them bombz.
                                Big up yourself, sir, etc.... 😄
                                  AtefZ
                                  Hello
                                  Please how can I modify this constant: SELECTION_STACK_SIZE ? 😎
                                  Thanks 🤓
                                    You'd have to open the RB file in a text editor and change it.
                                      AtefZ
                                      Thanks Mister Thomthom, I tried that and when I opended the file (tt_selection_memory-1.1.0.rbz) with a notepad as a text editor it shows me that somthing like that :
                                      "...‚e[.òÈÄ4úõå‡wK?\¾…Z^MHxDËv·ñ;öOã.h†îm¤Ë*Êс04a8Ûd&U´9ynV+ÒP«0 CLú5:i Ÿ9eÎÁÛôˆÌ¤G¾M˜÷‰..."
                                        RBZ files are really ZIP files. They are used to package the extension for distribution - but are unpacked when installed into the Plugins folder. Either you need to find the rb file in the Plugins folder and edit that. Or extract it manually and edit the RB file.
                                          AtefZ
                                          I made it finally 😉 Thanks a lot!
                                          • X Offline
                                            Xenobe
                                            Thanks!!, Says The fella with 4 thumbs & 2 happy trigger fingers.
                                            • 2 / 2
