    [Plugin] Selection Memory
    39 Posts 17 Posters 27.6k Views 17 Watching
    • V
      victor hugo
      Buenos Dias.
      If I want to revert the "selection_stack size" to default which number would be; or by removing the plugin it will go back to default?
      Thanks.
        If you reinstall then it would revert back, yes.
        • gonashviliG
          gonashvili
          This be them bombz.
          Big up yourself, sir, etc.... 😄
            AtefZ
            Hello
            Please how can I modify this constant: SELECTION_STACK_SIZE ? 😎
            Thanks 🤓
              You'd have to open the RB file in a text editor and change it.
                AtefZ
                Thanks Mister Thomthom, I tried that and when I opended the file (tt_selection_memory-1.1.0.rbz) with a notepad as a text editor it shows me that somthing like that :
                "...‚e[.òÈÄ4úõå‡wK?\¾…Z^MHxDËv·ñ;öOã.h†îm¤Ë*Êс04a8Ûd&U´9ynV+ÒP«0 CLú5:i Ÿ9eÎÁÛôˆÌ¤G¾M˜÷‰..."
                  RBZ files are really ZIP files. They are used to package the extension for distribution - but are unpacked when installed into the Plugins folder. Either you need to find the rb file in the Plugins folder and edit that. Or extract it manually and edit the RB file.
                    AtefZ
                    I made it finally 😉 Thanks a lot!
                    • X
                      Xenobe
                      Thanks!!, Says The fella with 4 thumbs & 2 happy trigger fingers.
                      • jgbJ
                        jgb
                        OK, I'm a bit dumb..... 😕
                        Exactly how do I cycle back through the selections? 😳
                        I mean what buttons do I press?
                        It is installed and active.
                        jgb
                        • filibisF
                          filibis
                          You select couple of entities and make an 'accidental' left click to empty space, then retrieve the previous selection via Edit > Cycle Previous Selections (up to 5 times)
                          But I suggest checking this plugin for more advanced selection features: Selection Manager
                          • jgbJ
                            jgb
                            Thanks. A bit tedious going that route, so I made the "Q" key a shortcut.
                            jgb
                            • 2 / 2
