    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.1m Views 79 Watching
      Yes the difficulty with Subdivision modeling against the Nurbs modeling where you have yet all the curves of the model, is to imagine the "rustic" cubic form before it's transformation! πŸ˜„
      https://s-media-cache-ak0.pinimg.com/236x/1a/d5/a5/1ad5a5b1e29b783619d44f7751f6c285.jpg
        miikka1978
        Is there any plugin working like Blender's Add Loop cut, see link below? I think that this would be really useful when using SubD.
        https://www.blender.org/manual/modeling/meshes/editing/subdividing/loop_subdivide.html
        https://www.youtube.com/watch?v=_f4XKe8lZEU
        • ely862meE Offline
          ely862me
          If you look back a little you will see that we talk about that too, it's called Quad face tools, you can find it in the plugins library.
          Elisei (sketchupper)
          Come and See EliseiDesign
          • HornOxxH Offline
            HornOxx
            ...completed the wing to a plane - certainly not a beauty πŸ˜•
            plane4_proxy.skp
            never trust a skinny cook
            • JQLJ Offline
              JQL
              Not bad either... but it was a very promising wing
              www.casca.pt
              Visit us on facebook!
              • HornOxxH Offline
                HornOxx
                @jql said:
                ... but it was a very promising wing...
                thanks
                πŸ˜† ok - give this wing an other try
                  Yet a charm certain! πŸ˜‰
                  • StinkieS Offline
                    Stinkie
                    @thomthom said:
                    There are talks going on with various render engines to allow for them to render high-poly variants from the low-polys.
                    Nice! πŸ‘
                    • O Offline
                      optimaforever
                      In the same order of idea, can you thomthom develop a quadchamfer4SU?
                      Ideally it would be a mix between the editability of SubD and the easiness of RoundCorner...
                      Roundcorner is good but it doesn't allow for editing. I have to keep a non-chamfered version in a temp layer if I need to edit it again. And SubD need manually offsetted lines to control the distance of chamfering. On complex models, it can quicky become a time-consuming burden, just to create chamfered edges, not to mention the file size and the memory footprint.
                      This TTQuadchamfer would be a quick 3D chamfer/fillet tool that automatically creates the needed lines offsets according to pre-entered parameters, which in return could allow easy re-editing, should the need arise. And afterward, one could tweak the fillet values edge by edge for more flexibility.
                      What do you think?
                        Got some visuals to illustrate expected result?
                        • O Offline
                          optimaforever
                          Have you seen http://www.mariussilaghi.com/products/quad-chamfer ?
                          • gillesG Offline
                            gilles
                            Streamliner, based on Norman E. Timbs 48 buick.
                            • JQLJ Offline
                              JQL
                              What do you think?
                              Actually I'm simply not using SubD, because it would be the most fun plugin I'd have, but it's not really useful for what I need right now. I would have yet another toy to have fun with and deviate my attention for what I do for a living... I must resist...
                              If you'd do it, it would be extremelly useful if you'd integrate it with SubD methodology and chamfer it only when subdividing, keeping UV's, allowing for creases worflow to be integrated too and, probably integrate it in the rendering workflow too.
                              I didn't know it yet but if SubD would be able to produce that, it would turn into the most useful toy an architect that deals with archviz needs apart from the renderers themselves.
                              Thanks for that feature request Optimaforever, I really hope Thomthom pulls that one off!
                              www.casca.pt
                                @: Gilles where is the model ? πŸ˜‰
                                Inspiration Vrooum, vrooum! πŸ’š
                                car_v6.zip
                                • gillesG Offline
                                  gilles
                                  [attachment=2:2ruqdqif]<!-- ia2 -->blobcar.jpg<!-- ia2 -->[/attachment:2ruqdqif]
                                  STREAMLINER.skp
                                  • StinkieS Offline
                                    Stinkie
                                    Oooh, it'd be great to have that in SU.
                                    • O Offline
                                      optimaforever
                                      Indeed, my next request would be that the quad chamfer only applies when rendering, a bit alla Skatter-way, with the "render only" option.
                                      I don't know if it's in the pipeline but I guess that having the SUbD not visible when working and only visible during rendertime would be an equally useful feature. A kind of general SUbD toggle on/off in the SUbD preferences. The thing is, there is always an SUbD object on which I forget to apply the subdivision before pushing on the render button (lazy me), and having a "all subd on when rendering" toggle button would save my ass for sure 🀒
                                        @ Gilles : Thx! πŸ˜‰
                                        Model by Gilles above!
                                        The trick is colored first then SUbD πŸ˜‰
                                        Or there is another trick after the SUbD ?
                                        • O Offline
                                          optimaforever
                                          very nice pilou ! 😎
                                          • HornOxxH Offline
                                            HornOxx
                                            @pilou said:
                                            ... The trick is colored first ...?
                                            typical French - you inspire a new fashion trend !! πŸ˜›
                                            • 76
                                            • 77
                                            • 78
                                            • 79
                                            • 80
                                            • 81
                                            • 82
                                            • 83
                                            • 78 / 83
