    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.1m Views 79 Watching
    • olisheaO Offline
      olishea
      Yes and about a half second in Wings 3D (which is pretty much redundant) and a half second in meshlab. SU is really bad at subdivision times; makes you wonder if you can integrate a subdivision app via a plugin so that SU doesn't even have to calculate the subdivision at all.
      oli
        At the moment; no. The current API require me to generate new model entities in the model DOM. Where as the ideal way would be to be able to override the viewport presentation of an object. Basically highjack the render-pipeline for a given object. That would allowed me to avoid the biggest bottleneck: generating SU entities which each needs to merge with each other for the special SU stickyness.
        The SU magic isn't ideal for extensions like SUbD where you aren't supposed to be editing the final result in the viewport. Had SU known only about the control mesh then any tool could edit the mesh while the viewport displayed the subdivided result.
        • olisheaO Offline
          olishea
          You explain things better than I do! ๐Ÿ˜„
          This is what I mean; is there a way to show the subdivided mesh in a small window that runs real-time with the SU model?
          You would simply play with the control mesh in SU and a window shows a subdivided version that moves in real time with the SU model? When you rotate, zoom and orbit the subdivided "render" does so too.
          Then when you are happy you can do the final subdivision inside SU right at the end.
          oli
            Oh, well, that surely is the next thing I'd poke into once OpenSubdiv is implemented! I was thinking of it in two stages:
            1. A preview window on the side.
            2. Make the background of that preview window transparent and overlay it the SU viewport. (not sure how well that'll work since it'd be a separate 3d spacxe on top of SU's view...)
            • olisheaO Offline
              olishea
              Nice!!
              I thought I was talking jibber jabber but you catch my drift! ๐Ÿ˜‰
              Can't you already do something similar with Maxwell? It renders a subdivided version of your control mesh? I'm not maxwell user so unsure. Also needs to be realtime, simple shader.
              If you could switch between SU viewport and a SubD render overlay that would be better.....kinda like Thea where you can see the render in the viewport. If you could press a hotkey and the screen changes to the subdivided render that would be a total game changer for SU.
              Even if it was a preview window I would be happy to be fair.
              oli
                Yea I wonder if I saw a YouTube video on that. Though I'm not a Maxwell user...
                • N Offline
                  numerobis
                  Please, no separate window! ๐Ÿ˜ฎ
                  Yes, Maxwell has render time subdivision. It's not a shader, it's a modifier, that produces real subdivision geometry.
                  http://support.nextlimit.com/display/mxdocsv3/Pixar+OpenSubdiv
                    Not much way around that - since the SU API doesn't give access to the pipe-line. It'd off course be optional to use it.
                    • Z Offline
                      ZahariStoyanov
                      Not quite sure where to post this but, since I'll be applying SubD on it, I'll ask here: any ideas how to fix the topology of the red section in this model?
                      Benz+190+Evo.skp
                      • ely862meE Offline
                        ely862me
                        Maybe add another loop.
                        original
                        Elisei (sketchupper)
                        Come and See EliseiDesign
                        • Z Offline
                          ZahariStoyanov
                          My biggest concern is the rear glass' frame - the corner looks a bit weird when I subdivide it because the ring from there goes along the roof all the way to the front instead of connecting somehow to the door's corner or something. I mean, I'm trying to solve the way I did on the corresponding front section(A-pillar?) ๐Ÿ˜•
                          • Z Offline
                            ZahariStoyanov
                            Fixed! I color-coded the problematic section again so I can better explain what was running through my head: I'm looking at the whole front-to-back edge as a group of rings that go along through the whole car. The issues shown on the "before" picture caused the corners between the roof and the C-pillar to kind of flick open. Now that I rearranged those rings and added a little extrusion to all contours, the problem's gone ๐Ÿ˜„
                            Before:
                            After:
                            Smooth:
                              cuttingedge
                              @alsomar said:
                              Well, here comes mine:
                              http://imagizer.imageshack.us/v2/xq90/923/lQPbJA.jpg
                              and after a little bit of Thea and Photoshop, this is the result:
                              http://imagizer.imageshack.us/v2/xq90/924/FVT3MO.jpg
                              Very clean high poly modeling!
                                Images doesn't seem to load on my end. (IMO it's better to upload to the forum instead of hot-linking.)
                                • cottyC Offline
                                  cotty
                                  It's Spanish and I don't see the images too.
                                  my SketchUp gallery
                                  • garydornG Offline
                                    garydorn
                                    I found this subdivision tips
                                    http://blog.whiteblaizer.com/2009/03/subdivision-tips-hard-surface-modelling-iv/
                                    not sure of the language - might be Italian.
                                    here is the index page
                                    http://blog.whiteblaizer.com/tutorials/
                                    Hope it helps.
                                    [img]http://blog.whiteblaizer.com/wp-content/uploads/2009/03/sdm04_05.jpg[/img]
                                    [img]http://blog.whiteblaizer.com/wp-content/uploads/2009/03/sdm04_04.jpg[/img]
                                    [img]http://blog.whiteblaizer.com/wp-content/uploads/2009/03/sdm04_03.jpg[/img]
                                    [img]http://blog.whiteblaizer.com/wp-content/uploads/2009/03/sdm04_02a.gif[/img]
                                    • garydornG Offline
                                      garydorn
                                      images changed to uploads rather than linked
                                        [edg3d:1evudelo]gV91M4RhOcwv4Fz[/edg3d:1evudelo]
                                        female-base-head.skp
                                          Nice! That looks to be similar to the challenge HornOxx and I was looking into earlier:
                                          http://sketchucation.com/forums/viewtopic.php?f=397%26amp;t=63826%26amp;start=300#p588912
                                          http://sketchucation.com/forums/viewtopic.php?f=397%26amp;t=63826%26amp;start=330#p588916
                                          • tuna1957T Offline
                                            tuna1957
                                            o.k I know it's not a car or godzilla, just started messing about with SubD last night. trying to wrap my brain around a new way of doing things. here's a mod style chip & dip bowl for your next party. copied my steps for the pic.
                                            plain cup in front pretty much native SU tools
                                            far left, base shape of bowl , pretty much Vertex tools
                                            middle bowl , shaped wavy edge , all Vertex
                                            far right , SubD , copied and scaled down for the dip.
                                            I think I really like this, don't think I could have got these shape without Vertex & SubD , thanks thomthom.. ๐Ÿ‘
                                            • 82
                                            • 83
                                            • 7 / 83
